bretswinney 23 Posted April 2, 2020 Author Posted April 2, 2020 ok thanks for fixing it! Sent from my iPad using Tapatalk
mrterabyte 3 Posted April 2, 2020 Posted April 2, 2020 All working again after update to Version 1.6.10.3, thanks.
bretswinney 23 Posted April 2, 2020 Author Posted April 2, 2020 Any way to add more colors for the user playback because i have more users than colors so it gets confusing? @@TeamB
TeamB 2440 Posted April 2, 2020 Posted April 2, 2020 Ok I will have a look, there might be a way of auto generating them.
bretswinney 23 Posted April 2, 2020 Author Posted April 2, 2020 Ok I will have a look, there might be a way of auto generating them. Thanks! Your plugin is one of the best!
mrterabyte 3 Posted April 3, 2020 Posted April 3, 2020 Just a quick question, would it be possible to add at some point a way to see what users are downloading in addition to what they watch? 1
TeamB 2440 Posted April 3, 2020 Posted April 3, 2020 Just a quick question, would it be possible to add at some point a way to see what users are downloading in addition to what they watch? This is asked a lot, unfortunately it is not a possibility as the download actions and events are not available in the plugin API.
neik 874 Posted April 3, 2020 Posted April 3, 2020 This is asked a lot, unfortunately it is not a possibility as the download actions and events are not available in the plugin API. Maybe something @@Luke can do about it? This would be indeed one nice addition more to an already amazing plugin.
mrterabyte 3 Posted April 3, 2020 Posted April 3, 2020 This is asked a lot, unfortunately it is not a possibility as the download actions and events are not available in the plugin API. No problem, just through I'd ask. Great plugin by the way
TeamB 2440 Posted April 4, 2020 Posted April 4, 2020 Any way to add more colors for the user playback because i have more users than colors so it gets confusing? @@TeamB New version : 1.6.10.4 With not much else to do today due to convid-19 lock downs I spent some time one the colour palette option. I have added a colour palette settings that allows you to manage your own colours. You can edit the ones that are there and add more, re-order them or simply remove all but one have have single colour charts if you want. Please test and let me know if it is working for you.
bretswinney 23 Posted April 4, 2020 Author Posted April 4, 2020 New version : 1.6.10.4 With not much else to do today due to convid-19 lock downs I spent some time one the colour palette option. I have added a colour palette settings that allows you to manage your own colours. You can edit the ones that are there and add more, re-order them or simply remove all but one have have single colour charts if you want. Please test and let me know if it is working for you. Works great any way to assign a color per user. Ex joe watches once a year & shows up & throws off the colors set for other users I have set up. Sent from my iPad using Tapatalk
TeamB 2440 Posted April 4, 2020 Posted April 4, 2020 I have added something to try to solve this, it uses the full user list and assigns colours in alphabetical order even for users that dont have data for the time period you are asking for. This means unless you add or remove users from the Emby system users should always have the same colour assigned in the chart.
bretswinney 23 Posted April 4, 2020 Author Posted April 4, 2020 I have added something to try to solve this, it uses the full user list and assigns colours in alphabetical order even for users that dont have data for the time period you are asking for. This means unless you add or remove users from the Emby system users should always have the same colour assigned in the chart. Now this i what I am seeing
TeamB 2440 Posted April 4, 2020 Posted April 4, 2020 Now this i what I am seeing graph.PNG colors.PNG Ok I will look into it.
TeamB 2440 Posted April 4, 2020 Posted April 4, 2020 Now this i what I am seeing graph.PNG colors.PNG Do you have a lot of users in your Emby system? What number compared to the count showing in this chart?
TeamB 2440 Posted April 4, 2020 Posted April 4, 2020 (edited) @@bretswinney Try this attached build, you will need to unzip it and copy it to your plugins path for the emby server. Then restart Emby server. Bring up the report page and hit the refresh page and in your browser bring up the console log using the F-12 key. Click on the user report again and copy and past the console log to a text file and post it here. you should see some lines like the following in the console log draw_graph called configurationpage:48:17 usage_data: [{"user_id":"3138bed521e5465b9be26d2c63be94af","user_name":"admin","user_usage":{"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":13,"2020-03-27":0,"2020-03-28":0,"2020-03-29":810,"2020-03-30":0,"2020-03-31":0,"2020-04-01":627,"2020-04-02":1189,"2020-04-03":0,"2020-04-04":0,"2020-04-05":0}},{"user_id":"labels_user","user_name":"labels_user","user_usage":{"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0,"2020-04-05":0}}] configurationpage:66:17 user_list: [{"name":"admin","id":"3138bed521e5465b9be26d2c63be94af","in_list":false}] configurationpage:67:17 color_list: ["#679b70","#d98880","#7fb3d5","#76d7c4","#7df1a0","#f7dc6f","#f0b27a","#d7dbdd","#85c1e9","#f1948a"] configurationpage:68:17 user_colour_map: {"admin":"#679b70"} configurationpage:69:17 Chart Done If you do not then something is not updating or refreshing correctly. Edited April 5, 2020 by TeamB
Barlog9511 17 Posted April 4, 2020 Posted April 4, 2020 Thanks for update but new color update is little bit strange I had a dark theme turned on, but more than half of the colors were dark / gray, it wasn't usable so I turned on the light theme. There the colors were already displayed, I tried to change the color settings. As a problem I see that not enough default colors have been generated for users, I have a little bit more in my installation I attach screanshots
bretswinney 23 Posted April 4, 2020 Author Posted April 4, 2020 Do you have a lot of users in your Emby system? What number compared to the count showing in this chart? 12 to 15
