MateyTate 16 Posted April 8, 2020 Posted April 8, 2020 (edited) Hello, So I started using iFlicks on the Mac to take my MP4s with 5.1 AAC tracks, and convert them to MP4 5.1 AC3 and a 2 channel AAC (for Apple compatibility). However whenever I try to play them with Emby on my NVIDIA shield, the 2 channel AAC works fine, but crashes if I switch to the AC3 track. Likewise if I start the movie with the AC3 track, it will play but has a constant blue spinning circle which will eventually crash after approx 10 seconds. If I play them via the web browser, its hit and miss, sometimes they work then the next minute they won't. These files play fine with VLC. Is there something wrong with the encoding being done by iFlicks? FFMPEG log below, Emby log attached. Appreciate the help! 2020-04-08 23:47:42.094 Emby Server version: 4.4.1.0Operating system: Unix 3.10.105.0Command Line: /var/packages/EmbyServer/target/server/EmbyServer.exe -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121 -ignore_vaapi_enabled_flagApp: Emby Web 4.4.2.1Safarihttp://192.168.1.5:8096/emby/videos/162864/hls1/main/0.ts?DeviceId=TW96aWxsYS81LjAgKE1hY2ludG9zaDsgSW50ZWwgTWFjIE9TIFggMTBfMTRfMykgQXBwbGVXZWJLaXQvNjA1LjEuMTUgKEtIVE1MLCBsaWtlIEdlY2tvKSBWZXJzaW9uLzEyLjAuMyBTYWZhcmkvNjA1LjEuMTV8MTU1MzkwMjE3NzM1OA11&MediaSourceId=a8e7e0bb5f7382b9c5f57d9679e1f8ff&PlaySessionId=f053f249e763420f9f6f9865f7f02c6b&api_key=24777b7c4d734f6da704cce360909e09&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=139616000&AudioBitrate=384000&MaxWidth=1920&AudioStreamIndex=4&SubtitleMethod=Encode&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=2&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline&h264-level=52&TranscodeReasons=AudioCodecNotSupported{"Protocol":"File","Id":"a8e7e0bb5f7382b9c5f57d9679e1f8ff","Path":"/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4","Type":"Default","Container":"mp4","Size":1761474984,"Name":"Mad Men - S01E03 - Marriage of Figaro-1","IsRemote":false,"RunTimeTicks":26548020000,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":true,"IsInfiniteStream":false,"RequiresOpening":false,"RequiresClosing":false,"RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"hevc","CodecTag":"hvc1","Language":"eng","TimeBase":"1/100000","CodecTimeBase":"1001/24000","VideoRange":"SDR","DisplayTitle":"1080p HEVC","DisplayLanguage":"English","IsInterlaced":false,"BitRate":4500260,"BitDepth":10,"RefFrames":1,"IsDefault":true,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":23.9760265,"RealFrameRate":23.9760246,"Profile":"Main 10","Type":"Video","AspectRatio":"16:9","Index":0,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p10le","Level":120},{"Codec":"mjpeg","CodecTag":"jpeg","Language":"und","ColorSpace":"bt470bg","TimeBase":"1/100000","CodecTimeBase":"1659183/3125","VideoRange":"SDR","DisplayTitle":"1080p MJPEG","IsInterlaced":false,"BitRate":536,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":0.00188345707,"RealFrameRate":11.9880123,"Profile":"Baseline","Type":"Video","AspectRatio":"16:9","Index":2,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuvj420p","Level":-99,"IsAnamorphic":false},{"Codec":"aac","CodecTag":"mp4a","Language":"eng","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"English AAC stereo (Default)","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":161400,"Channels":2,"SampleRate":48000,"IsDefault":true,"IsForced":false,"Profile":"LC","Type":"Audio","Index":3,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"ac3","CodecTag":"ac-3","Language":"eng","TimeBase":"1/48000","CodecTimeBase":"1/48000","DisplayTitle":"English Dolby Digital 5.1","DisplayLanguage":"English","IsInterlaced":false,"ChannelLayout":"5.1","BitRate":640000,"Channels":6,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":4,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"},{"Codec":"mov_text","CodecTag":"tx3g","Language":"eng","TimeBase":"1/1000","CodecTimeBase":"0/1","DisplayTitle":"English (Default MOV_TEXT)","DisplayLanguage":"English","IsInterlaced":false,"BitRate":73,"IsDefault":true,"IsForced":false,"Height":162,"Width":1920,"Type":"Subtitle","Index":5,"IsExternal":false,"IsTextSubtitleStream":true,"SupportsExternalStream":true,"Protocol":"File"},{"Codec":"png","TimeBase":"1/90000","CodecTimeBase":"0/1","IsInterlaced":false,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":600,"Width":600,"RealFrameRate":90000,"Type":"EmbeddedImage","AspectRatio":"1:1","Index":6,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"rgb24","Level":-99}],"Formats":[],"Bitrate":5308041,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false}>>>>>> User policy for unknownEnablePlaybackRemuxing: TrueEnableVideoPlaybackTranscoding: TrueEnableAudioPlaybackTranscoding: True>>>>>> Affected codecsEncoder VAAPI Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx - H.264 (AVC)Adapter #0: 'Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx' Id:8881 (Driver: Intel i965 driver for Intel® CherryView - 