msmcpeake 8 Posted April 2, 2020 Posted April 2, 2020 (edited) Hi, I'm on version 4.5.0.4 beta, and the last 4 versions I cannot set a new password for users via API. I am trying to set a password for a newly created user because when a new user is created, their password is blank. I can create the user and change user polices just fine using curl requests, utilizing examples from Swagger UI, but cannot for the life of me set a password. This is my current syntax and error I receive: curl -X POST "http://<ip>:8096/emby/Users/1a908baf86e54ab4843652e4d1fd057f/Password?api_key=<api key>" -H "accept: */*" -H "Content-Type: application/json" -d "{\"Id\":\"1a908baf86e54ab4843652e4d1fd057f\",\"CurrentPw\":\"\",\"NewPw\":\"test\",\"ResetPassword\":false}" Object reference not set to an instance of an object. I have nothing in my logs, and the error is very vague. What's infuriating is once in awhile, the request goes through with no error, but the password doesn't actually set and work. I have tried removing ResetPassword, change the blank string to NULL, 0... I am at my wits' end. Please someone assist me or explain what is wrong with this curl request.Also, why is their an Id field in the json when the Id is already referenced in the url? Edited April 2, 2020 by msmcpeake
PenkethBoy 2068 Posted April 2, 2020 Posted April 2, 2020 Yep thats not going to work Just did a quick test and it works fine for some reason you have Resetpassword as false - not sure why you thought that would work - but as true (the default from looking at swagger) works first time
msmcpeake 8 Posted April 2, 2020 Author Posted April 2, 2020 (edited) Yep thats not going to work Just did a quick test and it works fine for some reason you have Resetpassword as false - not sure why you thought that would work - but as true (the default from looking at swagger) works first time Did you verify the password actually set and worked after? And this was on a newly created user? This doesn't work for me. And I used the default settings as well with it as true, it didn't ever matter. Same error every time. Edited April 2, 2020 by msmcpeake
PenkethBoy 2068 Posted April 2, 2020 Posted April 2, 2020 yep - got a 204 response (which is what i would expect) - new test user created did it via swagger No - i did not try and login as got a 204 response - which in emby world means success - so i assumed wrongly it was done And you are correct the passwords did not take - have tried a few variations on the json posted response with no luck did it manually in the UI for the user and that worked - but no clue in the logs about what it sent tried easypassword as well with no positive result So i guess that Swagger is wrong and needs updating Only difference i am seeing to you is i dont get an error - appears to be 204 everytime - not doing it with curl just via swagger so might be the difference @@Luke - can you give us some guidance on whats needed to set a password for a user
rechigo 367 Posted April 3, 2020 Posted April 3, 2020 (edited) I've noticed this happening as well, sorry for not responding to your messages @@msmcpeake , was dealing with other projects and didn't feel like putting up with more trial and error with the Emby API I just tested this on a new user curl -X POST "http://192.168.0.69:8096/emby/Users/af0fbdc1023b40e29748ba48335cd9bb/Password?api_key=lolialmostleakeditagain"-H "accept: */*" -H "Content-Type: application/json" -d "{\"CurrentPw\":\"\",\"NewPw\":\"cuck\"}" and it worked perfectly, only difference being that I left out ID and ResetPassword I decided to test the same command again, only difference being a different user ID. Guess what? IT DIDN'T SET THE PASSWORD! (Or so I thought) When I try to run the command again, it says invalid password. When I try to sign in, it works with the newly set password. Some things point to "Yes, a password has been set" and other things point to "No, a password hasn't been set" The response to the /users/id endpoint after setting the password shows this: I'm starting to think this is a bug with the web app. Everything EXCEPT the password tab on the users page reports that "Yes, a password has in fact been set." sorry if this doesnt make much sense, it was getting late and I wanted to watch a movie. if you need any clarification let me know Edited April 3, 2020 by rechigo
Luke 42239 Posted April 3, 2020 Posted April 3, 2020 It does existing password validation against the logged in user, so currently you cannot use this api with only the api_key param. It's something we'll need to look at. Thanks.
