RandonOrty 0 Posted April 3, 2020 Posted April 3, 2020 Hi there, Happy user of Emby, I am facing a problem with hardware transcoding since a few days. When I play a video, which need to be transcoded, everything works fine if there are no subtitles. Hardware transcoding (Intel Quick Sync) do the job, transcoding go faster than playing, my integrated GPU work hard, everything is fine. But if I add subtitles to the play, the hardware transcoding goes a lot slower, so the video stuck frequently because the transcoding is not fast enough. I got the problem with all my players (Web player on Edge and Chrome, Emby on my Shield TV or on my smartphone). Info about my computer: Proc: Intel Core I5-9600K Mem: 16 Go DDR4 SSD: Samsung SSD Evo Plus 250Go OS: Windows 10 1909 (18363.752) Info about my Emby Server: Emby Premiere: yes Hardware transcode: yes Here some screenshots about a test with a HEVC encoded file with and without subtitles. I play the file remotely through the web player. You can find log files attached. Without subtitles, everything fine With subtitles, slow hardware transcoding Do you know what can cause this performance issue? Thanks' and keep up the good work PS: that's my first post, I hope I did it correctly ! embyserver.txt ffmpeg-transcode-wo_subtitles.txt ffmpeg-transcode-with_subtitles.txt
Luke 42212 Posted April 3, 2020 Posted April 3, 2020 Hi there, did you take a look at the troubleshooting section at the bottom of our hardware acceleration setup guide? https://support.emby.media/support/solutions/articles/44001160148-hardware-acceleration-overview
RandonOrty 0 Posted April 4, 2020 Author Posted April 4, 2020 Hi Luke, Thank you for you quick reply. Yes, a look at the article and I get the point with the integrated subtitles. What I don't understand is : - i don't have any activity peak on my CPU when I add the subtitles. With or without subtitiles, the CPU usage is about 15-20% - when I disable hardware acceleration, my CPU handle well the transcoding with subtitles. It seems that the CPU is not well used with hardware acceleration and subtitles.
RandonOrty 0 Posted April 4, 2020 Author Posted April 4, 2020 (edited) Here some tests I have done: Try with or without the option “Allow subtitles extraction on the fly” (hope my translation is good ) Enable advanced hardware acceleration and try the three different methods. Only Quick Sync seems to work. D3D11 et DX11VA failed and Emby fallback to software transcode. If I disable hardware acceleration for decoding part and keep it enable for encoding part, the process is fast. Don’t know if it can help Edited April 4, 2020 by RandonOrty
softworkz 5129 Posted April 4, 2020 Posted April 4, 2020 Moving data back and forth between system and GPU memory comes at some cost, and burning-in subtitles is currently done by the CPU only. In the future, we're planning to do the overlay in the GPU hardware as well.
RandonOrty 0 Posted April 5, 2020 Author Posted April 5, 2020 Thanks softworkz, So for my case, I will stay with software decode and hardware encode. It seems to be the best scenario, using both my CPU and GPU at 70%. A little bit sad not being able to only use hardware transcode and free up my CPU. I'll wait the update Thanks guyz
eyeSome 1 Posted April 17, 2020 Posted April 17, 2020 Hey Guys, it's the same for me with emby v4.4.2.0 on Synology DS918+ Some movies (h264) with forced subs are going crazy and need to be transcoded because of unsupported subtitles. For me the transcoding performance is horrible (3fps) what makes looking the movie with subtitles enabled impossible. Is there any way to have the subtitles "supported"? Can I replace them with working ones? Regards, eyeSome
Luke 42212 Posted April 17, 2020 Posted April 17, 2020 Hey Guys, it's the same for me with emby v4.4.2.0 on Synology DS918+ Some movies (h264) with forced subs are going crazy and need to be transcoded because of unsupported subtitles. For me the transcoding performance is horrible (3fps) what makes looking the movie with subtitles enabled impossible. Is there any way to have the subtitles "supported"? Can I replace them with working ones? Regards, eyeSome I would suggest either playing with Emby apps that can direct play the subtitles such as android or iOS, or download external srt subtitles. Our subtitle download features can help with that.
RandonOrty 0 Posted June 7, 2020 Author Posted June 7, 2020 Hey guyz, Quick post to tell you that my problem have been solved. I think it's due to a driver update. (or Emby update ?) I can know enable hardware transcoding with great performance. Cheers
