GPlayer 0 Posted April 12, 2020 Posted April 12, 2020 Screenshots of libraries https://bit.ly/2K1aMDu https://bit.ly/3b9B6HO https://bit.ly/2V0m2GB https://bit.ly/2K09okQ https://bit.ly/34sO9Bw https://bit.ly/2y8WlLb https://bit.ly/2yd2e9S https://bit.ly/34sPUi7 how many emby libraries have you created, and what folders have you added to each one?
Luke 42246 Posted April 14, 2020 Posted April 14, 2020 Since you can find them by searching i would suggest using the metadata editor to make sure they have season and episode numbers assigned in emby. please see if that helps. thanks.
KimNK 0 Posted April 14, 2020 Author Posted April 14, 2020 They are all named correct as refreshing metadata on each episode individually causes emby to identify and sort each episode out.
KimNK 0 Posted April 14, 2020 Author Posted April 14, 2020 No. I have almost 5k series it is not possible or practical to do that to every episode that has been updated in the last few weeks.
Luke 42246 Posted April 14, 2020 Posted April 14, 2020 Can you try what i suggested about the metadata editor? Thanks.
