archaeus2525 0 Posted April 12, 2020 Posted April 12, 2020 hello guys i have a seever with emby the problems is only dvdusb and pgssub are showing when i play the movies.when i download any srt external subtitle movie start but not showing the subtitle.and another problem after downlading srt external sub and choose and start playing the movie it give me error too many errors.i try to disable hardware acceleration still the same.can u help me with that?thx
ebr 16310 Posted April 12, 2020 Posted April 12, 2020 Hi. Can we please go over a specific example? Thanks. How to Report a Problem
ebr 16310 Posted April 12, 2020 Posted April 12, 2020 Hi. Exactly what did you do? What was the problem? At what time? Thanks.
archaeus2525 0 Posted April 12, 2020 Author Posted April 12, 2020 exactly.i have a lot of movies on emby some movies has allready ddvsub or pgssub subtitles built in.but some others movie dont. so i choose a random movie then i go to edit subtitles,then i found subtitle on open subtitles,i download it,and then play the movie. the srt external subtitle previous download it dont work with the movie.dont appear.this is the problem.i repet this probelm onny occurs when i download external srt subtitle.
archaeus2525 0 Posted April 12, 2020 Author Posted April 12, 2020 i allready attached a log.look at my previous posts
Luke 42213 Posted April 13, 2020 Posted April 13, 2020 Can you please attach the log to this posting rather than linking directly to your server? You are exposing your emby server by doing that. I've removed the link. Thanks.
Luke 42213 Posted April 14, 2020 Posted April 14, 2020 Glad you figured it out, thanks for following up !
