guunter 49 Posted August 9, 2024 Posted August 9, 2024 4 minutes ago, Q-Droid said: All relevant ports need to be open, active and reachable for domain validation, right? Unless it's using a different challenge method out of the box. You don't necessarily need to port forward it. You can use reverse proxy with like pihole for dns. So for example you can reach your internal sites that have an IP by a domain name, sonarr.domain.com and that can only be accessed locally. You'd of course need to run 2 reverse proxies for external and internal facing websites.
Q-Droid 1011 Posted August 9, 2024 Posted August 9, 2024 (edited) The certificate issuer needs to validate the domain. This is an external process and not related to LAN or WAN name resolution from within the network. Edited August 9, 2024 by Q-Droid
guunter 49 Posted August 9, 2024 Posted August 9, 2024 5 minutes ago, Q-Droid said: The certificate issuer needs to validate the domain. This is an external process and not related to LAN or WAN name resolution from within the network. Yes that's correct. If anything it could be a windows firewall issue? I haven't installed caddyv2 on windows so I don't know if you have to allow it or not. Everyone should just use linux 1
PeteGul 42 Posted January 11, 2025 Posted January 11, 2025 HI I have rally tried to make caddy save my a log, so I can check if there is something, when something happens. But I can't get it to work at all. I've tried to add the "log" code in top and in the bottom. But it wont start. My original caddyfile: It works as it should { email xxxx@gmail.com } xxx.xxx.net { encode gzip reverse_proxy http://192.168.0.2:8096 } And the I try this: { email pettnett@gmail.com } xxx.xxx.net { encode gzip reverse_proxy http://192.168.0.2:8096 } log { output file c:\caddy\logs\log.log { roll true # Rotate logs, enabled by default roll_size_mb 5 # Set max size 5 MB roll_gzip true # Whether to compress rolled files roll_local_time true # Use localhost time roll_keep 2 # Keep at most 2 log files roll_keep_days 7 # Keep log files for 7 days } Error I'll get is: Error: adapting config using caddyfile: Caddyfile:9: parsed 'log' as a site address, but it is a known directive; directives must appear in a site block. Tried to set "log" in to (), but did not help. Tried to read me up, but this is kinda not my skill So this log setup is from this thread.
pwhodges 2037 Posted January 11, 2025 Author Posted January 11, 2025 Logs are per site, so put the log directive inside the site block. More generally, except for the global block at the top, all directives go inside a site block. Simplest: just move the "}" after the reverse_proxy directive down to the end. Paul
Q-Droid 1011 Posted January 11, 2025 Posted January 11, 2025 You can define a snippet for logging then reuse it by referencing from each site. I haven't found a way to include the global Caddy log, it still needs its own settings in the global block. Define it: (logging) { log { output file /config/log/{args[0]}.log { roll_uncompressed roll_local_time roll_keep_for 7d roll_size 10MiB } format console { time_format wall_milli duration_format string level_format upper } } } Using it: #emby emby.mysite.net { reverse_proxy 192.xx.xx.xx:8096 header { blah blah blah } import logging emby } 1
PeteGul 42 Posted January 11, 2025 Posted January 11, 2025 4 hours ago, pwhodges said: Logs are per site, so put the log directive inside the site block. More generally, except for the global block at the top, all directives go inside a site block. Simplest: just move the "}" after the reverse_proxy directive down to the end. Paul Thanks, that was it. But had to remove "local time" for it to work
yocker 1429 Posted January 12, 2025 Posted January 12, 2025 Sorry if it has been mentioned before. Any benefit to using gzip with Caddy for Emby? Seems to me to just be a waste of CPU time for something like Emby but i kept being asking why i haven't enabled it by some friends of mine.
Q-Droid 1011 Posted January 12, 2025 Posted January 12, 2025 1 hour ago, yocker said: Sorry if it has been mentioned before. Any benefit to using gzip with Caddy for Emby? Seems to me to just be a waste of CPU time for something like Emby but i kept being asking why i haven't enabled it by some friends of mine. I think the general consensus is that the amount of compressible data sent by Emby is a tiny fraction of the total so the overall gain is miniscule. 1
yocker 1429 Posted January 12, 2025 Posted January 12, 2025 6 hours ago, Q-Droid said: I think the general consensus is that the amount of compressible data sent by Emby is a tiny fraction of the total so the overall gain is miniscule. Thanks, that was my thinking too but wanted to know for sure.