bretswinney 23 Posted April 4, 2020 Author Posted April 4, 2020 @@bretswinney Try this attached build, you will need to unzip it and copy it to your plugins path for the emby server. Then restart Emby server. Bring up the report page and hit the refresh page and in your browser bring up the console log using the F-12 key. Click on the user report again and copy and past the console log to a text file and post it here. you should see some lines like the following in the console log draw_graph called configurationpage:48:17 usage_data: [{"user_id":"3138bed521e5465b9be26d2c63be94af","user_name":"admin","user_usage":{"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":13,"2020-03-27":0,"2020-03-28":0,"2020-03-29":810,"2020-03-30":0,"2020-03-31":0,"2020-04-01":627,"2020-04-02":1189,"2020-04-03":0,"2020-04-04":0,"2020-04-05":0}},{"user_id":"labels_user","user_name":"labels_user","user_usage":{"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0,"2020-04-05":0}}] configurationpage:66:17 user_list: [{"name":"admin","id":"3138bed521e5465b9be26d2c63be94af","in_list":false}] configurationpage:67:17 color_list: ["#679b70","#d98880","#7fb3d5","#76d7c4","#7df1a0","#f7dc6f","#f0b27a","#d7dbdd","#85c1e9","#f1948a"] configurationpage:68:17 user_colour_map: {"admin":"#679b70"} configurationpage:69:17 Chart Done If you do not then something is not updating or refreshing correctly. app.js?v=4.5.0.4:1 Setting require baseUrl to http://localhost:8000/web connectionmanager.js?v=4.5.0.4:1 Begin ConnectionManager constructor app.js?v=4.5.0.4:1 loading ApiClient singleton app.js?v=4.5.0.4:1 creating ApiClient singleton apiclient.js?v=4.5.0.4:1 ApiClient serverAddress: http://localhost:8000 apiclient.js?v=4.5.0.4:1 ApiClient appName: Emby Web apiclient.js?v=4.5.0.4:1 ApiClient appVersion: 4.5.0.4 apiclient.js?v=4.5.0.4:1 ApiClient deviceName: Chrome apiclient.js?v=4.5.0.4:1 ApiClient deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc5LjAuMzk0NS4xMzAgU2FmYXJpLzUzNy4zNnwxNTgyNTE1MDUxMjky credentials.js?v=4.5.0.4:1 credentials initialized with: {"Servers":[{"DateLastAccessed":1586027770943,"LastConnectionMode":2,"ManualAddress":"http://localhost:8000","manualAddressOnly":true,"Type":"Server","Name":"SWEMBY","Id":"cd60cfced7fb4107b19560c002480162","LocalAddress":"http://10.0.1.2:8000","RemoteAddress":"http://swemby.ddns.net:443","UserId":"306e0972222343249de708be5d4cf9da","AccessToken":"e34ba543a0434089bfac8db011e6693e"}]} app.js?v=4.5.0.4:1 loaded ApiClient singleton 3manifest.json:1 Manifest: one of 'url' or 'id' is required, related application ignored. app.js?v=4.5.0.4:1 loadFirstLevelPresentationDependencies app.js?v=4.5.0.4:1 loadPlugins app.js?v=4.5.0.4:1 Loading installed plugins pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/playbackvalidation pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/playaccessvalidation pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/experimentalwarnings pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/soundeffects/defaultsoundeffects/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/logoscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/backdropscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/photoscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/htmlaudioplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/htmlvideoplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/photoplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/sessionplayer pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/chromecast/chromecastplayer pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/youtubeplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/confirmstillplaying/plugin router.js?v=4.5.0.4:1 Setting page base to /web connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings app.js?v=4.5.0.4:1 loadExternalScripts app.js?v=4.5.0.4:1 loadHeader registrationservices.js?v=4.5.0.4:1 validateFeature: themes app.js?v=4.5.0.4:1 onAppReady connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info app.js?v=4.5.0.4:1 Loaded dependencies in onAppReady app.js?v=4.5.0.4:1 Defining core routes router.js?v=4.5.0.4:1 Defining route: /startup/connectlogin.html router.js?v=4.5.0.4:1 Defining route: /startup/connectsignup.html router.js?v=4.5.0.4:1 Defining route: /startup/welcome.html router.js?v=4.5.0.4:1 Defining route: /startup/forgotpassword.html router.js?v=4.5.0.4:1 Defining route: /startup/forgotpasswordpin.html router.js?v=4.5.0.4:1 Defining route: /home router.js?v=4.5.0.4:1 Defining route: /home/home.html router.js?v=4.5.0.4:1 Defining route: /home.html router.js?v=4.5.0.4:1 Defining route: /home_horiz/home.html router.js?v=4.5.0.4:1 Defining route: /list/list.html router.js?v=4.5.0.4:1 Defining route: /item router.js?v=4.5.0.4:1 Defining route: /item/item.html router.js?v=4.5.0.4:1 Defining route: /livetv router.js?v=4.5.0.4:1 Defining route: /startup/login.html router.js?v=4.5.0.4:1 Defining route: /startup/manuallogin.html router.js?v=4.5.0.4:1 Defining route: /movies router.js?v=4.5.0.4:1 Defining route: /games router.js?v=4.5.0.4:1 Defining route: /homevideos router.js?v=4.5.0.4:1 Defining route: /musicvideos router.js?v=4.5.0.4:1 Defining route: /music router.js?v=4.5.0.4:1 Defining route: /videoosd/videoosd.html router.js?v=4.5.0.4:1 Defining route: /settings router.js?v=4.5.0.4:1 Defining route: /settings/keyboard.html router.js?v=4.5.0.4:1 Defining route: /settings/playback.html router.js?v=4.5.0.4:1 Defining route: /settings/subtitles.html router.js?v=4.5.0.4:1 Defining route: /settings/display.html router.js?v=4.5.0.4:1 Defining route: /settings/homescreen.html router.js?v=4.5.0.4:1 Defining route: /settings/profile.html router.js?v=4.5.0.4:1 Defining route: /settings/password.html router.js?v=4.5.0.4:1 Defining route: /search router.js?v=4.5.0.4:1 Defining route: /startup/manualserver.html router.js?v=4.5.0.4:1 Defining route: /startup/selectserver.html router.js?v=4.5.0.4:1 Defining route: /tv router.js?v=4.5.0.4:1 Defining route: /plugins/install router.js?v=4.5.0.4:1 Defining route: /dashboard router.js?v=4.5.0.4:1 Defining route: /dashboard.html router.js?v=4.5.0.4:1 Defining route: /dashboardgeneral.html router.js?v=4.5.0.4:1 Defining route: /devices router.js?v=4.5.0.4:1 Defining route: /network router.js?v=4.5.0.4:1 Defining route: /devices/device.html router.js?v=4.5.0.4:1 Defining route: /devices/cameraupload.html router.js?v=4.5.0.4:1 Defining route: /metadatamanager router.js?v=4.5.0.4:1 Defining route: /transcoding router.js?v=4.5.0.4:1 Defining route: /librarysetup/library.html router.js?v=4.5.0.4:1 Defining route: /librarysetup/advanced.