pir8radio 1313 Posted April 5, 2020 Posted April 5, 2020 Is there any kind of log entry that increments with every new stream started or ended? like a new stream starts and a line is added to the log: {TIME} INFO: concurrent streams now 7 a stream stops: {TIME} INFO: concurrent streams now 6 I would like to track it but dont know a better way... I can count ffmpeg instances running but thats not accurate.
rechigo 367 Posted April 5, 2020 Posted April 5, 2020 (edited) No, but a plugin could be written to do this for you...-----------edit--------- Here, logging freak. Logs in format: {TIME} Info ConcurrentStreamLogger: Session Count: {stream_count} (I know it says session count, trust me, it's only counting streams) (This took 5 minutes and I needed a break from what I was working on lol) Emby.ConcurrentStreamLogger.zip Edited April 5, 2020 by rechigo 1
pir8radio 1313 Posted April 5, 2020 Author Posted April 5, 2020 No, but a plugin could be written to do this for you... -----------edit--------- Here, logging freak. Logs in format: {TIME} Info ConcurrentStreamLogger: Session Count: {stream_count} (I know it says session count, trust me, it's only counting streams) (This took 5 minutes and I needed a break from what I was working on lol) lol sweet, I really have to get the stuff on my windows laptop to mess around with making plugins... Sweet I'll try it out thanks!!!
TeamB 2440 Posted April 5, 2020 Posted April 5, 2020 The playback reporting plugin has a concurrent play session count in its resources chart.
pir8radio 1313 Posted April 13, 2020 Author Posted April 13, 2020 No, but a plugin could be written to do this for you... -----------edit--------- Here, logging freak. Logs in format: {TIME} Info ConcurrentStreamLogger: Session Count: {stream_count} (I know it says session count, trust me, it's only counting streams) (This took 5 minutes and I needed a break from what I was working on lol) Thanks again for this quick plugin!! I'm starting to see it in my logs, now i just need to build some graphs!!! thanks again!
bruor 43 Posted January 8, 2024 Posted January 8, 2024 Sorry to necro this, any chance this works on 4.7? Also, how did you add a bar graph for the data?
Luke 42185 Posted January 8, 2024 Posted January 8, 2024 5 minutes ago, bruor said: Sorry to necro this, any chance this works on 4.7? HI, what exactly are you asking?
