darkmark 0 Posted April 5, 2020 Posted April 5, 2020 Hi All Samsung Emby Theater v1.0.75 I have been playing with the horizontal layout on the TV and have just switched back to vertical as others in the household prefer it. Now I don't know if it's something where different layouts have been tried or updates that have happened etc but ... the "hamburger" menu in the top left is missing. The top menu bar only shows Home/Favouries. So there's no way to get select libraries. The main window shows Continue watching/ next up and the usual suspects you'd expect. Anyone got any ideas / diagnostics before I start uninstalling the app? Thanks Mark
darkmark 0 Posted April 5, 2020 Author Posted April 5, 2020 ... and to reply to my own post in case anyone else hits the same problem. The answer is that the "My Media" section had been turned off.
Dzeta 0 Posted April 5, 2020 Posted April 5, 2020 Good, I have updated to emby premiere and live tv does not appear in the applications of the samsung smart tv or in the windows 10, it is directly that they do not allow me to do anything.
Luke 42242 Posted April 5, 2020 Posted April 5, 2020 Good, I have updated to emby premiere and live tv does not appear in the applications of the samsung smart tv or in the windows 10, it is directly that they do not allow me to do anything. Hi there, have you setup Live TV on your Emby Server? https://github.com/MediaBrowser/Wiki/wiki/Live-TV
Dzeta 0 Posted April 5, 2020 Posted April 5, 2020 Hi there, have you setup Live TV on your Emby Server? https://github.com/MediaBrowser/Wiki/wiki/Live-TV Yes, I got my iptv m3u lists, but live tv does not appear on television or pc windows, it is not that the channels do not appear, it is that the option to enter live tv does not appear directly
Luke 42242 Posted April 5, 2020 Posted April 5, 2020 Yes, I got my iptv m3u lists, but live tv does not appear on television or pc windows, it is not that the channels do not appear, it is that the option to enter live tv does not appear directly Where are you looking for it? Can you show a screenshot? Thanks.
Dzeta 0 Posted April 5, 2020 Posted April 5, 2020 Where are you looking for it? Can you show a screenshot? Thanks. It seems that I reset emby and it gets stuck for a long time, I don't know if this is normal when loading the data from the m3u file
Carlo 4561 Posted April 5, 2020 Posted April 5, 2020 Are you saying the server get's stuck for a long time after a reset? Curious, how many entries do you have in your M3U file used for TV?
