some streams not work..
Legend1981
Guys, I got a problem with the tv stream.
I made the upgrade to 4.4.0.40 and in some streams they do not work.
With version 4.2.1.0 all streams work...
I checked the log.
2020-04-01 00:24:39.003 Info SharedHttpPipelineSource: Beginning SharedHttpPipelineSource stream to /var/lib/emby/transcoding-temp/0a3eb1c442b642c386d76c7f287db316.ts
2020-04-01 00:24:39.010 Info LiveTvManager: Live stream opened after 510.5861ms
2020-04-01 00:24:39.052 Info MediaSourceManager: Live stream opened: {"Protocol":"Http","Id":"1","Path":"http://127.0.0.1:809...playTitle":"MP30 ch","IsInterlaced":false,"BitRate":192000,"Channels":0,"SampleRate":0,"IsDefault":false,"IsForced":false,"Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"Formats":[],"Bitrate":20192000,"RequiredHttpHeaders":{},"ReadAtNativeFramerate":false}
2020-04-01 00:24:39.056 Info MediaInfoService: User policy for Admin. EnablePlaybackRemuxing: True EnableVideoPlaybackTranscoding: True EnableAudioPlaybackTranscoding: True
2020-04-01 00:24:39.056 Info MediaInfoService: Bitrate exceeds DirectPlay limit: media bitrate: 20192000, max bitrate: 10000001
2020-04-01 00:24:39.056 Info MediaInfoService: Bitrate exceeds DirectStream limit: media bitrate: 20192000, max bitrate: 10000001
00:36:05.146 [mpegts @ 0xe18cc0] Could not find codec parameters for stream 40 (Video: h264 ([27][0][0][0] / 0x001B), none): unspecified size
Consider increasing the value for the 'analyzeduration' and 'probesize' options
I think the problem and the new ffmpeg...
somebody knows how to solve this?
Thanks