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/schedulesdirect.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/xmltv.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/embydata.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/guideprovider.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvsettings.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvstatus.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvtuner.html router.js?v=4.5.0.4:1 Defining route: /logs router.js?v=4.5.0.4:1 Defining route: /metadataadvanced.html router.js?v=4.5.0.4:1 Defining route: /notificationsetting.html router.js?v=4.5.0.4:1 Defining route: /notificationsettings.html router.js?v=4.5.0.4:1 Defining route: /plugins/plugincatalog.html router.js?v=4.5.0.4:1 Defining route: /plugins/plugins.html router.js?v=4.5.0.4:1 Defining route: /scheduledtask router.js?v=4.5.0.4:1 Defining route: /dashboard/releasenotes.html router.js?v=4.5.0.4:1 Defining route: /scheduledtasks router.js?v=4.5.0.4:1 Defining route: /serveractivity router.js?v=4.5.0.4:1 Defining route: /apikeys router.js?v=4.5.0.4:1 Defining route: /embypremiere router.js?v=4.5.0.4:1 Defining route: /syncactivity.html router.js?v=4.5.0.4:1 Defining route: /syncsettings.html router.js?v=4.5.0.4:1 Defining route: /useredit.html router.js?v=4.5.0.4:1 Defining route: /userlibraryaccess.html router.js?v=4.5.0.4:1 Defining route: /usernew.html router.js?v=4.5.0.4:1 Defining route: /userparentalcontrol.html router.js?v=4.5.0.4:1 Defining route: /userpassword.html router.js?v=4.5.0.4:1 Defining route: /users router.js?v=4.5.0.4:1 Defining route: /wizard/wizardagreement.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardremoteaccess.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardfinish.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardlibrary.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardsettings.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardstart.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizarduser.html router.js?v=4.5.0.4:1 Defining route: /configurationpage router.js?v=4.5.0.4:1 Defining route: /index.html router.js?v=4.5.0.4:1 Defining route: / connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient connectionmanager.js?v=4.5.0.4:1 Begin connect connectionmanager.js?v=4.5.0.4:1 Begin getAvailableServers connectionmanager.js?v=4.5.0.4:1 Begin getConnectServers connectionmanager.js?v=4.5.0.4:1 Begin connectToServers, with 1 servers connectionmanager.js?v=4.5.0.4:1 begin connectToServer connectionmanager.js?v=4.5.0.4:1 tryReconnect: http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 tryReconnectToUrl: http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 ConnectionManager requesting url: http://localhost:8000/emby/system/info/public connectionmanager.js?v=4.5.0.4:1 ConnectionManager response status: 200, url: http://localhost:8000/emby/system/info/public connectionmanager.js?v=4.5.0.4:1 ConnectionManager requesting url: http://localhost:8000/emby/System/Info connectionmanager.js?v=4.5.0.4:1 ConnectionManager response status: 200, url: http://localhost:8000/emby/System/Info connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient apiclient.js?v=4.5.0.4:1 Setting server address to http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 calling apiClient.ensureWebSocket apiclient.js?v=4.5.0.4:1 opening web socket with url: ws://localhost:8000/embywebsocket?api_key=e34ba543a0434089bfac8db011e6693e&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc5LjAuMzk0NS4xMzAgU2FmYXJpLzUzNy4zNnwxNTgyNTE1MDUxMjky connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient apiclient.js?v=4.5.0.4:1 web socket connection opened registrationservices.js?v=4.5.0.4:1 validateFeature: themes connectionmanager.js?v=4.5.0.4:1 resolving connectToServers with result.State: SignedIn connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info router.js?v=4.5.0.4:1 appRouter - processing path request /web#!/configurationpage router.js?v=4.5.0.4:1 appRouter - user is authenticated registrationservices.js?v=4.5.0.4:1 validateFeature: themes connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info :8000/emby/Items/Filters?UserId=306e0972222343249de708be5d4cf9da&IncludeItemTypes=Movie&ReportView=ReportData:1 Failed to load resource: the server responded with a status of 404 (Not Found) index.html#!/configurationpage?name=reports:1 Uncaught (in promise) Response chromecastplayer.js?v=4.5.0.4:1 chromecast.initialize chromecastplayer.js?v=4.5.0.4:1 chromecast init success router.js?v=4.5.0.4:1 appRouter - processing path request /web/configurationpage router.js?v=4.5.0.4:1 appRouter - user is authenticated configurationpage?name=activity_report.js&v=4.5.0.4:21 getActivity Url = http://localhost:8000/emby/user_usage_stats/session_list?stamp=1586043941804 configurationpage?name=activity_report.js&v=4.5.0.4:72 activity_data: [{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"device_name":"Chrome","client_name":"Emby Web","app_icon":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","app_version":"4.5.0.4","has_user":true,"user_id":"306e0972222343249de708be5d4cf9da","user_name":"Admin","remote_address":"::1","last_active":"00.00:00:00"},{"TranscodingInfo":{"AudioCodec":"aac","VideoCodec":"h264","Container":"m3u8","IsVideoDirect":false,"IsAudioDirect":true,"Bitrate":5137715,"Framerate":38,"TranscodingPositionTicks":1051000000,"TranscodingStartPositionTicks":0,"Width":1280,"Height":720,"AudioChannels":2,"TranscodeReasons":["ContainerBitrateExceedsLimit],"VideoDecoder":"Automaticsoftware decoder","VideoDecoderIsHardware":false,"VideoDecoderMediaType":"H264","VideoEncoder":"libx264 Software Encoder","VideoEncoderIsHardware":false,"VideoEncoderMediaType":"H.264 (AVC)"},"PlayState":{"PositionTicks":15860439514010000,"CanSeek":false,"IsPaused":false,"IsMuted":false,"AudioStreamIndex":-1,"SubtitleStreamIndex":-1,"MediaSourceId":"22f1502d1fcd0e726979cd373ae6bd90","PlayMethod":"Transcode","RepeatMode":"RepeatNone"},"NowPlayingItem":{"Name":"EVENTS 1: 6PM WWE Wrestlemania 