CAS 1 Posted March 31, 2020 Posted March 31, 2020 Hi I have a 3 disc bluray of 3 seperate concerts from one event, i have them ripped into a folder and named disc 1 , disc 2 etc. In the web client and ios app they show perfectly with Disc 2 and 3 being listed as additional parts. However on my shield and Kodi versions the additional parts are not appearing? Is there a specific nameing format needed ? or is it simply not supported? Thanks
ebr 16312 Posted March 31, 2020 Posted March 31, 2020 Hi. Can you show us the exact file structure and naming for these items? Also, based on what you said these are, I would think maybe either making them truly separate items and putting them in a collection or making them different versions of the same item would provide you a better experience.
CAS 1 Posted March 31, 2020 Author Posted March 31, 2020 Hi so this is the structure of files i have in the folder. The parent folder is called "Marillion- holidays in Zalande"
ebr 16312 Posted March 31, 2020 Posted March 31, 2020 Okay, I think the other parts would play in the other apps, you just cannot access them directly. I would do one of my other two suggestions. If you want to make it a multi-version item, just change each of those file names so that the part before the " - " matches the folder name exactly.
CAS 1 Posted March 31, 2020 Author Posted March 31, 2020 Hi thanks for help, decided ill make seperate items and make a collection, Seems best idea thanks for your assistnce