2.4.0, Vendor: Intel Corporation)Frame Sizes: 32x32...4096x4096Color Formats: NV12, P010Profiles: Constrained Baseline Profile (Level 6), Main Profile (Level 6), High Profile (Level 6)Decoder VAAPI Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx - H.265 (HEVC)Adapter #0: 'Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx' Id:8881 (Driver: Intel i965 driver for Intel® CherryView - 2.4.0, Vendor: Intel Corporation)Frame Sizes: max 4096x4096Color Formats: NV12, P010, NV16Profiles: Main Profile (Level 6 (Main))>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: True, Mode: AutomaticInfo Checking: 'VAAPI Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx - H.264 (AVC)'Info Check successful - selecting 'VAAPI Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx - H.264 (AVC)'>>>>>> FindVideoDecoder - MediaType: hevc, Mode: AutomaticInfo Checking: 'VAAPI Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx - H.265 (HEVC)'NoMatch Codec does not support profile 'Main 10 Profile'Info Decoder does not matchInfo Checking: 'Automatic software decoder'Info Check successful - selecting 'Automatic software decoder'>>>>>> Processing PlanInfo Name CanDoInHardware WillDoInHardware ReasonInfo Automatic software decoder >> False False Software CodecInfo VideoInput >> False False Not a hardware decoderInfo ColorConversion >> True TrueInfo VideoOutput >> True True Hardware encoderInfo VAAPI Atom/Celeron/Pentium Processor ... >> True True Hardware Codec>>>>>> Projected Processing FormatsInfo Previous HW-Context Format SW-Format NextInfo hevc >> - yuv420p10 yuv420p10 >> formatInfo format >> - yuv420p10 yuv420p10 >> hwuploadInfo hwupload >> VAAPI vaapi_vld yuv420p10 >> scale_vaapiInfo scale_vaapi >> VAAPI vaapi_vld nv12 >>>>>>> Legacy Command/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -init_hw_device vaapi=vad0:/dev/dri/renderD128 -filter_hw_device vad0 -f mp4 -i file:"/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4" -threads 0 -map 0:0 -map 0:4 -sn -c:v:0 h264_vaapi -filter_complex "[0:0]format=nv12|vaapi,hwupload" -b:v:0 9000520 -maxrate 9000520 -bufsize 18001040 -profile:v:0 high -level:v:0 4.1 -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 libmp3lame -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -filter:a:0 "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_%d.ts" -map 0:5 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 0 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt">>>>> Actual Command/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -loglevel +timing -y -print_graphs_file /var/packages/EmbyServer/target/var/logs/ffmpeg-transcode-ac3e24b2-c4a9-4c80-8f2e-bd08db80c8e1_1graph.txt -copyts -start_at_zero -init_hw_device "vaapi=vad0:/dev/dri/renderD128" -filter_hw_device vad0 -f mov,mp4,m4a,3gp,3g2,mj2 -c:v:0 hevc -c:v:1 mjpeg -c:v:2 png -i "/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4" -filter_complex "[0:0]format@f1=pix_fmts=yuv420p10,hwupload@f2,scale_vaapi@f3=format=nv12[f3_out0]" -map [f3_out0] -map 0:4 -sn -c:v:0 h264_vaapi -b:v:0 9000520 -g:v:0 72 -maxrate:v:0 9000520 -bufsize:v:0 18001040 -sc_threshold:v:0 0 -keyint_min:v:0 72 -profile:v:0 high -level:v:0 4 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8 -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_%d.ts" -map 0:5 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format webvtt -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8 -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:00:00.000 "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt"22:47:42.316 ffmpeg version 4.3.0-emby_2020_02_24-20200402T080457UTC Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC22:47:42.316 built with gcc 7.3.0 (GCC)22:47:42.316 Execution Date: 2020-04-08 22:47:4222:47:42.729 [mov,mp4,m4a,3gp,3g2,mj2 @ 0x1bb1940] stream 0, timescale not set22:47:42.735 [mjpeg @ 0x1bbf600] EOI missing, emulating22:47:42.745 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4':22:47:42.745 Metadata:22:47:42.745 major_brand : mp4222:47:42.745 minor_version : 022:47:42.745 compatible_brands: mp42isomavc122:47:42.745 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.745 title : Marriage of Figaro22:47:42.745 artist : Mad Men22:47:42.745 album_artist : Mad Men22:47:42.745 album : Mad Men, Season 122:47:42.745 comment : Information courtesy of The TVDB (https://www.thetvdb.com). Used with permission.22:47:42.745 genre : Drama22:47:42.745 date : 2007-08-02T10:00:00Z22:47:42.745 track : 322:47:42.745 compilation : 022:47:42.745 show : Mad Men22:47:42.745 network : AMC22:47:42.745 episode_id : S01E0322:47:42.745 season_number : 122:47:42.745 episode_sort : 322:47:42.745 description : Pete Campbell returns from his honeymoon with tall tales and a big grin on his face. He does tell Peggy Olson that their fling before his marriage was for one night only.22:47:42.745 synopsis : Pete Campbell returns from his honeymoon with tall tales and a big grin on his face. He does tell Peggy Olson that their fling before his marriage was for one night only. Don Draper runs into an old army buddy who knows him under the name of Dick Whitman.22:47:42.745 encoder : iFlicks 3.4.1.402322:47:42.745 hd_video : 222:47:42.745 media_type : 1022:47:42.745 rating : 022:47:42.745 gapless_playback: 022:47:42.745 account_id :22:47:42.745 iTunEXTC : uk-tv|Caution|600|22:47:42.745 iTunMOVI : <?xml version="1.0" encoding="UTF-8"?