rechigo 367 Posted March 30, 2020 Posted March 30, 2020 excuse the sloppiness, this is my second time writing this guide (first one didn't post and i REALLLLYYY didnt want to write this again) Easy method: Replace videoosd.js and nowplayingbar.js with the two that are in the mods.zip file attached to this post. The two that are provided in the description are from 4.5.0.2 beta and still work on the stable version from my testing, but it's a good idea to make a backup of your original two files before doing this in case it doesn't work. If these two files don't do the trick, follow the manual guide below The not-as-easy method: https://i.memester.xyz/u/r5b.mp4 Code needed for not-as-easy method: https://paste.memester.xyz/xunigazuto.js Additional: You can change the scroll step value by adding an audioScrollStep key to localstorage and setting its respective value to what you want the scroll step to be Show off: I'll try my best to keep the mods folder up to date with the latest stable. THESE MODIFICATIONS WILL BE WIPED AFTER EVERY SERVER UPDATE AND YOU MUST REDO THEM! @@cochize1 sorry for the wait mods.zip 1
