Matt19 0 Posted April 8, 2020 Posted April 8, 2020 Hi all First time forum user here so please be patient with me. I am trying to move to emby from wmc. I have have tuned the channels but it takes some time for the channel to come up or dosent at all. I have seen some posts about fixing this and needing to provide some data to fix it but i am not that savie to find it. Can someone please help Thanks Matt
ebr 16337 Posted April 8, 2020 Posted April 8, 2020 Hi. We need to look at exactly how you have setup live TV, what kind of tuner, what app you are using to watch and exactly what is happening when you do. Thanks. How to Report a Problem
Matt19 0 Posted April 8, 2020 Author Posted April 8, 2020 Hey ebr I have a hauppauge quad tv tuner. No app just using the emby web client. The app on my phone seams to work ok. When i choose a channel it either takes 10 seconds plus for the channel to come on or doesn't at all and frezzes the program.
ebr 16337 Posted April 8, 2020 Posted April 8, 2020 Can we please see an ffmpeg log from when it doesn't work well? @@softworkz
Matt19 0 Posted April 9, 2020 Author Posted April 9, 2020 Hey EBR is this the log you are after? log.txt
Matt19 0 Posted April 9, 2020 Author Posted April 9, 2020 10:31:13.778 ffmpeg version 4.3.0-emby_2020_02_24-g5abbb1430d+4891 Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC10:31:13.779 built with gcc 9.2.0 (Rev2, Built by MSYS2 project)10:31:13.779 Execution Date: 2020-04-09 10:31:1310:31:28.546 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.546 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.547 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] decode_slice_header error10:31:28.547 [h264 @ 00000000003f5e40] no frame!10:31:28.547 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.547 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.547 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] decode_slice_header error10:31:28.547 [h264 @ 00000000003f5e40] no frame!10:31:28.547 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.547 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] SPS unavailable in decode_picture_timing10:31:28.547 [h264 @ 00000000003f5e40] non-existing PPS 0 referenced10:31:28.547 [h264 @ 00000000003f5e40] decode_slice_header error10:31:28.547 [h264 @ 00000000003f5e40] no frame!
denz 501 Posted April 9, 2020 Posted April 9, 2020 (edited) You need to attach the whole ffmpeg log not just a snippet. Edited April 9, 2020 by denz
Luke 42244 Posted April 9, 2020 Posted April 9, 2020 @@Matt19 can you please attach a complete log file example? thanks.
Matt19 0 Posted April 9, 2020 Author Posted April 9, 2020 (edited) 2020-04-09 10:32:28.447Emby Server version: 4.4.2.0Operating system: Microsoft Windows NT 6.1.7601 Service Pack 1Command Line: C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\system\EmbyServer.dllApp: Emby Web 4.4.2.0Chromehttp://localhost:8096/emby/videos/11794/live.m3u8?DeviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgNi4xOyBXaW42NDsgeDY0KSBBcHBsZVdlYktpdC81MzcuMzYgKEtIVE1MLCBsaWtlIEdlY2tvKSBDaHJvbWUvODAuMC4zOTg3LjEyMiBTYWZhcmkvNTM3LjM2fDE1ODMxMzgzMDE2NDE1&MediaSourceId=native_ad10c1a8c4d37bc8c814a86a2fc885e8_486333306647387e8a4385359556b302&PlaySessionId=625fbc712a7843fbbd1163368917e127&api_key=85f8d7013ae04e75b34f9a0602a552b9&LiveStreamId=06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_ad10c1a8c4d37bc8c814a86a2fc885e8_486333306647387e8a4385359556b302&VideoCodec=h264&AudioCodec=mp3,aac&VideoBitrate=139808000&AudioBitrate=192000&AudioStreamIndex=-1&TranscodingMaxAudioChannels=2&SegmentContainer=ts&MinSegments=1&BreakOnNonKeyFrames=True&ManifestSubtitles=vtt&h264-profile=high,main,baseline,constrainedbaseline,high10&h264-level=52&TranscodeReasons=ContainerNotSupported{"Protocol":"Http","Id":"native_ad10c1a8c4d37bc8c814a86a2fc885e8_486333306647387e8a4385359556b302","Path":"http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5f90c5b065fc4dc99e363ecfb357b9f7/stream.ts","Type":"Default","Container":"mpegts","IsRemote":false,"ContainerStartTimeTicks":759690732330,"SupportsTranscoding":true,"SupportsDirectStream":true,"SupportsDirectPlay":false,"IsInfiniteStream":true,"RequiresOpening":true,"RequiresClosing":true,"LiveStreamId":"06044cf0e6f93cdae5f285c9ecfaaeb4_01413a525b3a9622ce6fdf19f7dde354_native_ad10c1a8c4d37bc8c814a86a2fc885e8_486333306647387e8a4385359556b302","RequiresLooping":false,"SupportsProbing":false,"MediaStreams":[{"Codec":"h264","ColorTransfer":"bt709","ColorPrimaries":"bt709","ColorSpace":"bt709","StreamStartTimeTicks":759696732330,"TimeBase":"1/90000","CodecTimeBase":"1/50","VideoRange":"SDR","DisplayTitle":"1080iH264","NalLengthSize":"0","IsInterlaced":true,"BitRate":20000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":1080,"Width":1920,"AverageFrameRate":25,"RealFrameRate":25,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":40,"IsAnamorphic":false},{"Codec":"mp2","StreamStartTimeTicks":759691372330,"TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"MP2 stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":192000,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":20192000,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false} >>>>>> User policy for Media Centre PCEnablePlaybackRemuxing: TrueEnableVideoPlaybackTranscoding: TrueEnableAudioPlaybackTranscoding: True>>>>>> Processing PlanInfo Name CanDoInHardware WillDoInHardware ReasonInfo Copy video stream >> False False Software CodecInfo VideoInput >> False False Not a hardware decoderInfo VideoOutput >> False False Not a hardware encoderInfo Copy video stream >> False False Software Codec>>>>>> Projected Processing FormatsInfo Previous HW-Context Format SW-Format NextInfo h264 >> - yuv420p yuv420p >>>>>>> Legacy CommandC:\Users\Media Centre PC\AppData\Roaming\Emby-Server\system\ffmpeg.exe -analyzeduration 3000000 -fflags +discardcorruptts+fillwallclockdts -f mpegts -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5f90c5b065fc4dc99e363ecfb357b9f7/stream.ts"-threads 0 -sn -c:v:0 copy -copyts -vsync -1 -codec:a:0 libmp3lame -disposition:a:0 default -ac:a:0 2 -ab:a:0 192000 -f segment -max_delay 5000000 -avoid_negative_ts disabled -map_metadata -1 -map_chapters -1 -start_at_zero -segment_time 3 -individual_header_trailer 0 -segment_format mpegts -segment_write_temp 1 -segment_list_type m3u8 -segment_start_number 0 -segment_list "C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8" -y "C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_%d.ts" >>>>> Actual CommandC:\Users\Media Centre PC\AppData\Roaming\Emby-Server\system\ffmpeg.exe -loglevel +timing -y -print_graphs_file "C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\logs\ffmpeg-remux-f5da44c8-db9a-4e51-9b52-a6682ca40b2f_1graph.txt" -copyts -start_at_zero -analyzeduration 3000000 -f mpegts -c:v:0 h264 -i "http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5f90c5b065fc4dc99e363ecfb357b9f7/stream.ts"-map v:0 -map a:0 -sn -c:v:0 copy -c:a:0 libmp3lame -ab:a:0 192000 -ac:a:0 2 -disposition:a:0 default -fflags +discardcorruptts+fillwallclockdts -max_delay 5000000 -avoid_negative_ts disabled -f segment -map_metadata -1 -map_chapters -1 -segment_format mpegts -segment_list "C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8" -segment_list_type m3u8 -segment_time 3 -segment_list_entry_prefix hls/2B8C08/ -segment_start_number 0 -individual_header_trailer 0 -write_header_trailer 0 -segment_write_temp 1 "C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_%d.ts" 10:32:28.463 ffmpeg version 4.3.0-emby_2020_02_24-g5abbb1430d+4891 Copyright © 2000-2019 the FFmpeg developers and softworkz for Emby LLC10:32:28.464 built with gcc 9.2.0 (Rev2, Built by MSYS2 project)10:32:28.464 Execution Date: 2020-04-09 10:32:2810:32:28.613 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.613 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.614 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.614 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.614 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.614 [h264 @ 00000000003c0b00] no frame!10:32:28.614 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.614 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.614 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.614 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.614 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.614 [h264 @ 00000000003c0b00] no frame!10:32:28.614 [mpegts @ 00000000003b7dc0] PES packet size mismatch10:32:28.615 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.615 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.615 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.615 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.615 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.615 [h264 @ 00000000003c0b00] no frame!10:32:28.615 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.615 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.616 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.616 [h264 @ 00000000003c0b00] no frame!10:32:28.616 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.616 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.616 