36","ServerId":"cd60cfced7fb4107b19560c002480162","Id":"678592","DateCreated":"2020-04-04T23:01:36.0000000+00:00","PresentationUniqueKey":"eaf359954a86978ca6f26ee8318b0b8b","ExternalUrls":[],"Taglines":[],"Genres":[],"Number":"460","ChannelNumber":"460","ProviderIds":{"ExternalServiceId":"Emby"},"IsFolder":false,"ParentId":"52","Type":"TvChannel","Studios":[],"GenreItems":[],"MediaStreams":[{"Codec":"h264","StreamStartTimeTicks":592000670000,"TimeBase":"1/90000","CodecTimeBase":"1/60","VideoRange":"SDR","DisplayTitle":"720p H264","NalLengthSize":"0","IsInterlaced":false,"BitRate":8000000,"BitDepth":8,"RefFrames":1,"IsDefault":false,"IsForced":false,"Height":720,"Width":1280,"AverageFrameRate":30,"RealFrameRate":30,"Profile":"High","Type":"Video","AspectRatio":"16:9","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File","PixelFormat":"yuv420p","Level":41,"IsAnamorphic":false},{"Codec":"aac","StreamStartTimeTicks":592000026670,"TimeBase":"1/90000","CodecTimeBase":"1/48000","DisplayTitle":"AAC stereo","IsInterlaced":false,"ChannelLayout":"stereo","BitRate":127875,"Channels":2,"SampleRate":48000,"IsDefault":false,"IsForced":false,"Profile":"LC","Type":"Audio","Index":-1,"IsExternal":false,"IsTextSubtitleStream":false,"SupportsExternalStream":false,"Protocol":"File"}],"ImageTags":{},"BackdropImageTags":[],"MediaType":"Video"},"device_name":"Robert's 2nd Fire TV","client_name":"AndroidTv","app_icon":"https://mediabrowser.github.io/Emby.AndroidTv/appicon.png","app_version":"1.7.92a","has_user":true,"user_id":"1ff0eb079f354e5b840da99d468a0cb4","user_name":"Mullinsrobert","has_image":"e247f848b1033d2b3404e0ee978f50a4","remote_address":"47.219.114.79","last_active":"00.00:00:00"},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"device_name":"Chrome","client_name":"Emby Web","app_icon":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","app_version":"4.5.0.4","has_user":true,"user_id":"ed9c6733140e41c3a61bfed99e568a55","user_name":"Bret","has_image":"b38520753b5b71a4f98205cc63ac2fa3","remote_address":"24.31.17.159","last_active":"00.00:00:01"},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"client_name":"DLNA","app_version":"4.5.0.4","has_user":false,"remote_address":"10.0.1.227","last_active":"00.00:01:26"},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"client_name":"DLNA","app_version":"4.5.0.4","has_user":false,"remote_address":"10.0.1.205","last_active":"00.00:01:26"}] index.html#!/configurationpage?name=activity_report:1 A cookie associated with a cross-site resource at http://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032. index.html#!/configurationpage?name=activity_report:1 A cookie associated with a cross-site resource at https://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032. router.js?v=4.5.0.4:1 appRouter - processing path request /web/configurationpage router.js?v=4.5.0.4:1 appRouter - user is authenticated configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/type_filter_list configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/user_list?stamp=1586043948923 configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/PlayActivity?filter=Episode,Movie,Audio,TvChannel,Trailer,Video,Recording&days=28&end_date=2020-04-04&data_type=time&stamp=1586043948923 configurationpage?name=user_playback_report.js&v=4.5.0.4:48 draw_graph called configurationpage?name=user_playback_report.js&v=4.5.0.4:66 usage_data: [{"user_id":"85adb93fb100430ca6a254b6f5ccd26e","user_name":"AHH_IT","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":16,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":5717,"2020-04-03":18898,"2020-04-04":0}},{"user_id":"ed9c6733140e41c3a61bfed99e568a55","user_name":"Bret","user_usage":{"2020-03-08":8742,"2020-03-09":7575,"2020-03-10":5095,"2020-03-11":15689,"2020-03-12":11553,"2020-03-13":14404,"2020-03-14":17834,"2020-03-15":24925,"2020-03-16":15302,"2020-03-17":15654,"2020-03-18":2450,"2020-03-19":7605,"2020-03-20":7063,"2020-03-21":20281,"2020-03-22":16239,"2020-03-23":1090,"2020-03-24":8422,"2020-03-25":0,"2020-03-26":5272,"2020-03-27":5410,"2020-03-28":16687,"2020-03-29":8355,"2020-03-30":0,"2020-03-31":0,"2020-04-01":4450,"2020-04-02":17313,"2020-04-03":24311,"2020-04-04":9304}},{"user_id":"7dbddfe2f7be4d4bb2be8d6f4a5e7fb4","user_name":"Drew","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":2649,"2020-03-11":5125,"2020-03-12":2658,"2020-03-13":6383,"2020-03-14":1762,"2020-03-15":2974,"2020-03-16":2031,"2020-03-17":0,"2020-03-18":0,"2020-03-19":49,"2020-03-20":0,"2020-03-21":421,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":301,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"3d73e004459344469cbdece9be9dde35","user_name":"Garry","user_usage":{"2020-03-08":11424,"2020-03-09":172,"2020-03-10":0,"2020-03-11":0,"2020-03-12":2245,"2020-03-13":0,"2020-03-14":15633,"2020-03-15":3957,"2020-03-16":11300,"2020-03-17":13121,"2020-03-18":16376,"2020-03-19":5124,"2020-03-20":1220,"2020-03-21":0,"2020-03-22":1080,"2020-03-23":6801,"2020-03-24":0,"2020-03-25":0,"2020-03-26":5309,"2020-03-27":12863,"2020-03-28":1324,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":2752,"2020-04-02":451,"2020-04-03":254,"2020-04-04":6022}},{"user_id":"b2a620b4729c454d81fb4b4cba6d15de","user_name":"jeluna979","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":41,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":9,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"e38645e79f474bac9b97e37481b48f4a","user_name":"jpluna","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":6806,"2020-03-12":12253,"2020-03-13":1310,"2020-03-14":1373,"2020-03-15":5230,"2020-03-16":5626,"2020-03-17":239,"2020-03-18":920,"2020-03-19":43,"2020-03-20":0,"2020-03-21":758,"2020-03-22":120,"2020-03-23":0,"2020-03-24":4223,"2020-03-25":2410,"2020-03-26":0,"2020-03-27":33,"2020-03-28":4886,"2020-03-29":22,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":5873,"2020-04-04":0}},{"user_id":"76bfb2ad2d8742bf8d381b12e525d80c","user_name":"Kamdyn","user_usage":{"2020-03-08":27953,"2020-03-09":0,"2020-03-10":48968,"2020-03-11":9819,"2020-03-12":24182,"2020-03-13":34212,"2020-03-14":12436,"2020-03-15":23640,"2020-03-16":20243,"2020-03-17":16078,"2020-03-18":4934,"2020-03-19":1130,"2020-03-20":1799,"2020-03-21":4949,"2020-03-22":3588,"2020-03