jakeip 0 Posted April 1, 2020 Posted April 1, 2020 I have a TCL P8S Android Tv and not able to get 5.1 out unless I use an external player; what could be the problem. Sound is set as Auto.
ebr 16338 Posted April 1, 2020 Posted April 1, 2020 Hi. Yes, make sure you installed the "Emby for Android TV" application...
Luke 42246 Posted April 2, 2020 Posted April 2, 2020 Have you configured audio settings in the Android os?
jakeip 0 Posted April 2, 2020 Author Posted April 2, 2020 Yes I've set digital sound as passthrough The native player outputs Dolby sound normal
ebr 16338 Posted April 2, 2020 Posted April 2, 2020 Yes I've set digital sound as passthrough What are your other options there? What is the outboard sound equipment and how is it connected?
jakeip 0 Posted April 2, 2020 Author Posted April 2, 2020 I have Auto, PCM and OFF My output is a Sony str-dh790 AV receiver 7.2 via HDMI
ebr 16338 Posted April 2, 2020 Posted April 2, 2020 What happens if you set the TV and the app to "Auto"?
jakeip 0 Posted April 2, 2020 Author Posted April 2, 2020 Well receiver displays DSUR (Dolby Surround) but no output to center channels.
Luke 42246 Posted April 2, 2020 Posted April 2, 2020 Well receiver displays DSUR (Dolby Surround) but no output to center channels. Can you please go over an example?
jakeip 0 Posted April 5, 2020 Author Posted April 5, 2020 I tested emby on the Shield and sound passthrough is incredible. I think my TV has a problem working with the Emby Android TV app. I'll plan to get an android box that can passthrough all codecs.