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.616 [h264 @ 00000000003c0b00] no frame!10:32:28.616 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.616 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.616 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.616 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.616 [h264 @ 00000000003c0b00] no frame!10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.617 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.617 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.617 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.617 [h264 @ 00000000003c0b00] no frame!10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.617 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.617 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.617 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.617 [h264 @ 00000000003c0b00] no frame!10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.617 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.617 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.618 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.618 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.618 [h264 @ 00000000003c0b00] no frame!10:32:28.618 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.618 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.618 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.618 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.618 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.618 [h264 @ 00000000003c0b00] no frame!10:32:28.618 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.618 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.618 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.618 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.618 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.619 [h264 @ 00000000003c0b00] no frame!10:32:28.619 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.619 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.619 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.619 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.619 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.619 [h264 @ 00000000003c0b00] no frame!10:32:28.631 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.632 [h264 @ 00000000003c0b00] no frame!10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.632 [h264 @ 00000000003c0b00] no frame!10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.632 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.632 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.632 [h264 @ 00000000003c0b00] no frame!10:32:28.632 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.633 [h264 @ 00000000003c0b00] no frame!10:32:28.633 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.633 [h264 @ 00000000003c0b00] no frame!10:32:28.633 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.633 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.633 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.633 [h264 @ 00000000003c0b00] no frame!10:32:28.634 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.634 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.634 [h264 @ 00000000003c0b00] SPS unavailable in decode_picture_timing10:32:28.634 [h264 @ 00000000003c0b00] non-existing PPS 0 referenced10:32:28.634 [h264 @ 00000000003c0b00] decode_slice_header error10:32:28.634 [h264 @ 00000000003c0b00] no frame!10:32:28.668 [h264 @ 00000000003c0b00] mmco: unref short failureLast message repeated 1 times10:32:28.927 [mpegts @ 00000000003b7dc0] Could not find codec parameters for stream 5 (Unknown: none ([5][0][0][0] / 0x0005)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options10:32:28.927 [mpegts @ 00000000003b7dc0] Could not find codec parameters for stream 6 (Unknown: none ([11][0][0][0] / 0x000B)): unknown codecConsider increasing the value for the 'analyzeduration' and 'probesize' options10:32:28.930 Input #0, mpegts, from 'http://127.0.0.1:8096/LiveTv/LiveStreamFiles/5f90c5b065fc4dc99e363ecfb357b9f7/stream.ts':10:32:28.931 Duration: N/A, start: 75969.073233, bitrate: N/A10:32:28.931 Program 77410:32:28.931 Stream #0:1[0x66]: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], Level 40, 25 fps, 25 tbr, 90k tbn, 50 tbc, Start-Time 75969.673s10:32:28.931 Stream #0:2[0x67](eng): Audio: mp2 ([3][0][0][0] / 0x0003), 48000 Hz, stereo, fltp, 192 kb/s, Start-Time 75969.137s10:32:28.931 Stream #0:3[0x68](aus): Audio: aac_latm (HE-AAC) ([17][0][0][0] / 0x0011), 48000 