DwarvenLord1 4 Posted April 9, 2020 Posted April 9, 2020 From time to time I have an issue with playback. It is intermittent. I am using the Web Interface for 4.4.1.0 I start playing a show, and while the show is running, I use the time/position slider to go to a different spot in the episode. The wheel of wait starts spinning, as expected, but it doesn't ever stop. I have tried going back to the main menu, but when I try to play the episode, I get the same thing, infinite wheel of wait. I close the tab and/or browser and reattach to the server and when I go to that episode...Wheel Of WAIT! What I can do to kill it is to either, play anything else for a second, and go back to the menu and to that episode that had a problem, and it plays fine. I can also mark the episode as played, and then mark it unplayed, and I can watch it. I assume this is a cache issue of some sort. Plex will do the same thing, with getting stuck occasionally when using the slider, but I can back out of it and then replay and it works fine, whereas Emby still has the issue. This is mostly just an FYI. If someone knows what the problem is, or if I can adjust something so it isn't a problem any more that would be awesome.
Luke 42213 Posted April 9, 2020 Posted April 9, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue: https://emby.media/community/index.php?/topic/739-how-to-report-a-problem/ Thanks!
