sambarlick 15 Posted April 5, 2020 Posted April 5, 2020 Not sure if this is a bug or not, but I'd like to request this a feature of not. Extras etc... do not show if there are multiple versions of a movie grouped together. 3
PenkethBoy 2068 Posted April 5, 2020 Posted April 5, 2020 Yes i can confirm this does not work - in 4.5.0.4 beta server
Luke 42212 Posted April 5, 2020 Posted April 5, 2020 I'll have to try that. I have one for testing with a lowercase extras folder and that is working OK. @@Happy2Play what about you?
Happy2Play 9802 Posted April 5, 2020 Posted April 5, 2020 I'll have to try that. I have one for testing with a lowercase extras folder and that is working OK. @@Happy2Play what about you? Only looked at "Extras" but they worked in 4.3 and don't in 4.4, 4.5.
sambarlick 15 Posted April 5, 2020 Author Posted April 5, 2020 (edited) What are the contents of the movie folder?So far so have 2 movies this is affecting,Both have the same file structures, the folders are; Alien (1979)/ Alien (1979)-Theatrical Cut.mkv Alien (1979)-Theatrical Cut.en.srt Alien (1979)-Director's Cut.mkv Alien (1979)-Director's Cut.en.srt extras/ Director's Cut Intro The other movies file structure is the same except the movie is Aliens and as a test I renamed the sub folder specials and in both cases emby still doesn't show the Intro extra. I'm running version 4.4.1.0. Extras do work as I have other movies with only one version and emby shows the extras. Thanks for replying. Edited April 5, 2020 by sambarlick
Happy2Play 9802 Posted April 5, 2020 Posted April 5, 2020 Yes none multi-version movie extras continue to work, the issue only applies to multi-version media.
sambarlick 15 Posted April 5, 2020 Author Posted April 5, 2020 Yes none multi-version movie extras continue to work, the issue only applies to multi-version media. Ok thanks. So this is a bug not a "feature" needing to be requested?
Happy2Play 9802 Posted April 5, 2020 Posted April 5, 2020 Ok thanks. So this is a bug not a "feature" needing to be requested? I would say so, since it worked in previous version.
sambarlick 15 Posted April 6, 2020 Author Posted April 6, 2020 (edited) I would say so, since it worked in previous version. Ok, thanks. Edited April 6, 2020 by sambarlick
Luke 42212 Posted April 7, 2020 Posted April 7, 2020 As a test can you try adding a new movie and see if it's any different?
sambarlick 15 Posted April 7, 2020 Author Posted April 7, 2020 As a test can you try adding a new movie and see if it's any different? A single movie or multiple versions? I just added both versions of alien resurrection with an extra file and still the same the extra doesn't appear. All single version of movies with extras display the extras without issue.
Bigmack3000 108 Posted April 12, 2020 Posted April 12, 2020 @@Bigmack3000 Since the update, if I import a film with multiple versions, it doesn't display the extras on the page. Here's an example of what I mean:
Bigmack3000 108 Posted April 12, 2020 Posted April 12, 2020 I don't know if this should be a separate thread, but I've also found that since the update TV Shows are throwing all of my "Extras" folders into the "Specials" folders. I preferred these a lot more when they were separated.
Luke 42212 Posted April 13, 2020 Posted April 13, 2020 It will be resolved for the next release. Thanks. 1
sambarlick 15 Posted April 13, 2020 Author Posted April 13, 2020 It will be resolved for the next release. Thanks.Great news, thanks Luke!
BlazedMonkey 112 Posted April 13, 2020 Posted April 13, 2020 same issue here, glad to see if fix is on the way.
Happy2Play 9802 Posted April 13, 2020 Posted April 13, 2020 Resolved in Version 4.5.0.6 beta, in my tests. 2
Bigmack3000 108 Posted April 28, 2020 Posted April 28, 2020 Is there going to be a patch sent out, or will this be fixed on the next official release?
Spaceboy 2573 Posted April 28, 2020 Posted April 28, 2020 Is there going to be a patch sent out, or will this be fixed on the next official release?itll be the next official release
Bigmack3000 108 Posted April 28, 2020 Posted April 28, 2020 Is there an estimate on when that would be? Since an update was just released, I'd imagine it's a few months away?
Bigmack3000 108 Posted April 29, 2020 Posted April 29, 2020 That is unfortunate since this particular error affects so many films.
rene.teniere 17 Posted April 30, 2020 Posted April 30, 2020 I was struggling to figure out why i could not see the extras for a movie. I had followed your naming conventions but still no luck. I finally tried removing a second version of the movie stored in the same folder, re-scanned and now it shows up. Below is the structure: /movies-kids/ /The Goonies (1985)/ The Goonies (1985) - 1080p.mkv The Goonies (1985) - 1080p Video Commentary.mkv /Extras/ Deleted Features.mkv The file i removed was The Goonies (1985) - 1080p Video Commentary.mkv and it worked. @@rene.teniere