Hz, stereo, fltp, Start-Time 75969.335s (visual impaired) (descriptions)10:32:28.931 Stream #0:4[0x2b](eng): Subtitle: dvb_teletext ([6][0][0][0] / 0x0006), Start-Time 75969.073s10:32:28.931 Stream #0:5[0x1e5e]: Unknown: none ([5][0][0][0] / 0x0005)10:32:28.931 Stream #0:6[0x1b58]: Unknown: none ([11][0][0][0] / 0x000B)10:32:28.931 No Program10:32:28.931 Stream #0:0[0x12]: Data: epg10:32:28.932 Stream mapping:10:32:28.932 Stream #0:1 -> #0:0 (copy)10:32:28.933 Stream #0:2 -> #0:1 (mp2 (native) -> mp3 (libmp3lame))10:32:28.933 Press [q] to stop, [?] for help10:32:28.938 Output #0, segment, to 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_%d.ts':10:32:28.938 Metadata:10:32:28.938 encoder : Lavf58.35.10010:32:28.938 Stream #0:0: Video: h264 (High) ([27][0][0][0] / 0x001B), yuv420p(tv, bt709, top first), 1920x1080 [sAR 1:1 DAR 16:9], q=2-31, Level 40, 25 fps, 25 tbr, 90k tbn, 25 tbc10:32:28.938 Stream #0:1: Audio: mp3 (libmp3lame), 48000 Hz, stereo, s16p, 192 kb/s (default)10:32:28.938 Metadata:10:32:28.938 encoder : Lavc58.62.100 libmp3lame10:32:28.939 [mp2 @ 00000000003f5a40] Header missing10:32:28.940 Error while decoding stream #0:2: Invalid data found when processing input10:32:29.007 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:29.026 SegmentComplete=video:0 Index=0 Start=0.000000 End=3.296000 Duration=3.296000 offset_pts=0 start_pts=0 Frames=48 filename=hls/2B8C08/2B8C08_0.ts10:32:29.027 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_1.ts.tmp' for writing10:32:29.106 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:29.123 SegmentComplete=video:0 Index=1 Start=3.576000 End=6.176000 Duration=2.600000 offset_pts=0 start_pts=3576000 Frames=72 filename=hls/2B8C08/2B8C08_1.ts10:32:29.123 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_2.ts.tmp' for writing10:32:29.214 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:29.235 SegmentComplete=video:0 Index=2 Start=6.456000 End=9.056000 Duration=2.600000 offset_pts=0 start_pts=6456000 Frames=72 filename=hls/2B8C08/2B8C08_2.ts10:32:29.236 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_3.ts.tmp' for writing10:32:29.448 frame= 215 fps=0.0 q=-1.0 size= 4497kB time=00:00:09.81 bitrate=N/A throttle=off speed= 0x10:32:29.994 frame= 227 fps=214 q=-1.0 size= 4809kB time=00:00:10.29 bitrate=82075.4kbits/s throttle=off speed=0.452x10:32:30.542 frame= 239 fps=149 q=-1.0 size= 4991kB time=00:00:10.77 bitrate=42592.5kbits/s throttle=off speed=0.597x10:32:31.089 frame= 255 fps=118 q=-1.0 size= 5305kB time=00:00:11.41 bitrate=27161.7kbits/s throttle=off speed=0.742x10:32:31.634 frame= 264 fps= 98 q=-1.0 size= 5467kB time=00:00:11.77 bitrate=22849.8kbits/s throttle=off speed=0.726x10:32:32.074 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:32.086 SegmentComplete=video:0 Index=3 Start=9.336000 End=11.936000 Duration=2.600000 offset_pts=0 start_pts=9336000 Frames=72 filename=hls/2B8C08/2B8C08_3.ts10:32:32.086 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_4.ts.tmp' for writing10:32:32.181 frame= 281 fps= 87 q=-1.0 size= 5839kB time=00:00:12.45 bitrate=18118.1kbits/s throttle=off speed=0.813x10:32:32.834 frame= 297 fps= 78 q=-1.0 size= 6143kB time=00:00:13.09 bitrate=15343.4kbits/s throttle=off speed=0.865x10:32:33.270 frame= 310 fps= 71 q=-1.0 size= 6368kB time=00:00:13.61 bitrate=13728.6kbits/s throttle=off speed=0.876x10:32:33.821 frame= 321 fps= 66 q=-1.0 size= 6634kB time=00:00:14.05 bitrate=12818.2kbits/s throttle=off speed=0.868x10:32:34.366 frame= 335 fps= 62 q=-1.0 size= 6847kB time=00:00:14.61 bitrate=11686.4kbits/s throttle=off speed=0.884x10:32:34.910 frame= 351 fps= 59 q=-1.0 size= 7177kB time=00:00:15.25 bitrate=10807.7kbits/s throttle=off speed=0.91x10:32:35.023 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:35.049 SegmentComplete=video:0 Index=4 Start=12.216000 End=14.816000 Duration=2.600000 offset_pts=0 start_pts=12216000 Frames=72 filename=hls/2B8C08/2B8C08_4.ts10:32:35.050 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_5.ts.tmp' for writing10:32:35.520 frame= 362 fps= 55 q=-1.0 size= 7489kB time=00:00:15.69 bitrate=10434.1kbits/s throttle=off speed=0.893x10:32:36.062 frame= 380 fps= 53 q=-1.0 size= 7763kB time=00:00:16.41 bitrate=9635.9kbits/s throttle=off speed=0.926x10:32:36.612 frame= 387 fps= 50 q=-1.0 size= 7980kB time=00:00:16.69 bitrate=9501.2kbits/s throttle=off speed=0.896x10:32:37.154 frame= 407 fps= 50 q=-1.0 size= 8244kB time=00:00:17.49 bitrate=8793.3kbits/s throttle=off speed=0.934x10:32:37.703 frame= 418 fps= 48 q=-1.0 size= 8508kB time=00:00:17.93 bitrate=8583.3kbits/s