>: <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">: <plist version="1.0">: <dict>: <key>cast</key>: <array>: <dict>: <key>name</key>: <string>Alison Brie</string>: </dict>: <dict>: <key>name</key>: <string>Jon Hamm</string>: </dict>: <dict>: <key>name</key>: <string>Kiernan Shipka</string>: </dict>: <dict>: <key>name</key>: <string>Elisabeth Moss</string>: </dict>: <dict>: <key>name</key>: <string>Kevin Rahm</string>: </dict>: <dict>: <key>name</key>: <string>Robert Morse</string>: </dict>: <dict>: <key>name</key>: <string>John Slattery</string>: </dict>: <dict>: <key>name</key>: <string>Jessica Par??</string>: </dict>: <dict>: <key>name</key>: <string>Rich Sommer</string>: </dict>: <dict>: <key>name</key>: <string>Jared Harris</string>: </dict>: <dict>: <key>name</key>: <string>Christina Hendricks</string>: </dict>: <dict>: <key>name</key>: <string>Joel Murray</string>: </dict>: <dict>: <key>name</key>: <string>Michael Gladis</string>: </dict>: <dict>: <key>name</key>: <string>Christopher Stanley</string>: </dict>: <dict>: <key>name</key>: <string>Vincent Kartheiser</string>: </dict>: <dict>: <key>name</key>: <string>Ben Feldman</string>: </dict>: <dict>: <key>name</key>: <string>Aaron Staton</string>: </dict>: <dict>: <key>name</key>: <string>Jay R. Ferguson</string>: </dict>: <dict>: <key>name</key>: <string>January Jones</string>: </dict>: <dict>: <key>name</key>: <string>James Wolk</string>: </dict>: <dict>: <key>name</key>: <string>Alastair Duncan</string>: </dict>: <dict>: <key>name</key>: <string>Alexa Alemanni</string>: </dict>: <dict>: <key>name</key>: <string>Anne Dudek</string>: </dict>: <dict>: <key>name</key>: <string>Bryan Batt</string>: </dict>: <dict>: <key>name</key>: <string>Darby Stanchfield</string>: </dict>: <dict>: <key>name</key>: <string>Jerry Kernion</string>: </dict>: <dict>: <key>name</key>: <string>Kate Connor</string>: </dict>: <dict>: <key>name</key>: <string>Kristoffer Polaha</string>: </dict>: <dict>: <key>name</key>: <string>Maggie Siff</string>: </dict>: <dict>: <key>name</key>: <string>Marten Holden Weiner</string>: </dict>: <dict>: <key>name</key>: <string>Price Carson</string>: </dict>: <dict>: <key>name</key>: <string>Rosemarie DeWitt</string>: </dict>: <dict>: <key>name</key>: <string>Stephanie Courtney</string>: </dict>: </array>: <key>directors</key>: <array>: <dict>: <key>name</key>: <string>Ed Bianchi</string>: </dict>: </array>: <key>screenwriters</key>: <array>: <dict>: <key>name</key>: <string>Tom Palmer</string>: </dict>: </array>: <key>studio</key>: <string></string>: </dict>: </plist>:22:47:42.746 Duration: 00:44:14.80, start: 0.000000, bitrate: 5308 kb/s22:47:42.746 Stream #0:0(eng): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv), 1920x1080, 4500 kb/s, Level 120, 23.98 fps, 23.98 tbr, 100k tbn, 23.98 tbc (default)22:47:42.746 Metadata:22:47:42.746 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.746 encoder : H.26522:47:42.746 Stream #0:1(und): Data: bin_data (text / 0x74786574)22:47:42.746 Metadata:22:47:42.746 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.746 Stream #0:2(und): Video: mjpeg (Baseline) (jpeg / 0x6765706A), yuvj420p(pc, bt470bg/unknown/unknown), 1920x1080 [sAR 72:72 DAR 16:9], 0 kb/s, 0.0019 fps, 11.99 tbr, 100k tbn, 100k tbc (attached pic) (timed thumbnails)22:47:42.746 Metadata:22:47:42.746 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.746 Stream #0:3(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 161 kb/s (default)22:47:42.746 Metadata:22:47:42.746 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.746 Stream #0:4(eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 640 kb/s22:47:42.746 Metadata:22:47:42.746 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.746 Side data:22:47:42.747 audio service type: main22:47:42.747 Stream #0:5(eng): Subtitle: mov_text (tx3g / 0x67337874), 1920x162, 0 kb/s (default)22:47:42.747 Metadata:22:47:42.747 rotate : 022:47:42.747 creation_time : 2020-04-08T21:04:33.000000Z22:47:42.747 Stream #0:6: Video: png, rgb24(pc), 600x600, 90k tbr, 90k tbn, 90k tbc (attached pic)22:47:42.750 Output #1, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt':22:47:42.750 Metadata:22:47:42.750 encoder : Lavf58.35.10022:47:42.750 Stream #1:0: Subtitle: webvtt, 1920x162 (default)22:47:42.750 Metadata:22:47:42.750 encoder : Lavc58.62.100 webvtt22:47:42.750 Stream #1:1: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv), 1920x1080, q=2-31, 4500 kb/s, Level 120, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc (default)22:47:42.750 Stream mapping:22:47:42.750 Stream #0:0 (hevc) -> format (graph 0)22:47:42.750 scale_vaapi (graph 0) -> Stream #0:0 (h264_vaapi)22:47:42.750 Stream #0:4 -> #0:1 (ac3 (native) -> mp3 (libmp3lame))22:47:42.750 Stream #0:5 -> #1:0 (mov_text (native) -> webvtt (native))22:47:42.750 Stream #0:0 -> #1:1 (copy)22:47:42.750 Press [q] to stop, [?] for helpffmpeg: gen75_vpp_vebox.c:1023: hsw_veb_surface_state: Assertion `obj_surf->fourcc == VA_FOURCC_NV12 || obj_surf->fourcc == VA_FOURCC_YUY2 || obj_surf->fourcc == VA_FOURCC_AYUV || obj_surf->fourcc == VA_FOURCC_RGBA' failed.