-23":9638,"2020-03-24":6629,"2020-03-25":14165,"2020-03-26":3964,"2020-03-27":13716,"2020-03-28":0,"2020-03-29":4610,"2020-03-30":0,"2020-03-31":0,"2020-04-01":3987,"2020-04-02":7507,"2020-04-03":17243,"2020-04-04":8358}},{"user_id":"8b6b4e0644174e558553e86e319d14ac","user_name":"KK","user_usage":{"2020-03-08":13248,"2020-03-09":4453,"2020-03-10":12520,"2020-03-11":4130,"2020-03-12":0,"2020-03-13":11921,"2020-03-14":7763,"2020-03-15":7927,"2020-03-16":10006,"2020-03-17":2908,"2020-03-18":0,"2020-03-19":1186,"2020-03-20":1381,"2020-03-21":7992,"2020-03-22":4807,"2020-03-23":2454,"2020-03-24":1337,"2020-03-25":11786,"2020-03-26":17924,"2020-03-27":5476,"2020-03-28":12859,"2020-03-29":5504,"2020-03-30":0,"2020-03-31":0,"2020-04-01":185,"2020-04-02":12075,"2020-04-03":3240,"2020-04-04":4811}},{"user_id":"labels_user","user_name":"labels_user","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"9cc27651973f4c08a3a9541aba4f999b","user_name":"Micah & Noah","user_usage":{"2020-03-08":0,"2020-03-09":5159,"2020-03-10":7455,"2020-03-11":0,"2020-03-12":1046,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":1996,"2020-03-17":3811,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":58,"2020-03-28":0,"2020-03-29":2687,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"1ff0eb079f354e5b840da99d468a0cb4","user_name":"Mullinsrobert","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":43,"2020-04-02":15445,"2020-04-03":0,"2020-04-04":5170}},{"user_id":"5f46b1625972423e8a05232964f4a921","user_name":"Vincent83","user_usage":{"2020-03-08":20966,"2020-03-09":22039,"2020-03-10":4832,"2020-03-11":9170,"2020-03-12":2014,"2020-03-13":10251,"2020-03-14":9810,"2020-03-15":17732,"2020-03-16":1486,"2020-03-17":2133,"2020-03-18":0,"2020-03-19":4528,"2020-03-20":0,"2020-03-21":7935,"2020-03-22":2455,"2020-03-23":2438,"2020-03-24":5465,"2020-03-25":3415,"2020-03-26":2937,"2020-03-27":4053,"2020-03-28":7583,"2020-03-29":16326,"2020-03-30":0,"2020-03-31":0,"2020-04-01":26540,"2020-04-02":80029,"2020-04-03":67689,"2020-04-04":2673}}] configurationpage?name=user_playback_report.js&v=4.5.0.4:67 user_list: [{"name":"Bret","id":"ed9c6733140e41c3a61bfed99e568a55","in_list":false},{"name":"Admin","id":"306e0972222343249de708be5d4cf9da","in_list":true},{"name":"Drew","id":"7dbddfe2f7be4d4bb2be8d6f4a5e7fb4","in_list":false},{"name":"Garry","id":"3d73e004459344469cbdece9be9dde35","in_list":false},{"name":"Kamdyn","id":"76bfb2ad2d8742bf8d381b12e525d80c","in_list":false},{"name":"KK","id":"8b6b4e0644174e558553e86e319d14ac","in_list":false},{"name":"Micah & Noah","id":"9cc27651973f4c08a3a9541aba4f999b","in_list":false},{"name":"Patrice","id":"bb493aabbdf34bd0a22a261cd652194f","in_list":false},{"name":"Mullinsrobert","id":"1ff0eb079f354e5b840da99d468a0cb4","in_list":false},{"name":"Vincent83","id":"5f46b1625972423e8a05232964f4a921","in_list":false},{"name":"jpluna","id":"e38645e79f474bac9b97e37481b48f4a","in_list":false},{"name":"jeluna979","id":"b2a620b4729c454d81fb4b4cba6d15de","in_list":false},{"name":"Ashley Minton","id":"297a715112654fcc99003fc247727adc","in_list":false},{"name":"Beckham","id":"05703c4e0a4d4703b234a391c8ac2036","in_list":false},{"name":"Ashley Swinney","id":"302e721125064a098b802c7cc3a47c96","in_list":false},{"name":"Tyler","id":"58ce3cdd62744258b6b02574dab538f9","in_list":false},{"name":"AHH_IT","id":"85adb93fb100430ca6a254b6f5ccd26e","in_list":false}] configurationpage?name=user_playback_report.js&v=4.5.0.4:68 color_list: ["#ff0000","#ffff00","#85da00","#7d002b","#00007e","#d67000","#00b27a","#8d00ff","#ff008a","#008080","#d82b23","#85c1ff","#0000ff","#ff00ff","#00ff00"] configurationpage?name=user_playback_report.js&v=4.5.0.4:69 user_colour_map: {"AHH_IT":"#ff0000","Admin":"#ffff00","Ashley Minton":"#85da00","Ashley Swinney":"#7d002b","Beckham":"#00007e","Bret":"#d67000","Drew":"#00b27a","Garry":"#8d00ff","KK":"#ff008a","Kamdyn":"#008080","Micah & Noah":"#d82b23","Mullinsrobert":"#85c1ff","Patrice":"#0000ff","Tyler":"#ff00ff","Vincent83":"#00ff00"} configurationpage?name=user_playback_report.js&v=4.5.0.4:249 Chart Done
TeamB 2440 Posted April 5, 2020 Posted April 5, 2020 Thanks for update but new color update is little bit strange I had a dark theme turned on, but more than half of the colors were dark / gray, it wasn't usable so I turned on the light theme. There the colors were already displayed, I tried to change the color settings. As a problem I see that not enough default colors have been generated for users, I have a little bit more in my installation I attach screanshots Snímka obrazovky 2020-04-05 o 1.23.08.png Snímka obrazovky 2020-04-05 o 1.26.49.png you can compare your chart with @@bretswinney from the prev page, they both have the same problem I am looking into now.
TeamB 2440 Posted April 5, 2020 Posted April 5, 2020 @@bretswinney can you try the attached build of the plugin, same process, extract, copy, restart, refresh etc playback_reporting.zip
bretswinney 23 Posted April 5, 2020 Author Posted April 5, 2020 @@bretswinney can you try the attached build of the plugin, same process, extract, copy, restart, refresh etc app.js?v=4.5.0.4:1 Setting require baseUrl to http://localhost:8000/web connectionmanager.js?v=4.5.0.4:1 Begin ConnectionManager constructor app.js?v=4.5.0.4:1 loading ApiClient singleton app.js?v=4.5.0.4:1 creating ApiClient singleton apiclient.js?v=4.5.0.4:1 ApiClient serverAddress: http://localhost:8000 apiclient.js?v=4.5.0.4:1 ApiClient appName: Emby Web apiclient.js?v=4.5.0.4:1 ApiClient appVersion: 4.5.0.4 apiclient.js?v=4.5.0.4:1 ApiClient deviceName: Chrome apiclient.js?v=4.5.0.4:1 ApiClient deviceId: TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc5LjAuMzk0NS4xMzAgU2FmYXJpLzUzNy4zNnwxNTgyNTE1MDUxMjky credentials.js?v=4.5.0.4:1 credentials initialized with: {"Servers":[{"DateLastAccessed":1586052516109,"LastConnectionMode":2,"ManualAddress":"http://localhost:8000","manualAddressOnly":true,"Type":"Server","Name":"SWEMBY","Id":"cd60cfced7fb4107b19560c002480162","LocalAddress":"http://10.0.1.2:8000","RemoteAddress":"http://swemby.ddns.net:443","UserId":"306e0972222343249de708be5d4cf9da","AccessToken":"e34ba543a0434089bfac8db011e6693e"}]} app.js?v=4.5.0.4:1 loaded ApiClient singleton 3manifest.json:1 Manifest: one of 'url' or 'id' is required, related