chris_martin 3 Posted April 3, 2020 Posted April 3, 2020 i've recently come to emby from plex because the plex service has become more and more unreliable over the last 2 yrs to the point of becoming unusable.... ive mabaged to get everything working remotely on port 8096 with no problems whatsoever. however port 8920 is dead in the water as far as emby is concerned.... im using and asuscomm.com ddns with a let encrypt key and have converted it from pem ot pfx as directed in other posts with a passowrd etc.... the ports are forwarded on my router and can both be seen from canyuseeme.org... and yet emby still wont connect via https on any device in or ut of my network.... ive been going through the forum for the last 3 days and am almost at the point of just sticking to netfix and not wasting another dollar or minute trying to get these things to work as advertised..... im not a particularly advance user as im sure you can tell.....and emby has a rediculous amount of logs already so wouldn't know where to begin in providing more information.. i really am at the end of my teather with this
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 i've wasted days trying to get this to work
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 i've even disabled all firewalls and still nothing.....
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 So how are you testing it? Have you got it working on the LAN with https? Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 it doesnt work on that port in or out of my network, ive tested it by using the app and my domain.com:port# in my browser and still nothing thatbport is open on my ip when i check it from canyouseeme.org
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 How about ip and port? Should ask you to create exception. Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 when doing that in my browser on my network it says connection reset
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Then something is not right with the port. If you have disabled the PC firewall and it still gives that then post your network settings screen from with emby. Krs Mark Sent from my SM-N976B using Tapatalk
Happy2Play 9805 Posted April 3, 2020 Posted April 3, 2020 What does "however port 8920 is dead in the water" mean? I have zero issues with port 8920 and using my ssl certificate. If 8920 does not show open like 8096, then I would first look at port forwarding, then the firewall to ensure port is configured. Most of the time at least in Windows disabling firewall doesn't help.
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 it means it doesn't work. not seen.. not by emby atleast. it shows as open and working when i check it on canyouseeme.org so i dont understand why emby doesn't see it
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 how do i add a print screen to this topic???
rbjtech 5338 Posted April 3, 2020 Posted April 3, 2020 (edited) Pretty sure this has nothing to do with the ports - the OP has said that both ports are being answered by using canyouseeme.org - this prooves the port forwarding is working and the firewalls are allowing the traffic in/out. I suspect it's a Certificate issue. A simple 'netstat -a | find "8920" will tell you if the host is listening on the correct port. It should show something like this (with 192.168.30.100 being the host in my case) C:\netstat -a | find "8920" TCP 0.0.0.0:8920 MEDIA:0 LISTENING TCP 192.168.30.100:8920 host**-***-107-255:41771 ESTABLISHED TCP 192.168.30.100:8920 host**-***-107-255:41773 ESTABLISHED TCP [::]:8920 MEDIA:0 LISTENING Edited April 3, 2020 by rbjtech
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 this whole thing is driving me nuts, you guys really need to get this sorted so its easier for the noobs like me
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 i converted my pem to pfk (with password) using....https://www.sslshopper.com/ssl-converter.html
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 if that helps anybody, i cant do the command prompt stuff and m nt even gonna try it
Happy2Play 9805 Posted April 3, 2020 Posted April 3, 2020 There are dozens of how to's but. No one understands "it doesn't work". As rbjtech mentioned it could be the certificate itself that is the issue, but we are all just guessing with the information provided.
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 (edited) Pretty sure this has nothing to do with the ports - the OP has said that both ports are being answered by using canyouseeme.org - this prooves the port forwarding is working and the firewalls are allowing the traffic in/out. I suspect it's a Certificate issue. Which is why I asked him to test internally by ip and port. He should be able to override an invalid certificate. His port forwarding may be totally wrong giving canyouseeme a false positive. Build it up from the basic networking. Krs Mark Sent from my SM-N976B using Tapatalk Edited April 3, 2020 by maegibbons
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 how do i attach thing to send you guys?? tell me which logs which files and which printscreens you need and how to send them pls
Happy2Play 9805 Posted April 3, 2020 Posted April 3, 2020 Right you should get a cert error in browser via WANIP:port. There just is not enough information.
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 If i was guessing i would say he has installed the cert wrong and emby is not opening the port properly or the pc firewall is still enabled. Krs Mark Sent from my SM-N976B using Tapatalk
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Right you should get a cert error in browser via WANIP:port. There just is not enough information.Try LANIP:port first. We do not know if he has hairpin nat enabled. Krs Mark Sent from my SM-N976B using Tapatalk
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 (edited) **Removed image Edited April 3, 2020 by Happy2Play
chris_martin 3 Posted April 3, 2020 Author Posted April 3, 2020 can somebody remove the post with my domain in it pls