======= 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>>>>>> Affected codecsEncoder libx264 Software EncoderProfiles: Baseline Profile (Level 6.2), Main Profile (Level 6.2), High Profile (Level 6.2), High 10 Profile (Level 6.2), High 4:2:2 Profile (Level 6.2), High 4:4:4 Predictive Profile (Level 6.2)Info Previous transcoding attempt failed. Falling back to software transcoding.>>>>>> FindVideoEncoder - Media: h264, UseHardwareCodecs: False, Mode: AutomaticInfo Checking: 'libx264 Software Encoder'Info Check successful - selecting 'libx264 Software Encoder'>>>>>> FindVideoDecoder - MediaType: hevc, Mode: AutomaticInfo Checking: 'Automatic software decoder'Info Check successful - selecting 'Automatic software decoder'>>>>>> Processing PlanInfo Name CanDoInHardware WillDoInHardware ReasonInfo Automatic software decoder >> False False Software CodecInfo VideoInput >> False False Not a hardware decoderInfo ColorConversion >> False FalseInfo VideoOutput >> False False Not a hardware encoderInfo libx264 Software Encoder >> False False Software Codec>>>>>> Projected Processing FormatsInfo Previous HW-Context Format SW-Format NextInfo hevc >> - yuv420p10 yuv420p10 >> formatInfo format >> - yuv420p yuv420p >>Legacy Command:/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -f mp4 -i file:"/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4" -threads 0 -map 0:0 -map 0:4 -sn -c:v:0 libx264 -pix_fmt yuv420p -maxrate 9000520 -bufsize 18001040 -preset veryfast -profile:v:0 high -level:v:0 4.1 -crf 23 -x264opts:0 subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none -g:v:0 72 -keyint_min:v:0 72 -sc_threshold:v:0 0 -copyts -vsync -1 -codec:a:0 libmp3lame -metadata:s:a:0 language=eng -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -filter:a:0 "volume=2" -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_%d.ts" -map 0:5 -map 0:0 -c:v:0 copy -codec:0 webvtt -copyts -vsync -1 -f segment -segment_time 3 -segment_format webvtt -max_delay 5000000 -avoid_negative_ts disabled -start_at_zero -write_empty_segments 1 -segment_list_type m3u8 -segment_start_number 0 -segment_write_temp 1 -break_non_keyframes 1 -segment_list "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8" -y "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt"Actual Command:/var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -loglevel +timing -y -print_graphs_file /var/packages/EmbyServer/target/var/logs/ffmpeg-transcode-ac3e24b2-c4a9-4c80-8f2e-bd08db80c8e1_1graph.txt -copyts -start_at_zero -f mov,mp4,m4a,3gp,3g2,mj2 -c:v:0 hevc -c:v:1 mjpeg -c:v:2 png -i "/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4" -filter_complex "[0:0]format@f1=pix_fmts=yuv420p[f1_out0]" -map [f1_out0] -map 0:4 -sn -c:v:0 libx264 -g:v:0 72 -maxrate:v:0 9000520 -bufsize:v:0 18001040 -sc_threshold:v:0 0 -keyint_min:v:0 72 -pix_fmt:v:0 yuv420p -preset:v:0 veryfast -profile:v:0 high -level:v:0 4.0 -x264opts:v:0 "subme=0:me_range=4:rc_lookahead=10:me=dia:no_chroma_me:8x8dct=0:partitions=none" -crf:v:0 23 -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -metadata:s:a:0 language=eng -filter:a:0 "volume=2" -disposition:a:0 default -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8 -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_%d.ts" -map 0:5 -map 0:0 -an -c:v:0 copy -c:s:0 webvtt -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format webvtt -segment_list /var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8 -segment_list_type m3u8 -segment_time 3 -segment_start_number 0 -break_non_keyframes 1 -individual_header_trailer 1 -write_header_trailer 0 -write_empty_segments 1 -segment_write_temp 1 -min_frame_time 00:00:00.000 "/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt"22:47:45.918 ffmpeg version 4.3.0-emby_2020_02_24-20200402T080457UTC Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC22:47:45.919 built with gcc 7.3.0 (GCC)22:47:45.919 Execution Date: 2020-04-08 22:47:4522:47:45.985 [mov,mp4,m4a,3gp,3g2,mj2 @ 0xf0d8c0] stream 0, timescale not set22:47:45.991 [mjpeg @ 0xf1b780] EOI missing, emulating22:47:46.001 Input #0, mov,mp4,m4a,3gp,3g2,mj2, from '/volume1/Media/TV Shows/Mad Men/Season 1/Mad Men - S01E03 - Marriage of Figaro-1.mp4':22:47:46.001 Metadata:22:47:46.001 major_brand : mp4222:47:46.001 minor_version : 022:47:46.001 compatible_brands: mp42isomavc122:47:46.002 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.002 title : Marriage of Figaro22:47:46.002 