application ignored. app.js?v=4.5.0.4:1 loadFirstLevelPresentationDependencies app.js?v=4.5.0.4:1 loadPlugins app.js?v=4.5.0.4:1 Loading installed plugins pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/playbackvalidation pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/playaccessvalidation pluginmanager.js?v=4.5.0.4:1 Loading plugin: bower_components/emby-webcomponents/playback/experimentalwarnings pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/soundeffects/defaultsoundeffects/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/logoscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/backdropscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/photoscreensaver/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/htmlaudioplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/htmlvideoplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/photoplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/sessionplayer pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/chromecast/chromecastplayer pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/youtubeplayer/plugin pluginmanager.js?v=4.5.0.4:1 Loading plugin: modules/confirmstillplaying/plugin router.js?v=4.5.0.4:1 Setting page base to /web connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings pluginmanager.js?v=4.5.0.4:1 creating plugin instance pluginmanager.js?v=4.5.0.4:1 setting require config pluginmanager.js?v=4.5.0.4:1 loading plugin strings app.js?v=4.5.0.4:1 loadExternalScripts app.js?v=4.5.0.4:1 loadHeader registrationservices.js?v=4.5.0.4:1 validateFeature: themes app.js?v=4.5.0.4:1 onAppReady connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info app.js?v=4.5.0.4:1 Loaded dependencies in onAppReady app.js?v=4.5.0.4:1 Defining core routes router.js?v=4.5.0.4:1 Defining route: /startup/connectlogin.html router.js?v=4.5.0.4:1 Defining route: /startup/connectsignup.html router.js?v=4.5.0.4:1 Defining route: /startup/welcome.html router.js?v=4.5.0.4:1 Defining route: /startup/forgotpassword.html router.js?v=4.5.0.4:1 Defining route: /startup/forgotpasswordpin.html router.js?v=4.5.0.4:1 Defining route: /home router.js?v=4.5.0.4:1 Defining route: /home/home.html router.js?v=4.5.0.4:1 Defining route: /home.html router.js?v=4.5.0.4:1 Defining route: /home_horiz/home.html router.js?v=4.5.0.4:1 Defining route: /list/list.html router.js?v=4.5.0.4:1 Defining route: /item router.js?v=4.5.0.4:1 Defining route: /item/item.html router.js?v=4.5.0.4:1 Defining route: /livetv router.js?v=4.5.0.4:1 Defining route: /startup/login.html router.js?v=4.5.0.4:1 Defining route: /startup/manuallogin.html router.js?v=4.5.0.4:1 Defining route: /movies router.js?v=4.5.0.4:1 Defining route: /games router.js?v=4.5.0.4:1 Defining route: /homevideos router.js?v=4.5.0.4:1 Defining route: /musicvideos router.js?v=4.5.0.4:1 Defining route: /music router.js?v=4.5.0.4:1 Defining route: /videoosd/videoosd.html router.js?v=4.5.0.4:1 Defining route: /settings router.js?v=4.5.0.4:1 Defining route: /settings/keyboard.html router.js?v=4.5.0.4:1 Defining route: /settings/playback.html router.js?v=4.5.0.4:1 Defining route: /settings/subtitles.html router.js?v=4.5.0.4:1 Defining route: /settings/display.html router.js?v=4.5.0.4:1 Defining route: /settings/homescreen.html router.js?v=4.5.0.4:1 Defining route: /settings/profile.html router.js?v=4.5.0.4:1 Defining route: /settings/password.html router.js?v=4.5.0.4:1 Defining route: /search router.js?v=4.5.0.4:1 Defining route: /startup/manualserver.html router.js?v=4.5.0.4:1 Defining route: /startup/selectserver.html router.js?v=4.5.0.4:1 Defining route: /tv router.js?v=4.5.0.4:1 Defining route: /plugins/install router.js?v=4.5.0.4:1 Defining route: /dashboard router.js?v=4.5.0.4:1 Defining route: /dashboard.html router.js?v=4.5.0.4:1 Defining route: /dashboardgeneral.html router.js?v=4.5.0.4:1 Defining route: /devices router.js?v=4.5.0.4:1 Defining route: /network router.js?v=4.5.0.4:1 Defining route: /devices/device.html router.js?v=4.5.0.4:1 Defining route: /devices/cameraupload.html router.js?v=4.5.0.4:1 Defining route: /metadatamanager router.js?v=4.5.0.4:1 Defining route: /transcoding router.js?v=4.5.0.4:1 Defining route: /librarysetup/library.html router.js?v=4.5.0.4:1 Defining route: /librarysetup/advanced.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/schedulesdirect.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/xmltv.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/embydata.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/guideprovider.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvsettings.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvstatus.html router.js?v=4.5.0.4:1 Defining route: /livetvsetup/livetvtuner.html router.js?v=4.5.0.4:1 Defining route: /logs router.js?v=4.5.0.4:1 Defining route: /metadataadvanced.html router.js?v=4.5.0.4:1 Defining route: /notificationsetting.html router.js?v=4.5.0.4:1 Defining route: /notificationsettings.html router.js?v=4.5.0.4:1 Defining route: /plugins/plugincatalog.html router.js?v=4.5.0.4:1 Defining route: /plugins/plugins.html router.js?v=4.5.0.4:1 Defining route: /scheduledtask router.js?v=4.5.0.4:1 Defining route: /dashboard/releasenotes.html router.js?v=4.5.0.4:1 Defining route: /scheduledtasks router.js?v=4.5.0.4:1 Defining route: /serveractivity router.js?v=4.5.0.4:1 Defining route: /apikeys router.js?v=4.5.0.4:1 Defining route: /embypremiere router.js?v=4.5.0.4:1 Defining route: /syncactivity.html router.js?v=4.5.0.4:1 Defining route: /syncsettings.html router.js?v=4.5.0.4:1 Defining route: /useredit.html router.js?v=4.5.0.4:1 Defining route: /userlibraryaccess.html router.js?v=4.5.0.4:1 Defining route: /usernew.html router.js?v=4.5.0.4:1 Defining route: /userparentalcontrol.html router.js?v=4.5.0.4:1 Defining route: /userpassword.html router.js?v=4.5.0.4:1 Defining route: /users router.js?v=4.5.0.4:1 Defining route: /wizard/wizardagreement.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardremoteaccess.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardfinish.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardlibrary.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardsettings.