sjpotter 12 Posted April 12, 2020 Posted April 12, 2020 What I mean by my question is, lets say I have 2 version of a record stored. On is a 10 bit hevc version and the other is a normal h264 version. Q1. does it see 2 different versions of the same record. i.e. does it record that it has access to bothQ2. If I only allow direct streaming / playing, will it use the "best" one it can direct stream. i.e. i I'm playing on an old machine that can't decode hevc, it will choose the h264 version, but if I'm on a machine that can, it will choose the hevc version.
denz 501 Posted April 12, 2020 Posted April 12, 2020 (edited) The first question it will be yes next to video above play button you should see a drop down arrow letting you choose which version of the video you want. 2nd i am not sure but if your system doesn’t support it will transcode the video now which version of video it will use to transcode I don’t know don’t have anything to test but I am sure somebody else with reply. Edited April 13, 2020 by denz
ebr 16310 Posted April 12, 2020 Posted April 12, 2020 Hi. The answer to both is yes if what you are talking about is a video file. You have to follow certain conventions, however: Movie Naming
