warrencalvert 16 Posted April 7, 2020 Posted April 7, 2020 Hi I'm using Emby Theatre on Windows 10 and found a couple of limitations with the Live TV guide. 1. When using the keyboard (or more often a remote control) to scroll right to go to a later time it wont automatically scroll through the next day. It gets so far then stops and I need to go up to select a different day then back down to the guide then left to the start of that day. It would be much easier to just keep scrolling to the right and have it continuously scroll through the days. 2. When viewing upcoming movies and TV shows in the Live TV Guide and under 'Programmes' it only shows the next few hours. It would be great if you could scroll along to see the next 5 days at least. I guess this would be easy to implement - it would just be a case of increasing the value for max no of titles shown? 3. I use the Live TV guide on a large screen TV, it would be really useful to be able to display more rows and columns. Again, I guess this is easy to do by just allowing us to set the number of rows and columns. thanks, warren.
Luke 42244 Posted April 7, 2020 Posted April 7, 2020 HI there, yes these are planned for the future. Thanks for the feedback.