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizardstart.html router.js?v=4.5.0.4:1 Defining route: /wizard/wizarduser.html router.js?v=4.5.0.4:1 Defining route: /configurationpage router.js?v=4.5.0.4:1 Defining route: /index.html router.js?v=4.5.0.4:1 Defining route: / connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient connectionmanager.js?v=4.5.0.4:1 Begin connect connectionmanager.js?v=4.5.0.4:1 Begin getAvailableServers connectionmanager.js?v=4.5.0.4:1 Begin getConnectServers connectionmanager.js?v=4.5.0.4:1 Begin connectToServers, with 1 servers connectionmanager.js?v=4.5.0.4:1 begin connectToServer connectionmanager.js?v=4.5.0.4:1 tryReconnect: http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 tryReconnectToUrl: http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 ConnectionManager requesting url: http://localhost:8000/emby/system/info/public connectionmanager.js?v=4.5.0.4:1 ConnectionManager response status: 200, url: http://localhost:8000/emby/system/info/public connectionmanager.js?v=4.5.0.4:1 ConnectionManager requesting url: http://localhost:8000/emby/System/Info connectionmanager.js?v=4.5.0.4:1 ConnectionManager response status: 200, url: http://localhost:8000/emby/System/Info connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient apiclient.js?v=4.5.0.4:1 Setting server address to http://localhost:8000 connectionmanager.js?v=4.5.0.4:1 calling apiClient.ensureWebSocket apiclient.js?v=4.5.0.4:1 opening web socket with url: ws://localhost:8000/embywebsocket?api_key=e34ba543a0434089bfac8db011e6693e&deviceId=TW96aWxsYS81LjAgKFdpbmRvd3MgTlQgMTAuMDsgV2luNjQ7IHg2NCkgQXBwbGVXZWJLaXQvNTM3LjM2IChLSFRNTCwgbGlrZSBHZWNrbykgQ2hyb21lLzc5LjAuMzk0NS4xMzAgU2FmYXJpLzUzNy4zNnwxNTgyNTE1MDUxMjky connectionmanager.js?v=4.5.0.4:1 returning instance from getOrAddApiClient apiclient.js?v=4.5.0.4:1 web socket connection opened registrationservices.js?v=4.5.0.4:1 validateFeature: themes connectionmanager.js?v=4.5.0.4:1 resolving connectToServers with result.State: SignedIn connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info router.js?v=4.5.0.4:1 appRouter - processing path request /web#!/configurationpage router.js?v=4.5.0.4:1 appRouter - user is authenticated registrationservices.js?v=4.5.0.4:1 validateFeature: themes configurationpage?name=activity_report.js&v=4.5.0.4:21 getActivity Url = http://localhost:8000/emby/user_usage_stats/session_list?stamp=1586052529542 connectionmanager.js?v=4.5.0.4:1 getRegistrationInfo returning cached info configurationpage?name=activity_report.js&v=4.5.0.4:72 activity_data: [{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"device_name":"Chrome","client_name":"Emby Web","app_icon":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","app_version":"4.5.0.4","has_user":true,"user_id":"306e0972222343249de708be5d4cf9da","user_name":"Admin","remote_address":"::1","last_active":"00.00:00:00"},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"device_name":"Chrome","client_name":"EmbyWeb","app_icon":"https://github.com/MediaBrowser/Emby.Resources/raw/master/images/devices/chrome.png","app_version":"4.5.0.4","has_user":true,"user_id":"ed9c6733140e41c3a61bfed99e568a55","user_name":"Bret","has_image":"b38520753b5b71a4f98205cc63ac2fa3","remote_address":"24.31.17.159","last_active":"00.00:00:00"},{"PlayState":{"CanSeek":false,"IsPaused":false,"IsMuted":false,"RepeatMode":"RepeatNone"},"client_name":"DLNA","app_version":"4.5.0.4","has_user":false,"remote_address":"10.0.1.205","last_active":"00.00:00:12"}] index.html#!/configurationpage?name=activity_report:1 A cookie associated with a cross-site resource at http://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032. index.html#!/configurationpage?name=activity_report:1 A cookie associated with a cross-site resource at https://github.com/ was set without the `SameSite` attribute. A future release of Chrome will only deliver cookies with cross-site requests if they are set with `SameSite=None` and `Secure`. You can review cookies in developer tools under Application>Storage>Cookies and see more details at https://www.chromestatus.com/feature/5088147346030592 and https://www.chromestatus.com/feature/5633521622188032. chromecastplayer.js?v=4.5.0.4:1 chromecast.initialize chromecastplayer.js?v=4.5.0.4:1 chromecast init success router.js?v=4.5.0.4:1 appRouter - processing path request /web/configurationpage router.js?v=4.5.0.4:1 appRouter - user is authenticated configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/type_filter_list configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/user_list?stamp=1586052538684 configurationpage?name=user_playback_report.js&v=4.5.0.4:25 getUserActivity Url = http://localhost:8000/emby/user_usage_stats/PlayActivity?filter=Episode,Movie,Audio,TvChannel,Trailer,Video,Recording&days=28&end_date=2020-04-04&data_type=time&stamp=1586052538683 configurationpage?name=user_playback_report.js&v=4.5.0.4:48 draw_graph called configurationpage?name=user_playback_report.js&v=4.5.0.4:67 usage_data: [{"user_id":"85adb93fb100430ca6a254b6f5ccd26e","user_name":"AHH_IT","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":16,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":5717,"2020-04-03":18898,"2020-04-04":0}},{"user_id":"ed9c6733140e41c3a61bfed99e568a55","user_name":"Bret","user_usage":{"2020-03-08":8742,"2020-03-09":7575,"2020-03-10":5095,"2020-03-11":15689,"2020-03-12":11553,"2020-03-13":14404,"2020-03-14":17834,"2020-03-15":24925,"2020-03-16":15302,"2020-03-17":15654,"2020-03-18":2450,"2020-03-19":7605,"2020-03-20":7063,"2020-03-21":20281,"2020-03-22":16239,"2020-03-23":1090,"2020-03-24":8422,"2020-03-25":0,"2020-03-26":5272,"2020-03-27":5410,"2020-03-28":16687,"2020-03-29":8355,"2020-03-30":0,"2020-03-31":0,"2020-04-01":4450,"2020-04-02":17313,"2020-04-03":24311,"2020-04-04":9304}},{"user_id":"7dbddfe2f7be4d4bb2be8d6f4a5e7fb4","user_name":"Drew","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":2649,"2020-03-11":5125,"2020-03-12":2658,"2020-03-13":6383,"2020-03-14":1762,"2020-03-15":2974,"2020-03-16":2031,"2020-03-17":0,"2020-03-18":0,"2020-03-19":49,"2020-03-20":0,"2020-03-21":421,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":301,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"3d73e004459344469cbdece9be9dde35","user_name":"Garry","user_usage":{"2020-03-08":11424,"2020-03-09":172,"2020-03-10