throttle=off speed=0.926x10:32:38.246 frame= 431 fps= 46 q=-1.0 size= 8705kB time=00:00:18.45 bitrate=8253.8kbits/s throttle=off speed=0.928x10:32:38.904 frame= 449 fps= 46 q=-1.0 size= 9064kB time=00:00:19.17 bitrate=7933.2kbits/s throttle=off speed=0.949x10:32:38.905 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:38.914 SegmentComplete=video:0 Index=5 Start=15.096000 End=18.656000 Duration=3.560000 offset_pts=0 start_pts=15096000 Frames=96 filename=hls/2B8C08/2B8C08_5.ts10:32:38.914 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_6.ts.tmp' for writing10:32:39.357 frame= 458 fps= 44 q=-1.0 size= 9317kB time=00:00:19.53 bitrate=7852.5kbits/s throttle=off speed=0.932x10:32:39.933 frame= 474 fps= 43 q=-1.0 size= 9621kB time=00:00:20.17 bitrate=7607.7kbits/s throttle=off speed=0.942x10:32:40.482 frame= 488 fps= 42 q=-1.0 size= 9890kB time=00:00:20.73 bitrate=7419.4kbits/s throttle=off speed=0.946x10:32:41.043 frame= 503 fps= 42 q=-1.0 size= 10203kB time=00:00:21.33 bitrate=7255.6kbits/s throttle=off speed=0.951x10:32:41.589 frame= 519 fps= 41 q=-1.0 size= 10542kB time=00:00:21.97 bitrate=7102.2kbits/s throttle=off speed=0.961x10:32:41.698 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:41.711 SegmentComplete=video:0 Index=6 Start=18.936000 End=21.536000 Duration=2.600000 offset_pts=0 start_pts=18936000 Frames=72 filename=hls/2B8C08/2B8C08_6.ts10:32:41.711 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_7.ts.tmp' for writing10:32:42.138 frame= 527 fps= 40 q=-1.0 size= 10711kB time=00:00:22.29 bitrate=7030.7kbits/s throttle=off speed=0.945x10:32:42.788 frame= 544 fps= 40 q=-1.0 size= 11027kB time=00:00:22.97 bitrate=6864.0kbits/s throttle=off speed=0.957x10:32:43.227 frame= 551 fps= 39 q=-1.0 size= 11164kB time=00:00:23.25 bitrate=6804.6kbits/s throttle=off speed=0.94x10:32:43.770 frame= 570 fps= 38 q=-1.0 size= 11578kB time=00:00:24.01 bitrate=6679.4kbits/s throttle=off speed=0.957x10:32:44.319 frame= 584 fps= 38 q=-1.0 size= 11842kB time=00:00:24.57 bitrate=6572.7kbits/s throttle=off speed=0.959x10:32:44.645 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:44.660 SegmentComplete=video:0 Index=7 Start=21.816000 End=24.416000 Duration=2.600000 offset_pts=0 start_pts=21816000 Frames=72 filename=hls/2B8C08/2B8C08_7.ts10:32:44.660 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_8.ts.tmp' for writing10:32:44.866 frame= 599 fps= 38 q=-1.0 size= 12136kB time=00:00:25.17 bitrate=6472.4kbits/s throttle=off speed=0.964x10:32:45.407 frame= 610 fps= 37 q=-1.0 size= 12465kB time=00:00:25.61 bitrate=6462.7kbits/s throttle=off speed=0.959x10:32:45.959 frame= 623 fps= 37 q=-1.0 size= 12665kB time=00:00:26.13 bitrate=6357.4kbits/s throttle=off speed=0.959x10:32:46.536 frame= 641 fps= 36 q=-1.0 size= 13076kB time=00:00:26.85 bitrate=6286.4kbits/s throttle=off speed=0.968x10:32:47.075 frame= 654 fps= 36 q=-1.0 size= 13370kB time=00:00:27.37 bitrate=6237.2kbits/s throttle=off speed=0.968x10:32:47.521 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:47.541 SegmentComplete=video:0 Index=8 Start=24.696000 End=27.296000 Duration=2.600000 offset_pts=0 start_pts=24696000 Frames=72 filename=hls/2B8C08/2B8C08_8.ts10:32:47.541 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_9.ts.tmp' for writing10:32:47.655 frame= 670 fps= 36 q=-1.0 size= 13616kB time=00:00:28.01 bitrate=6128.5kbits/s throttle=off speed=0.972x10:32:48.215 frame= 681 fps= 35 q=-1.0 size= 13864kB time=00:00:28.45 bitrate=6092.9kbits/s throttle=off speed=0.967x10:32:48.767 frame= 695 fps= 35 q=-1.0 size= 14094kB time=00:00:29.01 bitrate=6013.3kbits/s throttle=off speed=0.968x10:32:49.308 frame= 711 fps= 35 q=-1.0 size= 14422kB time=00:00:29.65 bitrate=5954.9kbits/s throttle=off speed=0.974x10:32:49.872 frame= 722 fps= 34 q=-1.0 size= 14714kB time=00:00:30.09 bitrate=5943.7kbits/s throttle=off speed=0.969x10:32:50.340 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:50.349 SegmentComplete=video:0 Index=9 Start=27.576000 End=30.176000 Duration=2.600000 offset_pts=0 start_pts=27576000 Frames=72 filename=hls/2B8C08/2B8C08_9.ts10:32:50.349 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_10.ts.tmp' for writing10:32:50.452 frame= 733 fps= 34 q=-1.0 size= 14975kB time=00:00:30.53 bitrate=5920.5kbits/s throttle=off speed=0.963x10:32:51.011 frame= 752 fps= 34 q=-1.0 size= 15242kB time=00:00:31.29 bitrate=5812.9kbits/s throttle=off speed=0.973x10:32:51.589 frame= 767 fps= 34 q=-1.0 size= 15530kB time=00:00:31.89 bitrate=5761.8kbits/s throttle=off speed=0.975x10:32:52.133 frame= 782 fps= 34 q=-1.0 size= 15761kB