artist : Mad Men22:47:46.002 album_artist : Mad Men22:47:46.002 album : Mad Men, Season 122:47:46.002 comment : Information courtesy of The TVDB (https://www.thetvdb.com). Used with permission.22:47:46.002 genre : Drama22:47:46.002 date : 2007-08-02T10:00:00Z22:47:46.002 track : 322:47:46.002 compilation : 022:47:46.002 show : Mad Men22:47:46.002 network : AMC22:47:46.002 episode_id : S01E0322:47:46.002 season_number : 122:47:46.002 episode_sort : 322:47:46.002 description : Pete Campbell returns from his honeymoon with tall tales and a big grin on his face. He does tell Peggy Olson that their fling before his marriage was for one night only.22:47:46.002 synopsis : Pete Campbell returns from his honeymoon with tall tales and a big grin on his face. He does tell Peggy Olson that their fling before his marriage was for one night only. Don Draper runs into an old army buddy who knows him under the name of Dick Whitman.22:47:46.002 encoder : iFlicks 3.4.1.402322:47:46.002 hd_video : 222:47:46.002 media_type : 1022:47:46.002 rating : 022:47:46.002 gapless_playback: 022:47:46.002 account_id :22:47:46.002 iTunEXTC : uk-tv|Caution|600|22:47:46.002 iTunMOVI : <?xml version="1.0" encoding="UTF-8"?>: <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">: <plist version="1.0">: <dict>: <key>cast</key>: <array>: <dict>: <key>name</key>: <string>Alison Brie</string>: </dict>: <dict>: <key>name</key>: <string>Jon Hamm</string>: </dict>: <dict>: <key>name</key>: <string>Kiernan Shipka</string>: </dict>: <dict>: <key>name</key>: <string>Elisabeth Moss</string>: </dict>: <dict>: <key>name</key>: <string>Kevin Rahm</string>: </dict>: <dict>: <key>name</key>: <string>Robert Morse</string>: </dict>: <dict>: <key>name</key>: <string>John Slattery</string>: </dict>: <dict>: <key>name</key>: <string>Jessica Par??</string>: </dict>: <dict>: <key>name</key>: <string>Rich Sommer</string>: </dict>: <dict>: <key>name</key>: <string>Jared Harris</string>: </dict>: <dict>: <key>name</key>: <string>Christina Hendricks</string>: </dict>: <dict>: <key>name</key>: <string>Joel Murray</string>: </dict>: <dict>: <key>name</key>: <string>Michael Gladis</string>: </dict>: <dict>: <key>name</key>: <string>Christopher Stanley</string>: </dict>: <dict>: <key>name</key>: <string>Vincent Kartheiser</string>: </dict>: <dict>: <key>name</key>: <string>Ben Feldman</string>: </dict>: <dict>: <key>name</key>: <string>Aaron Staton</string>: </dict>: <dict>: <key>name</key>: <string>Jay R. Ferguson</string>: </dict>: <dict>: <key>name</key>: <string>January Jones</string>: </dict>: <dict>: <key>name</key>: <string>James Wolk</string>: </dict>: <dict>: <key>name</key>: <string>Alastair Duncan</string>: </dict>: <dict>: <key>name</key>: <string>Alexa Alemanni</string>: </dict>: <dict>: <key>name</key>: <string>Anne Dudek</string>: </dict>: <dict>: <key>name</key>: <string>Bryan Batt</string>: </dict>: <dict>: <key>name</key>: <string>Darby Stanchfield</string>: </dict>: <dict>: <key>name</key>: <string>Jerry Kernion</string>: </dict>: <dict>: <key>name</key>: <string>Kate Connor</string>: </dict>: <dict>: <key>name</key>: <string>Kristoffer Polaha</string>: </dict>: <dict>: <key>name</key>: <string>Maggie Siff</string>: </dict>: <dict>: <key>name</key>: <string>Marten Holden Weiner</string>: </dict>: <dict>: <key>name</key>: <string>Price Carson</string>: </dict>: <dict>: <key>name</key>: <string>Rosemarie DeWitt</string>: </dict>: <dict>: <key>name</key>: <string>Stephanie Courtney</string>: </dict>: </array>: <key>directors</key>: <array>: <dict>: <key>name</key>: <string>Ed Bianchi</string>: </dict>: </array>: <key>screenwriters</key>: <array>: <dict>: <key>name</key>: <string>Tom Palmer</string>: </dict>: </array>: <key>studio</key>: <string></string>: </dict>: </plist>:22:47:46.002 Duration: 00:44:14.80, start: 0.000000, bitrate: 5308 kb/s22:47:46.003 Stream #0:0(eng): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv), 1920x1080, 4500 kb/s, Level 120, 23.98 fps, 23.98 tbr, 100k tbn, 23.98 tbc (default)22:47:46.003 Metadata:22:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 encoder : H.26522:47:46.003 Stream #0:1(und): Data: bin_data (text / 0x74786574)22:47:46.003 Metadata:22:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 Stream #0:2(und): Video: mjpeg (Baseline) (jpeg / 0x6765706A), yuvj420p(pc, bt470bg/unknown/unknown), 1920x1080 [sAR 72:72 DAR 16:9], 0 kb/s, 0.0019 fps, 11.99 tbr, 100k tbn, 100k tbc (attached pic) (timed thumbnails)22:47:46.003 Metadata:22:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 Stream #0:3(eng): Audio: aac (LC) (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 161 kb/s (default)22:47:46.003 Metadata:22:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 Stream #0:4(eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), fltp, 640 kb/s22:47:46.003 Metadata:22:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 Side data:22:47:46.003 audio service type: main22:47:46.003 Stream #0:5(eng): Subtitle: mov_text (tx3g / 0x67337874), 1920x162, 0 kb/s (default)22:47:46.003 Metadata:22:47:46.003 rotate : 022:47:46.003 creation_time : 2020-04-08T21:04:33.000000Z22:47:46.003 Stream #0:6: Video: png, rgb24(pc), 600x600, 90k tbr, 90k tbn, 90k tbc (attached pic)22:47:46.007 Output #1, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_%d.vtt':22:47:46.007 Metadata:22:47:46.007 encoder : Lavf58.35.10022:47:46.007 Stream #1:0: Subtitle: webvtt, 1920x162 (default)22:47:46.007 Metadata:22:47:46.007 encoder : Lavc58.62.100 webvtt22:47:46.007 Stream #1:1: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv), 1920x1080, q=2-31, 4500 kb/s, Level 120, 23.98 fps, 23.98 tbr, 23.98 tbn, 23.98 tbc (default)22:47:46.007 Stream mapping:22:47:46.007 Stream #0:0 (hevc) -> format (graph 0)22:47:46.007 format (graph 0) -> Stream #0:0 (libx264)22:47:46.007 Stream #0:4 -> #0:1 (ac3 (native) -> mp3 (libmp3lame))22:47:46.007 Stream #0:5 -> #1:0 (mov_text (native) -> webvtt (native))22:47:46.007 Stream #0:0 -> #1:1 (copy)22:47:46.007 Press [q] to stop, [?] for help22:47:46.090 [libx264 @ 0xf44540] using cpu capabilities: MMX2 SSE2Fast SSSE3 SSE4.222:47:46.093 [libx264 @ 0xf44540] profile Main, level 4.022:47:46.093 [libx264 @ 0xf44540] 264 - core 155 - H.264/MPEG-4 AVC codec - Copyleft 2003-2018 - http://www.videolan.org/x264.html - options: cabac=1 ref=1 deblock=1:0:0 analyse=0x1:0 me=dia subme=0 psy=1 psy_rd=1.00:0.00 mixed_ref=0 me_range=4 chroma_me=0 trellis=0 8x8dct=0 cqm=0 deadzone=21,11 fast_pskip=1 chroma_qp_offset=0 threads=6 lookahead_threads=1 sliced_threads=0 nr=0 decimate=1 interlaced=0 bluray_compat=0 constrained_intra=0 bframes=3 b_pyramid=2 b_adapt=1 b_bias=0 direct=1 weightb=1 open_gop=0 weightp=1 keyint=72 keyint_min=37 scenecut=0 intra_refresh=0 rc_lookahead=10 rc=crf mbtree=1 crf=23.0 qcomp=0.60 qpmin=0 qpmax=69 qpstep=4 vbv_maxrate=9000 vbv_bufsize=18001 crf_max=0.0 nal_hrd=none filler=0 ip_ratio=1.40 aq=1:1.0022:47:46.094 Output #0, segment, to '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_%d.ts':22:47:46.094 Metadata:22:47:46.094 encoder : Lavf58.35.10022:47:46.094 Stream #0:0: Video: h264 (libx264), yuv420p, 1920x1080, q=-1--1, 23.98 fps, 90k tbn, 23.98 tbc (default)22:47:46.094 Metadata:22:47:46.094 encoder : Lavc58.62.100 libx26422:47:46.094 Side data:22:47:46.094 cpb: bitrate max/min/avg: 9000000/0/0 buffer size: 18001000 vbv_delay: N/A22:47:46.094 Stream #0:1(eng): Audio: mp3 (libmp3lame), 48000 Hz, stereo, fltp, 192 kb/s (default)22:47:46.094 Metadata:22:47:46.094 encoder : Lavc58.62.100 libmp3lame22:47:46.095 Side data:22:47:46.095 audio service type: main22:47:46.537 frame= 21 fps=0.0 q=28.0 size= 26kB time=00:00:01.03 bitrate=N/A throttle=off speed= 0x22:47:47.038 frame= 46 fps= 45 q=28.0 size= 50kB time=00:00:01.99 bitrate= 427.4kbits/s throttle=off speed=0.945x22:47:47.543 frame= 64 fps= 42 q=28.0 size= 66kB time=00:00:02.61 bitrate= 341.0kbits/s throttle=off speed=1.04x22:47:48.076 frame= 78 fps= 38 q=28.0 size= 182kB time=00:00:03.14 bitrate= 706.6kbits/s throttle=off speed=1.03x22:47:48.695 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:47:48.696 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.003000 Duration=3.003000 offset_pts=0 start_pts=0 Frames=72 filename=E4D7B4_0.ts22:47:48.696 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_1.ts.tmp' for writing22:47:48.697 frame= 93 fps= 36 q=28.0 size= 691kB time=00:00:03.91 bitrate=1965.3kbits/s throttle=off speed= 1.1x22:47:49.158 frame= 107 fps= 34 q=28.0 size= 1006kB time=00:00:04.48 bitrate=2385.0kbits/s throttle=off speed= 1.1x22:47:49.720 frame= 124 fps= 34 q=28.0 size= 1332kB time=00:00:05.06 bitrate=2707.0kbits/s throttle=off speed=1.11x22:47:50.191 frame= 139 fps= 33 q=28.0 size= 1704kB time=00:00:05.83 bitrate=2908.4kbits/s throttle=off speed=1.16x22:47:50.735 frame= 154 fps= 33 q=28.0 size= 2022kB time=00:00:06.45 bitrate=3054.4kbits/s throttle=off speed=1.15x22:47:51.102 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:47:51.104 SegmentComplete=video:0 Index=1 Start=3.003000 End=6.006000 Duration=3.003000 offset_pts=0 start_pts=3003000 Frames=72 filename=E4D7B4_1.ts22:47:51.104 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_2.ts.tmp' for writing22:47:51.304 frame= 169 fps= 32 q=28.0 size= 2441kB time=00:00:06.98 bitrate=3359.3kbits/s throttle=off speed=1.13x22:47:51.793 frame= 184 fps= 32 q=28.0 size= 2694kB time=00:00:07.60 bitrate=3355.7kbits/s throttle=off speed=1.14x22:47:52.333 frame= 199 fps= 31 q=28.0 size= 3108kB time=00:00:08.37 bitrate=3467.1kbits/s throttle=off speed=1.16x22:47:52.840 frame= 214 fps= 31 q=28.0 size= 3378kB time=00:00:08.95 bitrate=3494.0kbits/s throttle=off speed=1.16x22:47:53.347 frame= 228 fps= 31 q=28.0 size= 3807kB time=00:00:09.48 bitrate=3691.3kbits/s throttle=off speed=1.15x22:47:53.787 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:47:53.788 SegmentComplete=video:0 Index=2 Start=6.006000 End=9.009000 Duration=3.003000 offset_pts=0 