chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 and pls stop saying you dont have enough info and start telling me what info you need or we wont get anyhwere
Happy2Play 9806 Posted April 3, 2020 Posted April 3, 2020 But I have zero issue accessing your domain with the image you provided. So We don't really know why you can not access it yourself. All we know is it would be a Hairpin router loopback issue. Meaning you can not access your WAN address from within your LAN. All devices outside your LAN should have not issues like me.
rbjtech 5338 Posted April 3, 2020 Posted April 3, 2020 Now we have your FQDN, I can scan your port myself and 8920 is Open - the issue is not your ports or firewalls - I suspect it's your Cert as suggested earlier. ps - you may want to remove your FQDN from post #22 ... 1
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Yes. All working from here too. Are you trying to use hairpin nat internally? Or have you set up split horizon dns? Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 install te cert? i converted it from pem to pfx and then directed emby to that file... is there a step missing?
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 i dont know about the hairpin nat or horizons dns
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 The cert is fine. I have logged in as Sue and emby is presenting your librarys perfectly. Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 thankyou for removing that post with my info
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 ok now im really confused, hw can you log in and i cant? it wont work from my mobile devices remotely using the app or the browser, the device im using is an galaxy s10 if that helps?
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 So you have switched off wifi on your mobile? Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 it connects fine when on 8096 but not 8920
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 (edited) Well i am using a Note 10+ over wifi and chrome is working fine. You are putting https at the beginning of the url arnt you? Krs Mark Sent from my SM-N976B using Tapatalk Edited April 3, 2020 by maegibbons
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 i've even tred emby connect and that doesn't work iether
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 apparently that was it, for the browser lol... i feel stupid... now to get it to work on my app
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 all done, thankyou so much, hopefully this will help another noob out in the future.... i've been going crosseyed for days now and overlooked the obvious. thankyou once again 1
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Well i can assure you it is working how you intended from here so dont adjust anything on the emby/pc side because it ISNT BROKEN. Try a diffetent phone or device. Log in to a remote pc in the cloud and dial back. Krs Mark Sent from my SM-N976B using Tapatalk 1
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 (edited) Ok great. Glad you got it sorted. Krs Mark Sent from my SM-N976B using Tapatalk Edited April 3, 2020 by maegibbons 1
chef 3811 Posted April 3, 2020 Posted April 3, 2020 Ok great. Glad you got it sorted. Krs Mark Sent from my SM-N976B using Tapatalk Well done!
Happy2Play 9806 Posted April 3, 2020 Posted April 3, 2020 Also note if you are allowing External connections you should apply passwords to all Users or hide them on the login page requiring them to manually login. 1
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 my final thought to people reading this.... emby is way better than plex once you have it setup correctly!! the streams are much better quality and far more stable.. thankyou guys for your help once again 2
rbjtech 5338 Posted April 3, 2020 Posted April 3, 2020 apparently that was it, for the browser lol... i feel stupid... now to get it to work on my app Coincidentally, which Browser did not work ? I suspect it's something to do with the Lets Encrypt Cert and chain of trust - so it would be interesting to find out what Browser doesn't like those Certs.. Glad you got it sorted.
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Coincidentally, which Browser did not work ? I suspect it's something to do with the Lets Encrypt Cert and chain of trust - so it would be interesting to find out what Browser doesn't like those Certs.. Glad you got it sorted. He was not putting httpS in front. Krs Mark Sent from my SM-N976B using Tapatalk 1