time=00:00:32.49 bitrate=5692.7kbits/s throttle=off speed=0.978x10:32:52.677 frame= 797 fps= 34 q=-1.0 size= 16022kB time=00:00:33.09 bitrate=5637.9kbits/s throttle=off speed=0.98x10:32:53.236 frame= 806 fps= 33 q=-1.0 size= 16165kB time=00:00:33.45 bitrate=5601.5kbits/s throttle=off speed=0.973x10:32:53.791 frame= 823 fps= 33 q=-1.0 size= 16440kB time=00:00:34.13 bitrate=5537.7kbits/s throttle=off speed=0.978x10:32:53.797 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:53.851 SegmentComplete=video:0 Index=10 Start=30.456000 End=33.656000 Duration=3.200000 offset_pts=0 start_pts=30456000 Frames=87 filename=hls/2B8C08/2B8C08_10.ts10:32:53.851 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_11.ts.tmp' for writing10:32:54.332 frame= 830 fps= 33 q=-1.0 size= 16547kB time=00:00:34.41 bitrate=5510.3kbits/s throttle=off speed=0.969x10:32:54.907 frame= 853 fps= 33 q=-1.0 size= 16885kB time=00:00:35.33 bitrate=5420.1kbits/s throttle=off speed=0.983x10:32:55.474 frame= 862 fps= 32 q=-1.0 size= 17045kB time=00:00:35.69 bitrate=5395.3kbits/s throttle=off speed=0.975x10:32:56.019 frame= 878 fps= 32 q=-1.0 size= 17215kB time=00:00:36.33 bitrate=5317.7kbits/s throttle=off speed=0.979x10:32:56.563 frame= 892 fps= 32 q=-1.0 size= 17414kB time=00:00:36.89 bitrate=5267.9kbits/s throttle=off speed=0.98x10:32:56.693 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:56.722 SegmentComplete=video:0 Index=11 Start=33.936000 End=36.536000 Duration=2.600000 offset_pts=0 start_pts=33936000 Frames=72 filename=hls/2B8C08/2B8C08_11.ts10:32:56.722 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_12.ts.tmp' for writing10:32:57.139 frame= 902 fps= 32 q=-1.0 size= 17610kB time=00:00:37.29 bitrate=5249.8kbits/s throttle=off speed=0.974x10:32:57.735 frame= 918 fps= 32 q=-1.0 size= 17814kB time=00:00:37.93 bitrate=5189.7kbits/s throttle=off speed=0.976x10:32:58.298 frame= 930 fps= 32 q=-1.0 size= 18060kB time=00:00:38.41 bitrate=5173.1kbits/s throttle=off speed=0.974x10:32:58.889 frame= 950 fps= 32 q=-1.0 size= 18322kB time=00:00:39.21 bitrate=5105.2kbits/s throttle=off speed=0.981x10:32:59.447 frame= 964 fps= 32 q=-1.0 size= 18573kB time=00:00:39.77 bitrate=5078.4kbits/s throttle=off speed=0.982x10:32:59.562 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:32:59.582 SegmentComplete=video:0 Index=12 Start=36.816000 End=39.416000 Duration=2.600000 offset_pts=0 start_pts=36816000 Frames=72 filename=hls/2B8C08/2B8C08_12.ts10:32:59.582 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_13.ts.tmp' for writing10:33:00.014 frame= 974 fps= 31 q=-1.0 size= 18729kB time=00:00:40.17 bitrate=5053.5kbits/s throttle=off speed=0.977x10:33:00.578 frame= 991 fps= 31 q=-1.0 size= 19043kB time=00:00:40.85 bitrate=5025.9kbits/s throttle=off speed=0.981x10:33:01.167 frame= 1004 fps= 31 q=-1.0 size= 19320kB time=00:00:41.37 bitrate=5014.8kbits/s throttle=off speed=0.979x10:33:01.745 frame= 1022 fps= 31 q=-1.0 size= 19561kB time=00:00:42.09 bitrate=4964.3kbits/s throttle=off speed=0.984x10:33:02.321 frame= 1034 fps= 31 q=-1.0 size= 19795kB time=00:00:42.57 bitrate=4949.9kbits/s throttle=off speed=0.981x10:33:02.432 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:02.448 SegmentComplete=video:0 Index=13 Start=39.696000 End=42.296000 Duration=2.600000 offset_pts=0 start_pts=39696000 Frames=72 filename=hls/2B8C08/2B8C08_13.ts10:33:02.448 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_14.ts.tmp' for writing10:33:02.913 frame= 1046 fps= 31 q=-1.0 size= 19930kB time=00:00:43.05 bitrate=4911.8kbits/s throttle=off speed=0.978x10:33:03.459 frame= 1063 fps= 31 q=-1.0 size= 20197kB time=00:00:43.73 bitrate=4877.8kbits/s throttle=off speed=0.983x10:33:04.003 frame= 1074 fps= 31 q=-1.0 size= 20443kB time=00:00:44.17 bitrate=4874.0kbits/s throttle=off speed=0.98x10:33:04.565 frame= 1093 fps= 31 q=-1.0 size= 20685kB time=00:00:44.93 bitrate=4824.8kbits/s throttle=off speed=0.986x10:33:05.117 frame= 1102 fps= 30 q=-1.0 size= 20867kB time=00:00:45.29 bitrate=4817.9kbits/s throttle=off speed=0.981x10:33:05.352 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:05.382 SegmentComplete=video:0 Index=14 Start=42.576000 End=45.176000 Duration=2.600000 offset_pts=0 start_pts=42576000 Frames=72 filename=hls/2B8C08/2B8C08_14.ts10:33:05.382 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_15.ts.tmp' for writing10:33:05.674 frame= 1118 fps= 30 q=-1.0 size= 21103kB time=00:00:45.93 bitrate=4786.2kbits/s throttle=off speed=0.983x10:33:06.253 frame= 1134 fps= 30 q=-1.0 size= 21380kB time=00:00:46.57 bitrate=4764.6kbits/s throttle=off speed=0.985x10:33:06.847 