ShobuPrime 0 Posted March 31, 2020 Posted March 31, 2020 Good morning, I'm writing this because I wanted to highlight an issue I've been having with the Surface Pro X, which is a Windows on ARM always-connected device. The issues I'm having with the app are: It seems downmixing is not working properly for 5.1 and 7.1 audio. Audio sounds very, very low despite ensuring all settings such as the volume bar and system volume are maxed out Content with stereo audio sounds normal as far as I can tell Playback of any video over Cellular plays for about 0.5seconds, then freezes. It will continue pausing and playing like a delayed stutter with a few seconds in between. If I switch to Wi-Fi, the content will play at normal speeds, but the audio depending on the content will still be low.I've already verified cellular speeds were more then enough for playbackI've tried it with the eSIM and nanoSIM Playback through Edge Chromium and Firefox <both of them ARM64 builds> are normal. I would like to use Emby Theater for the better integrated syncing/downloading options and other benefits it provides. Since there already is an official ARM64 build, I'm wondering if some attention can be given to this issue. Thanks for your time.
Luke 42241 Posted March 31, 2020 Posted March 31, 2020 HI there @@ShobuPrime, can we please look at an example? Please attach the information requested in how to report a media playback issue. thanks !
ShobuPrime 0 Posted April 3, 2020 Author Posted April 3, 2020 Good morning Luke, Thanks for the prompt reply. I didn't have the device with me, but now I do, and will get the reports to you after some more testing later on in the day. I just updated my instance on my Synology to 4.4.0.40
ShobuPrime 0 Posted April 4, 2020 Author Posted April 4, 2020 Hey Luke, I've sent you the logs for Emby theater on the Surface Pro X. Thanks.
ShobuPrime 0 Posted April 6, 2020 Author Posted April 6, 2020 (edited) Good afternoon Luke, Yes. I am still running into this issue. The stutter was less, but still existent after the update over cellular playback. The audio is still very low through the app. Once again, it's normal through the ARM64 browsers Edge <Chromium> and Firefox. Is there a way for me to PM you the logs for Emby Theater if you need them? I tried looking in AppData and couldn't find any. Thanks. Edit: To clarify, 5.1 and 7.1 audio sounds low. If I have content in stereo, it's normal. Edited April 6, 2020 by ShobuPrime
Luke 42241 Posted April 28, 2020 Posted April 28, 2020 Ok yes please PM me the requested log files. thanks.
Luke 42241 Posted May 9, 2020 Posted May 9, 2020 @@ShobuPrime are you still running into this? have you updated to Emby Server 4.4.2?