start_pts=6006000 Frames=72 filename=E4D7B4_2.ts22:47:53.788 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_3.ts.tmp' for writing22:47:53.848 frame= 239 fps= 31 q=28.0 size= 4278kB time=00:00:09.91 bitrate=3946.7kbits/s throttle=off speed=1.13x22:47:54.369 frame= 256 fps= 31 q=28.0 size= 4761kB time=00:00:10.82 bitrate=3982.8kbits/s throttle=off speed=1.17x22:47:54.884 frame= 274 fps= 31 q=28.0 size= 5089kB time=00:00:11.40 bitrate=4021.0kbits/s throttle=off speed=1.17x22:47:55.383 frame= 289 fps= 31 q=28.0 size= 5143kB time=00:00:12.02 bitrate=3832.9kbits/s throttle=off speed=1.17x22:47:55.910 frame= 303 fps= 31 q=28.0 size= 5367kB time=00:00:12.55 bitrate=3816.8kbits/s throttle=off speed=1.17x22:47:55.919 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:47:55.920 SegmentComplete=video:1 Index=0 Start=0.000000 End=2.877875 Duration=2.877875 offset_pts=0 start_pts=0 Frames=69 filename=E4D7B4_s5_0.vtt22:47:55.920 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_1.vtt.tmp' for writing22:47:56.153 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:47:56.154 SegmentComplete=video:0 Index=3 Start=9.009000 End=12.012000 Duration=3.003000 offset_pts=0 start_pts=9009000 Frames=72 filename=E4D7B4_3.ts22:47:56.155 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_4.ts.tmp' for writing22:47:56.492 frame= 316 fps= 30 q=28.0 size= 5793kB time=00:00:13.32 bitrate=3862.3kbits/s throttle=off speed=1.18x22:47:57.015 frame= 327 fps= 30 q=28.0 size= 6309kB time=00:00:13.70 bitrate=4078.5kbits/s throttle=off speed=1.15x22:47:57.497 frame= 339 fps= 30 q=28.0 size= 6887kB time=00:00:14.23 bitrate=4274.3kbits/s throttle=off speed=1.15x22:47:58.000 frame= 349 fps= 29 q=28.0 size= 7361kB time=00:00:14.64 bitrate=4431.4kbits/s throttle=off speed=1.13x22:47:58.547 frame= 359 fps= 29 q=28.0 size= 7996kB time=00:00:14.90 bitrate=4722.2kbits/s throttle=off speed=1.11x22:47:59.143 frame= 371 fps= 28 q=28.0 size= 8596kB time=00:00:15.62 bitrate=4825.8kbits/s throttle=off speed=1.11x22:47:59.381 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:47:59.382 SegmentComplete=video:1 Index=1 Start=3.003000 End=5.922583 Duration=2.919583 offset_pts=0 start_pts=3003000 Frames=73 filename=E4D7B4_s5_1.vtt22:47:59.383 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_2.vtt.tmp' for writing22:47:59.664 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:47:59.665 SegmentComplete=video:0 Index=4 Start=12.012000 End=15.015000 Duration=3.003000 offset_pts=0 start_pts=12012000 Frames=72 filename=E4D7B4_4.ts22:47:59.665 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_5.ts.tmp' for writing22:47:59.702 frame= 382 fps= 28 q=28.0 size= 9451kB time=00:00:16.00 bitrate=5169.9kbits/s throttle=off speed= 1.1x22:48:00.202 frame= 392 fps= 28 q=28.0 size= 9910kB time=00:00:16.39 bitrate=5285.2kbits/s throttle=off speed=1.08x22:48:00.705 frame= 404 fps= 28 q=28.0 size= 10541kB time=00:00:16.77 bitrate=5485.0kbits/s throttle=off speed=1.07x22:48:01.194 frame= 414 fps= 27 q=28.0 size= 11017kB time=00:00:17.32 bitrate=5538.5kbits/s throttle=off speed=1.07x22:48:01.876 frame= 427 fps= 27 q=28.0 size= 11713kB time=00:00:17.92 bitrate=5679.1kbits/s throttle=off speed=1.07x22:48:02.403 frame= 439 fps= 27 q=28.0 size= 12324kB time=00:00:18.36 bitrate=5826.4kbits/s throttle=off speed=1.06x22:48:02.897 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:48:02.898 SegmentComplete=video:1 Index=2 Start=6.006000 End=9.009000 Duration=3.003000 offset_pts=0 start_pts=6006000 Frames=74 filename=E4D7B4_s5_2.vtt22:48:02.898 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_3.vtt.tmp' for writing22:48:02.923 frame= 452 fps= 27 q=29.0 size= 12875kB time=00:00:18.88 bitrate=5906.9kbits/s throttle=off speed=1.06x22:48:03.069 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:48:03.070 SegmentComplete=video:0 Index=5 Start=15.015000 End=18.018000 Duration=3.003000 offset_pts=0 start_pts=15015000 Frames=72 filename=E4D7B4_5.ts22:48:03.070 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_6.ts.tmp' for writing22:48:03.531 frame= 462 fps= 26 q=30.0 size= 13629kB time=00:00:19.27 bitrate=6121.1kbits/s throttle=off speed=1.04x22:48:04.133 frame= 474 fps= 26 q=29.0 size= 14167kB time=00:00:19.65 bitrate=6231.3kbits/s throttle=off speed=1.04x22:48:04.556 frame= 484 fps= 26 q=28.0 size= 14558kB time=00:00:20.04 bitrate=6274.0kbits/s throttle=off speed=1.03x22:48:05.089 frame= 496 fps= 26 q=29.0 size= 15160kB time=00:00:20.80 bitrate=6280.0kbits/s throttle=off speed=1.04x22:48:05.623 frame= 508 fps= 26 q=28.0 size= 15619kB time=00:00:21.19 bitrate=6346.8kbits/s throttle=off speed=1.03x22:48:06.131 frame= 519 fps= 26 q=28.0 size= 16022kB time=00:00:21.57 bitrate=6388.9kbits/s throttle=off speed=1.02x22:48:06.209 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:48:06.210 SegmentComplete=video:1 Index=3 Start=9.134125 End=12.012000 Duration=2.877875 offset_pts=0 start_pts=9134125 Frames=72 filename=E4D7B4_s5_3.vtt22:48:06.210 