frame= 1143 fps= 30 q=-1.0 size= 21538kB time=00:00:46.93 bitrate=4753.1kbits/s throttle=off speed=0.979x10:33:07.348 frame= 1162 fps= 30 q=-1.0 size= 21909kB time=00:00:47.69 bitrate=4738.0kbits/s throttle=off speed=0.986x10:33:07.936 frame= 1175 fps= 30 q=-1.0 size= 22129kB time=00:00:48.21 bitrate=4720.9kbits/s throttle=off speed=0.985x10:33:08.271 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:08.296 SegmentComplete=video:0 Index=15 Start=45.456000 End=48.056000 Duration=2.600000 offset_pts=0 start_pts=45456000 Frames=72 filename=hls/2B8C08/2B8C08_15.ts10:33:08.296 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_16.ts.tmp' for writing10:33:08.530 frame= 1190 fps= 30 q=-1.0 size= 22392kB time=00:00:48.81 bitrate=4703.6kbits/s throttle=off speed=0.985x10:33:09.105 frame= 1206 fps= 30 q=-1.0 size= 22705kB time=00:00:49.45 bitrate=4692.2kbits/s throttle=off speed=0.987x10:33:09.653 frame= 1216 fps= 30 q=-1.0 size= 22974kB time=00:00:49.85 bitrate=4700.5kbits/s throttle=off speed=0.983x10:33:10.230 frame= 1234 fps= 30 q=-1.0 size= 23244kB time=00:00:50.57 bitrate=4671.6kbits/s throttle=off speed=0.987x10:33:10.808 frame= 1247 fps= 30 q=-1.0 size= 23479kB time=00:00:51.09 bitrate=4659.4kbits/s throttle=off speed=0.986x10:33:11.151 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:11.162 SegmentComplete=video:0 Index=16 Start=48.336000 End=50.936000 Duration=2.600000 offset_pts=0 start_pts=48336000 Frames=72 filename=hls/2B8C08/2B8C08_16.ts10:33:11.162 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_17.ts.tmp' for writing10:33:11.402 frame= 1262 fps= 30 q=-1.0 size= 23703kB time=00:00:51.69 bitrate=4636.4kbits/s throttle=off speed=0.986x10:33:11.964 frame= 1274 fps= 30 q=-1.0 size= 23976kB time=00:00:52.17 bitrate=4636.6kbits/s throttle=off speed=0.984x10:33:12.529 frame= 1286 fps= 30 q=-1.0 size= 24126kB time=00:00:52.65 bitrate=4613.5kbits/s throttle=off speed=0.983x10:33:13.087 frame= 1304 fps= 30 q=-1.0 size= 24490kB time=00:00:53.37 bitrate=4605.6kbits/s throttle=off speed=0.987x10:33:13.632 frame= 1314 fps= 29 q=-1.0 size= 24734kB time=00:00:53.77 bitrate=4609.1kbits/s throttle=off speed=0.984x10:33:13.981 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:14.000 SegmentComplete=video:0 Index=17 Start=51.216000 End=53.816000 Duration=2.600000 offset_pts=0 start_pts=51216000 Frames=72 filename=hls/2B8C08/2B8C08_17.ts10:33:14.000 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_18.ts.tmp' for writing10:33:14.192 frame= 1332 fps= 29 q=-1.0 size= 24970kB time=00:00:54.49 bitrate=4578.1kbits/s throttle=off speed=0.987x10:33:14.738 frame= 1343 fps= 29 q=-1.0 size= 25193kB time=00:00:54.93 bitrate=4574.1kbits/s throttle=off speed=0.985x10:33:15.302 frame= 1358 fps= 29 q=-1.0 size= 25438kB time=00:00:55.53 bitrate=4557.9kbits/s throttle=off speed=0.986x10:33:15.897 frame= 1374 fps= 29 q=-1.0 size= 25720kB time=00:00:56.17 bitrate=4544.8kbits/s throttle=off speed=0.987x10:33:16.451 frame= 1385 fps= 29 q=-1.0 size= 26010kB time=00:00:56.61 bitrate=4552.9kbits/s throttle=off speed=0.985x10:33:17.018 frame= 1401 fps= 29 q=-1.0 size= 26266kB time=00:00:57.25 bitrate=4535.6kbits/s throttle=off speed=0.987x10:33:17.577 frame= 1415 fps= 29 q=-1.0 size= 26505kB time=00:00:57.81 bitrate=4523.5kbits/s throttle=off speed=0.987x10:33:17.906 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:17.932 SegmentComplete=video:0 Index=18 Start=54.096000 End=57.656000 Duration=3.560000 offset_pts=0 start_pts=54096000 Frames=96 filename=hls/2B8C08/2B8C08_18.ts10:33:17.932 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_19.ts.tmp' for writing10:33:18.176 frame= 1430 fps= 29 q=-1.0 size= 26755kB time=00:00:58.41 bitrate=4509.9kbits/s throttle=off speed=0.987x10:33:18.746 frame= 1446 fps= 29 q=-1.0 size= 27065kB time=00:00:59.05 bitrate=4502.8kbits/s throttle=off speed=0.989x10:33:19.322 frame= 1457 fps= 29 q=-1.0 size= 27336kB time=00:00:59.49 bitrate=4507.6kbits/s throttle=off speed=0.986x10:33:19.887 frame= 1473 fps= 29 q=-1.0 size= 27588kB time=00:01:00.13 bitrate=4491.3kbits/s throttle=off speed=0.988x10:33:20.451 frame= 1488 fps= 29 q=-1.0 size= 27865kB time=00:01:00.73 bitrate=4483.0kbits/s throttle=off speed=0.988x10:33:20.776 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:20.802 SegmentComplete=video:0 Index=19 Start=57.936000 End=60.536000 Duration=2.600000 offset_pts=0 start_pts=57936000 Frames=72 filename=hls/2B8C08/2B8C08_19.ts10:33:20.802 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_20.ts.tmp' for writing10:33:21.024 frame= 1502 fps= 29 q=-1.0 size= 