joe.mukeni01 1 Posted April 2, 2020 Posted April 2, 2020 Hello, I'm new to the forum. I've been using Emby for months now, and I've run into a problem. I've using an HDHOMERUN and a M3U to stream Live TV. I've followed the instruction and followed the setup that's on YouTube as well. My issue is, the channels aren't loading from the HDHOMERUN Tuner nor the M3U. I've used other apps, and the channels are loading with no problem. I've tried using a different TV guide, and I received the same result each time, no channels will load. Is there a fix for this? Thanks, Joe 1
ebr 16337 Posted April 2, 2020 Posted April 2, 2020 Hi. Exactly what do you mean by "channels are not loading"? They don't show in the interface, they don't play properly, ...? Exactly what does happen when you try? How to Report a Problem
tvboxverema 0 Posted April 3, 2020 Posted April 3, 2020 (edited) Buenas a mi ocurre exactamente lo mismo cargo un archivo.m3u y no aparecen los canales. (mi pregunta es hay que ser premium para que salgan los canales de m3u o el premium es para otros servicios de tv en vivo gracias Good to me the exact same thing happens I load an.m3u file and the channels do not appear. (my question is do you have to be premium for the m3u channels to come out? or the premium is for other live tv servicesthanks Edited April 3, 2020 by tvboxverema
Luke 42244 Posted April 3, 2020 Posted April 3, 2020 Buenas a mi ocurre exactamente lo mismo cargo un archivo.m3u y no aparecen los canales. (mi pregunta es hay que ser premium para que salgan los canales de m3u o el premium es para otros servicios de tv en vivo gracias Good to me the exact same thing happens I load an.m3u file and the channels do not appear. (my question is do you have to be premium for the m3u channels to come out? or the premium is for other live tv servicesthanks Hi there, yes live tv requires Emby Premiere.
tvboxverema 0 Posted April 3, 2020 Posted April 3, 2020 Hi there, yes live tv requires Emby Premiere. Ok Thank you, I will continue to use other services.
maegibbons 1287 Posted April 3, 2020 Posted April 3, 2020 Ok Thank you, I will continue to use other services.Just buy a sub for a month to test it. It is only $5. If you do go lifetime, if not you have only spent $5 testing it out. Krs Mark Sent from my SM-N976B using Tapatalk
joe.mukeni01 1 Posted April 3, 2020 Author Posted April 3, 2020 Hi EDR, What I meant when I said the channels aren't loading, after adding the TV source and the TV guide provider, no channels loaded on the home screen, nor under the guide on the main page. I've deleted and added the information several times, and finally, the channels loaded. I've noticed that after mapping the channels, a few channels are not showing data, the guide schedule information of what's coming on. Is there a way to fix this? Thanks,
Luke 42244 Posted April 3, 2020 Posted April 3, 2020 Hi EDR, What I meant when I said the channels aren't loading, after adding the TV source and the TV guide provider, no channels loaded on the home screen, nor under the guide on the main page. I've deleted and added the information several times, and finally, the channels loaded. I've noticed that after mapping the channels, a few channels are not showing data, the guide schedule information of what's coming on. Is there a way to fix this? Thanks, Hi, what guide data did you use?
joe.mukeni01 1 Posted April 6, 2020 Author Posted April 6, 2020 I used the Emby Guide Data. Also, I've noticed that the recording that I've schedule are stopping half way thru the movie/ tv show I scheduled for recording. Could a setting be off that I accidentlly changed?
Luke 42244 Posted April 6, 2020 Posted April 6, 2020 I used the Emby Guide Data. Also, I've noticed that the recording that I've schedule are stopping half way thru the movie/ tv show I scheduled for recording. Could a setting be off that I accidentlly changed? Can we please look at an example? Please attach the information requested in how to report a problem. Thanks.
