mernmx 2 Posted April 1, 2020 Posted April 1, 2020 (edited) hi @@TeamBi have an issue with embycon when trying to open sections which has a big number of movies or tv shows it keep saying "The read operation timed out" but when opening a specific section like 4k tv shows or 4k movies it works without any issue i really need to access my full library. i have attached my log kodi.log Edited April 1, 2020 by Luke
TeamB 2440 Posted April 1, 2020 Posted April 1, 2020 What you are seeing is a HTTP time out error from the HTTP client, this means the server took to long in getting back to EmbyCon with data when EmbyCon asked for your library info. In the latest version you can set the HTTP timeout in the advanced setting area of the EmbyCon settings. Try a larger value. You can also try using the pages option in the EmbyCon main menu under your library, this will break the request up into pages of items and should be quicker to return the data. It does mean you will need to page through your library though as you browser your media items from your large library.