28075kB time=00:01:01.29 bitrate=4467.6kbits/s throttle=off speed=0.988x10:33:21.587 frame= 1519 fps= 29 q=-1.0 size= 28381kB time=00:01:01.97 bitrate=4457.4kbits/s throttle=off speed=0.991x10:33:22.132 frame= 1528 fps= 29 q=-1.0 size= 28618kB time=00:01:02.33 bitrate=4463.9kbits/s throttle=off speed=0.987x10:33:22.682 frame= 1543 fps= 29 q=-1.0 size= 28757kB time=00:01:02.93 bitrate=4434.8kbits/s throttle=off speed=0.988x10:33:23.243 frame= 1551 fps= 29 q=-1.0 size= 28899kB time=00:01:03.25 bitrate=4430.0kbits/s throttle=off speed=0.984x10:33:23.599 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:23.628 SegmentComplete=video:0 Index=20 Start=60.816000 End=63.416000 Duration=2.600000 offset_pts=0 start_pts=60816000 Frames=72 filename=hls/2B8C08/2B8C08_20.ts10:33:23.636 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_21.ts.tmp' for writing10:33:23.818 frame= 1574 fps= 29 q=-1.0 size= 29263kB time=00:01:04.17 bitrate=4409.9kbits/s throttle=off speed=0.99x10:33:24.399 frame= 1585 fps= 29 q=-1.0 size= 29502kB time=00:01:04.61 bitrate=4410.3kbits/s throttle=off speed=0.988x10:33:24.957 frame= 1598 fps= 29 q=-1.0 size= 29664kB time=00:01:05.13 bitrate=4392.8kbits/s throttle=off speed=0.987x10:33:25.506 frame= 1614 fps= 29 q=-1.0 size= 29959kB time=00:01:05.77 bitrate=4385.7kbits/s throttle=off speed=0.989x10:33:26.062 frame= 1625 fps= 28 q=-1.0 size= 30232kB time=00:01:06.21 bitrate=4391.2kbits/s throttle=off speed=0.987x10:33:26.499 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:26.515 SegmentComplete=video:0 Index=21 Start=63.696000 End=66.296000 Duration=2.600000 offset_pts=0 start_pts=63696000 Frames=72 filename=hls/2B8C08/2B8C08_21.ts10:33:26.515 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_22.ts.tmp' for writing10:33:26.627 frame= 1644 fps= 28 q=-1.0 size= 30483kB time=00:01:06.97 bitrate=4368.7kbits/s throttle=off speed=0.991x10:33:27.202 frame= 1656 fps= 28 q=-1.0 size= 30750kB time=00:01:07.45 bitrate=4370.4kbits/s throttle=off speed=0.989x10:33:27.786 frame= 1670 fps= 28 q=-1.0 size= 30934kB time=00:01:08.01 bitrate=4354.1kbits/s throttle=off speed=0.989x10:33:28.342 frame= 1684 fps= 28 q=-1.0 size= 31211kB time=00:01:08.57 bitrate=4351.2kbits/s throttle=off speed=0.989x10:33:28.933 frame= 1696 fps= 28 q=-1.0 size= 31485kB time=00:01:09.05 bitrate=4353.9kbits/s throttle=off speed=0.987x10:33:29.407 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:29.443 SegmentComplete=video:0 Index=22 Start=66.576000 End=69.176000 Duration=2.600000 offset_pts=0 start_pts=66576000 Frames=72 filename=hls/2B8C08/2B8C08_22.ts10:33:29.447 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_23.ts.tmp' for writing10:33:29.448 frame= 1711 fps= 28 q=-1.0 size= 31670kB time=00:01:09.65 bitrate=4335.5kbits/s throttle=off speed=0.989x10:33:30.008 frame= 1726 fps= 28 q=-1.0 size= 31995kB time=00:01:10.25 bitrate=4336.5kbits/s throttle=off speed=0.99x10:33:30.576 frame= 1742 fps= 28 q=-1.0 size= 32263kB time=00:01:10.89 bitrate=4327.1kbits/s throttle=off speed=0.991x10:33:31.118 frame= 1753 fps= 28 q=-1.0 size= 32565kB time=00:01:11.33 bitrate=4336.4kbits/s throttle=off speed=0.989x10:33:31.681 frame= 1766 fps= 28 q=-1.0 size= 32768kB time=00:01:11.85 bitrate=4326.8kbits/s throttle=off speed=0.989x10:33:31.790[q] command received. Exiting.10:33:31.793 10:33:31.793 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:31.820 SegmentComplete=video:0 Index=23 Start=69.456000 End=72.056000 Duration=2.600000 offset_pts=0 start_pts=69456000 Frames=72 filename=hls/2B8C08/2B8C08_23.ts10:33:31.820 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08_24.ts.tmp' for writing10:33:31.820 [segment @ 0000000002d573c0] Opening 'C:\Users\Media Centre PC\AppData\Roaming\Emby-Server\programdata\transcoding-temp\2B8C08.m3u8.tmp' for writing10:33:31.835 SegmentComplete=video:0 Index=24 Start=72.336000 End=72.376000 Duration=0.040000 offset_pts=0 start_pts=72336000 Frames=1 filename=hls/2B8C08/2B8C08_24.ts10:33:31.835 frame= 1768 fps= 28 q=-1.0 Lsize= 32901kB time=00:01:11.93 bitrate=4338.8kbits/s throttle=off speed=0.988x10:33:31.835 video:31225kB audio:1676kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.000000%Last message repeated 1 times10:33:31.835 EXIT10:33:31.843======= 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 Edited April 9, 2020 by Matt19
Luke 42244 Posted April 10, 2020 Posted April 10, 2020 can you please attach the ffmpeg log and the emby server log in their original plain text format (not word). You can do this by clicking more reply options next to the Post button. Thanks.