":0,"2020-03-11":0,"2020-03-12":2245,"2020-03-13":0,"2020-03-14":15633,"2020-03-15":3957,"2020-03-16":11300,"2020-03-17":13121,"2020-03-18":16376,"2020-03-19":5124,"2020-03-20":1220,"2020-03-21":0,"2020-03-22":1080,"2020-03-23":6801,"2020-03-24":0,"2020-03-25":0,"2020-03-26":5309,"2020-03-27":12863,"2020-03-28":1324,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":2752,"2020-04-02":451,"2020-04-03":254,"2020-04-04":6022}},{"user_id":"b2a620b4729c454d81fb4b4cba6d15de","user_name":"jeluna979","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":41,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":9,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"e38645e79f474bac9b97e37481b48f4a","user_name":"jpluna","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":6806,"2020-03-12":12253,"2020-03-13":1310,"2020-03-14":1373,"2020-03-15":5230,"2020-03-16":5626,"2020-03-17":239,"2020-03-18":920,"2020-03-19":43,"2020-03-20":0,"2020-03-21":758,"2020-03-22":120,"2020-03-23":0,"2020-03-24":4223,"2020-03-25":2410,"2020-03-26":0,"2020-03-27":33,"2020-03-28":4886,"2020-03-29":22,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":5873,"2020-04-04":0}},{"user_id":"76bfb2ad2d8742bf8d381b12e525d80c","user_name":"Kamdyn","user_usage":{"2020-03-08":27953,"2020-03-09":0,"2020-03-10":48968,"2020-03-11":9819,"2020-03-12":24182,"2020-03-13":34212,"2020-03-14":12436,"2020-03-15":23640,"2020-03-16":20243,"2020-03-17":16078,"2020-03-18":4934,"2020-03-19":1130,"2020-03-20":1799,"2020-03-21":4949,"2020-03-22":3588,"2020-03-23":9638,"2020-03-24":6629,"2020-03-25":14165,"2020-03-26":3964,"2020-03-27":13716,"2020-03-28":0,"2020-03-29":4610,"2020-03-30":0,"2020-03-31":0,"2020-04-01":3987,"2020-04-02":7507,"2020-04-03":17243,"2020-04-04":8358}},{"user_id":"8b6b4e0644174e558553e86e319d14ac","user_name":"KK","user_usage":{"2020-03-08":13248,"2020-03-09":4453,"2020-03-10":12520,"2020-03-11":4130,"2020-03-12":0,"2020-03-13":11921,"2020-03-14":7763,"2020-03-15":7927,"2020-03-16":10006,"2020-03-17":2908,"2020-03-18":0,"2020-03-19":1186,"2020-03-20":1381,"2020-03-21":7992,"2020-03-22":4807,"2020-03-23":2454,"2020-03-24":1337,"2020-03-25":11786,"2020-03-26":17924,"2020-03-27":5476,"2020-03-28":12859,"2020-03-29":5504,"2020-03-30":0,"2020-03-31":0,"2020-04-01":185,"2020-04-02":12075,"2020-04-03":3240,"2020-04-04":4811}},{"user_id":"labels_user","user_name":"labels_user","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"9cc27651973f4c08a3a9541aba4f999b","user_name":"Micah & Noah","user_usage":{"2020-03-08":0,"2020-03-09":5159,"2020-03-10":7455,"2020-03-11":0,"2020-03-12":1046,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":1996,"2020-03-17":3811,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":58,"2020-03-28":0,"2020-03-29":2687,"2020-03-30":0,"2020-03-31":0,"2020-04-01":0,"2020-04-02":0,"2020-04-03":0,"2020-04-04":0}},{"user_id":"1ff0eb079f354e5b840da99d468a0cb4","user_name":"Mullinsrobert","user_usage":{"2020-03-08":0,"2020-03-09":0,"2020-03-10":0,"2020-03-11":0,"2020-03-12":0,"2020-03-13":0,"2020-03-14":0,"2020-03-15":0,"2020-03-16":0,"2020-03-17":0,"2020-03-18":0,"2020-03-19":0,"2020-03-20":0,"2020-03-21":0,"2020-03-22":0,"2020-03-23":0,"2020-03-24":0,"2020-03-25":0,"2020-03-26":0,"2020-03-27":0,"2020-03-28":0,"2020-03-29":0,"2020-03-30":0,"2020-03-31":0,"2020-04-01":43,"2020-04-02":15445,"2020-04-03":0,"2020-04-04":12921}},{"user_id":"5f46b1625972423e8a05232964f4a921","user_name":"Vincent83","user_usage":{"2020-03-08":20966,"2020-03-09":22039,"2020-03-10":4832,"2020-03-11":9170,"2020-03-12":2014,"2020-03-13":10251,"2020-03-14":9810,"2020-03-15":17732,"2020-03-16":1486,"2020-03-17":2133,"2020-03-18":0,"2020-03-19":4528,"2020-03-20":0,"2020-03-21":7935,"2020-03-22":2455,"2020-03-23":2438,"2020-03-24":5465,"2020-03-25":3415,"2020-03-26":2937,"2020-03-27":4053,"2020-03-28":7583,"2020-03-29":16326,"2020-03-30":0,"2020-03-31":0,"2020-04-01":26540,"2020-04-02":80029,"2020-04-03":67689,"2020-04-04":2673}}] configurationpage?name=user_playback_report.js&v=4.5.0.4:68 user_list: [{"name":"Bret","id":"ed9c6733140e41c3a61bfed99e568a55","in_list":false},{"name":"Admin","id":"306e0972222343249de708be5d4cf9da","in_list":true},{"name":"Drew","id":"7dbddfe2f7be4d4bb2be8d6f4a5e7fb4","in_list":false},{"name":"Garry","id":"3d73e004459344469cbdece9be9dde35","in_list":false},{"name":"Kamdyn","id":"76bfb2ad2d8742bf8d381b12e525d80c","in_list":false},{"name":"KK","id":"8b6b4e0644174e558553e86e319d14ac","in_list":false},{"name":"Micah & Noah","id":"9cc27651973f4c08a3a9541aba4f999b","in_list":false},{"name":"Patrice","id":"bb493aabbdf34bd0a22a261cd652194f","in_list":false},{"name":"Mullinsrobert","id":"1ff0eb079f354e5b840da99d468a0cb4","in_list":false},{"name":"Vincent83","id":"5f46b1625972423e8a05232964f4a921","in_list":false},{"name":"jpluna","id":"e38645e79f474bac9b97e37481b48f4a","in_list":false},{"name":"jeluna979","id":"b2a620b4729c454d81fb4b4cba6d15de","in_list":false},{"name":"Ashley Minton","id":"297a715112654fcc99003fc247727adc","in_list":false},{"name":"Beckham","id":"05703c4e0a4d4703b234a391c8ac2036","in_list":false},{"name":"Ashley Swinney","id":"302e721125064a098b802c7cc3a47c96","in_list":false},{"name":"Tyler","id":"58ce3cdd62744258b6b02574dab538f9","in_list":false},{"name":"AHH_IT","id":"85adb93fb100430ca6a254b6f5ccd26e","in_list":false}] configurationpage?name=user_playback_report.js&v=4.5.0.4:69 full_user_list: ["AHH_IT","Admin","Ashley Minton","Ashley Swinney","Beckham","Bret","Drew","Garry","KK","Kamdyn","Micah & Noah","Mullinsrobert","Patrice","Tyler","Vincent83","jeluna979","jpluna"] configurationpage?name=user_playback_report.js&v=4.5.0.4:70 color_list: ["#ff0000","#ffff00","#85da00","#7d002b","#00007e","#d67000","#00b27a","#8d00ff","#ff008a","#008080","#d82b23","#85c1ff","#0000ff","#ff00ff","#00ff00"] configurationpage?name=user_playback_report.js&v=4.5.0.4:71 user_colour_map: {"AHH_IT":"#ff0000","Admin":"#ffff00","Ashley Minton":"#85da00","Ashley Swinney":"#7d002b","Beckham":"#00007e","Bret":"#d67000","Drew":"#00b27a","Garry":"#8d00ff","KK":"#ff008a","Kamdyn":"#008080","Micah & Noah":"#d82b23","Mullinsrobert":"#85c1ff","Patrice":"#0000ff","Tyler":"#ff00ff","Vincent83":"#00ff00","jeluna979":"#ff0000","jpluna":"#ffff00"} configurationpage?name=user_playback_report.js&v=4.5.0.4:251 Chart Done
