bp Media 0 Posted April 8, 2020 Posted April 8, 2020 Hi All, After a reboot I attempted to start Emby using my standard shortcut and never saw the taskbar Emby icon pop up. Looking through the running programs also revealed the app not running. I made no system changes (that I am aware of) but obviously something changed. My guess is a .NET related error causing Emby not to start based on the info I provided below although I’m turning to the experts for that validation and rementy. Let me know where to start and if further information is required for diagnosis. Thanks All. System Windows 10, Fully Patched Emby Log is attached: Checking Windows Application logs showed the following (3) errors: .NET Runtime, Event ID 1026 Application: EmbyServer.exe CoreCLR Version: 4.700.20.6602 .NET Core Version: 3.1.2 Description: The process was terminated due to an unhandled exception. Exception Info: System.BadImageFormatException: Could not load file or assembly 'MediaBrowser.Model, Version=4.4.0.40, Culture=neutral, PublicKeyToken=null'. Format of the executable (.exe) or library (.dll) is invalid. File name: 'MediaBrowser.Model, Version=4.4.0.40, Culture=neutral, PublicKeyToken=null' at EmbyServer.Program.Main(String[] args) Application Error, Event ID 1000 Faulting application name: EmbyServer.exe, version: 4.4.0.40, time stamp: 0x5e222541 Faulting module name: KERNELBASE.dll, version: 10.0.18362.719, time stamp: 0xb31987d3 Exception code: 0xe0434352 Fault offset: 0x000000000003a859 Faulting process id: 0x3314 Faulting application start time: 0x01d60df38312fe71 Faulting application path: C:\Users\Bill\AppData\Roaming\MediaBrowser-Server\system\EmbyServer.exe Faulting module path: C:\WINDOWS\System32\KERNELBASE.dll Report Id: d5b24eda-a340-44c9-9a02-edf339f93535 Faulting package full name: Faulting package-relative application ID: Windows Error Reporting Fault bucket 2073956257766826960, type 4 Event Name: APPCRASH Response: Not available Cab Id: 0 Problem signature: P1: EmbyServer.exe P2: 4.4.0.40 P3: 5e222541 P4: KERNELBASE.dll P5: 10.0.18362.719 P6: b31987d3 P7: e0434352 P8: 000000000003a859 P9: P10: embyserver.txt
Luke 42213 Posted April 9, 2020 Posted April 9, 2020 Hi, I would suggest shutting down emby server, then installing the latest version from the website on top of your existing version and see if that helps.
bp Media 0 Posted April 9, 2020 Author Posted April 9, 2020 Hi Admin, Will this process retain all my current settings, movie pointers & metadata? -Thx
