samper 2 Posted April 5, 2020 Posted April 5, 2020 Buenas, En el menu de la pelicula, el trailer se puede reproduir en la version gratuita o solo en la premium? Porque tengo la gratuita y algunos trailers se ven y otros no. Si tambien es para la version gratis, que complements puedo bajar para tener todos los trailers? Gracias 1
Happy2Play 9811 Posted April 5, 2020 Posted April 5, 2020 Los trailers de elementos de youtube provienen de metadatos proporcionados por TMDB. ¿Puedes repasar un ejemplo específico? Item youtube trailers comes from metadata provided by TMDB. Can you go over a specific example.
samper 2 Posted April 5, 2020 Author Posted April 5, 2020 Good, For example, I have the movie Goodbye of 2019 and when I went over the trailer tab, it kind of referred me to the trailer but it closed suddenly, the same month passed with the movie Reaching your dreams, which was as if it was suddenly interrupted, because the screen went black, but then I went back to the movie menu. But on the other hand, the movie Bloodshot if the trailer came out well. So my question, if I can also see trailers in the free version or is it only for the paid version? And then, if I can put some plugin so that the trailers are all. Thank you. @@cayars
Carlo 4561 Posted April 6, 2020 Posted April 6, 2020 Having a bit of trouble understanding what you are asking but let me give it a shot. Trailers work in the free version. There is a Trailers plugin where you can adjust some type of trailers to display.
Happy2Play 9811 Posted April 6, 2020 Posted April 6, 2020 The trailers tab is a bit deceiving as it does not show trailers within your library or url based trailers from items within your library. The library trailers tab is linked to the Trailers plugin which requires Premiere subscription. There is a third party plugin that will download trailers to make them local, and even a script on the forum. But local trailer still don't apply to the Trailers tab within a library.
samper 2 Posted April 6, 2020 Author Posted April 6, 2020 Buenas, La verdad que en la película Adiós (2019), la pestaña trailer de la TV Lg, es como si intentara abrir el trailer pero se cierra de repente, pero entrando en el servidor emby del ordenador puedo ver el trailer sin ningún problema; es decir, el problema lo tengo en solo 2 películas de 60 y en la TV, no en el servidor del ordenador que funciona perfecto. Sobre lo que comentas Happy2Play, es el complemento de trailers HD el que requiere ser Premier, no? ya lo ví y es muy interesante, pero la versión trailer sin HD debe ser gratuita porque lo puedo ver en el resto de pelis. Que complemento específico de trailer me puedo instalar, porque veo Cayars y Happy2Play decís que existe uno y debe funcionar, como se llama? por instalar si no me funciona? Y por último, valoro hacerme Premier por la TV Direct, ya que tengo VODAFONE TV y no quier el deco que te dan. Puedo pedir a la empresa el M3U y con ese listado que yo pago, puedo ver los canales en Emby sin ningún probleam? igual que Movistar Plus, que tengo Yomvi? Porque esta función me interesa si puedo coger listas legales que pago (y no se si se pueden pedir) para verlo en la tv con la app ya que Vodafone TV en mi LG no hay app. Gracias.
Carlo 4561 Posted April 6, 2020 Posted April 6, 2020 Trailers can be a bit hard to talk about as they are used different ways in Emby. Local trailers you download or rip that sit besides your movies. Trailers that show up in searches that come from movielist, etc YouTube trailers The above used in Cinema mode The plugin I was referring to is called "Trailers" (for supporters) current at version 1.2.9.0 as I type this. This adds 1500 or so trailers to the system for use with cinema mode and has options you can select: Movie trailer archive New and Upcoming in Theaters New and Upcoming on Dvd New and Upcoming on Netflix
samper 2 Posted April 6, 2020 Author Posted April 6, 2020 Muchas gracias. Valoraré hacerme premium para poner el modo cine. Gracias. Sobre el otro asunto de las listas m3u lo expondré en otro topic. Saludos. 1