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_4.vtt.tmp' for writing22:48:06.369 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:48:06.372 SegmentComplete=video:0 Index=6 Start=18.018000 End=21.021000 Duration=3.003000 offset_pts=0 start_pts=18018000 Frames=72 filename=E4D7B4_6.ts22:48:06.373 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_7.ts.tmp' for writing22:48:06.679 frame= 531 fps= 26 q=28.0 size= 16828kB time=00:00:22.15 bitrate=6527.1kbits/s throttle=off speed=1.02x22:48:07.176 frame= 544 fps= 26 q=28.0 size= 17368kB time=00:00:22.58 bitrate=6601.7kbits/s throttle=off speed=1.02x22:48:07.690 frame= 557 fps= 26 q=28.0 size= 17869kB time=00:00:23.30 bitrate=6572.5kbits/s throttle=off speed=1.03x22:48:08.263 frame= 568 fps= 26 q=28.0 size= 18232kB time=00:00:23.68 bitrate=6592.3kbits/s throttle=off speed=1.02x22:48:08.783 frame= 579 fps= 25 q=28.0 size= 18556kB time=00:00:24.07 bitrate=6597.8kbits/s throttle=off speed=1.01x22:48:09.384 frame= 591 fps= 25 q=28.0 size= 19009kB time=00:00:24.64 bitrate=6593.8kbits/s throttle=off speed=1.01x22:48:09.438 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:48:09.439 SegmentComplete=video:1 Index=4 Start=12.095417 End=14.973292 Duration=2.877875 offset_pts=0 start_pts=12095417 Frames=71 filename=E4D7B4_s5_4.vtt22:48:09.439 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_5.vtt.tmp' for writing22:48:09.688 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:48:09.689 SegmentComplete=video:0 Index=7 Start=21.021000 End=24.024000 Duration=3.003000 offset_pts=0 start_pts=21021000 Frames=72 filename=E4D7B4_7.ts22:48:09.689 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_8.ts.tmp' for writing22:48:10.050 frame= 603 fps= 25 q=28.0 size= 19658kB time=00:00:25.22 bitrate=6656.8kbits/s throttle=off speed=1.01x22:48:10.423 frame= 611 fps= 25 q=28.0 size= 19984kB time=00:00:25.60 bitrate=6661.4kbits/s throttle=off speed=1.01x22:48:10.971 frame= 622 fps= 25 q=28.0 size= 20414kB time=00:00:25.99 bitrate=6700.1kbits/s throttle=off speed= 1x22:48:11.550 frame= 633 fps= 25 q=28.0 size= 21282kB time=00:00:26.37 bitrate=6879.0kbits/s throttle=off speed=0.994x22:48:12.062 frame= 643 fps= 25 q=28.0 size= 21861kB time=00:00:26.76 bitrate=6960.6kbits/s throttle=off speed=0.988x22:48:12.631 frame= 654 fps= 25 q=28.0 size= 22450kB time=00:00:27.19 bitrate=7030.1kbits/s throttle=off speed=0.983x22:48:13.140 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5.m3u8.tmp' for writing22:48:13.141 SegmentComplete=video:1 Index=5 Start=15.181833 End=17.976292 Duration=2.794458 offset_pts=0 start_pts=15181833 Frames=72 filename=E4D7B4_s5_5.vtt22:48:13.141 [segment @ 0x1025f80] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_s5_6.vtt.tmp' for writing22:48:13.150 frame= 666 fps= 25 q=30.0 size= 23026kB time=00:00:27.91 bitrate=7017.3kbits/s throttle=off speed=0.991x22:48:13.265 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4.m3u8.tmp' for writing22:48:13.266 SegmentComplete=video:0 Index=8 Start=24.024000 End=27.027000 Duration=3.003000 offset_pts=0 start_pts=24024000 Frames=72 filename=E4D7B4_8.ts22:48:13.266 [segment @ 0x1101240] Opening '/var/packages/EmbyServer/target/var/transcoding-temp/E4D7B4_9. Emby Log.txt Edited April 9, 2020 by MateyTate
Luke 42242 Posted April 8, 2020 Posted April 8, 2020 Hi, this ffmpeg log is from safari in the web app. I thought you said you were playing on the Shield?
MateyTate 16 Posted April 9, 2020 Author Posted April 9, 2020 (edited) Hi Luke - you are correct, I didn't realise you could send the logs direct from the Shield Emby app, I have done that now straight after the app crashed so you should have them. Edited April 9, 2020 by MateyTate
ebr 16335 Posted April 9, 2020 Posted April 9, 2020 Hi. If you look at the media details for this item in the web app (or the Shield at the bottom) do both of your audio tracks show a channel count or is it missing from one of them?
ebr 16335 Posted April 9, 2020 Posted April 9, 2020 Please confirm if that is what you find. If so, this should be solved with the next beta release of the app and may be solvable by you by refreshing the item in question (if ffprobe can properly discover the track count).
MateyTate 16 Posted April 9, 2020 Author Posted April 9, 2020 See attached. Looks OK to me... what do you think? Did the logs indicate the reason why playing that 5.1 AC3 track crashes the app?
Solution MateyTate 16 Posted April 9, 2020 Author Solution Posted April 9, 2020 So, its definitely to do with the way iFlicks 3 on the Mac is re-encoding the audio. The original 5.1 AAC track is being converted to 5.1 AC3 and the video passed through. If I try to play it, it crashes the Emby Shield app (Plex will play it, albeit with a stutter at the start & the Apple TV Emby app plays it no problem). I took my original Blu-ray rip and this time converted the audio to AC3 and passed the video through using Box4 in Windows and it works perfectly now. I don't know, but I guess I can live with it. 1
