fizzyade 132 Posted April 6, 2020 Posted April 6, 2020 (edited) Can we have a drop down on this that has an option for the library display options as it current shows when you display it, but also an option which takes you to the live tv settings. (this is on the Android TV client)It's a bit annoying that if you want to change live tv settings you can't do it in the live tv section and you have to go back to home and then navigate to the settings to change stuff. Edited April 6, 2020 by fizzyade
ebr 16339 Posted April 6, 2020 Posted April 6, 2020 Yes, I would like to move a lot of these settings closer to where they actually take effect (much like the default tab setting there now). Just haven't gotten there yet.
