tamim2007 5 Posted April 9, 2020 Posted April 9, 2020 Hi guys , I hope everyone is safe. I have a small issue with emby app for samsung ks8000 / All emby versions. In the middle of any episode press the "next item". When The next episode plays wait until the playback control disappears. Just press OK button in the remote. It will jump to next episode again. I have to press down button instead of ok or will jump to next. thanks and be safe guys.
tamim2007 5 Posted April 9, 2020 Author Posted April 9, 2020 (edited) Hi Luke 1.0,77 via usb this issue is being a long time more than a year. I hope it's clear. thanks @@SamES Edited April 9, 2020 by Luke
tamim2007 5 Posted April 9, 2020 Author Posted April 9, 2020 , pls see the vid for more explanation. https://youtu.be/qlK0tQ3qIco
SamES 1084 Posted April 10, 2020 Posted April 10, 2020 I don't see this issue on my 2017 TV, but I see a different problem. For me, when I skip to the next episode, the OSD doesn't automatically hide at all. @@Luke, the OSD is receiving both a keydown and a click event. The keydown event does what it is supposed to and skips to the next item in the queue, but when the click event fires immediately afterwards, as the next queue item is being loaded the check for isDisplayingLocalVideo() in startOsdHideTimer() fails as no media is loaded. This causes the timer to be cancelled with the OSD still visible and it never hides. I think the easiest fix is to remove this one check for isDisplayingLocalVideo(). I don't see any side effect as the same check is called again in hideOsd() anyway, but by this stage the media playback should have started.
Luke 42242 Posted April 14, 2020 Posted April 14, 2020 , pls see the vid for more explanation. https://youtu.be/qlK0tQ3qIco Ok I'll try to reproduce this. Thanks.
