ireme 11 Posted July 1, 2014 Posted July 1, 2014 I installed trailer channel but it's missing in web interface and MB Classic. I think it's a configuration problem because with a fresh MB server in another machine, trailers is available. Not problem with another channels, only with trailers. Is there any config configuration file to modify it or delete any file to fix the problem? Thanks in advance
Luke 42255 Posted July 1, 2014 Posted July 1, 2014 what makes you think it's missing? http://mediabrowser.tv/community/index.php?/topic/790-how-to-report-a-problem/
ireme 11 Posted July 1, 2014 Author Posted July 1, 2014 (edited) Luke, the MBServer is 3.0.5294.41893 but with last beta server the behavior is the same. Looking at attached below copyscreen, the channels view doesn't exist, but if I install another channel, the channels view appears: http://www.firedrive.com/file/1CEB51DB84FF520C http://www.firedrive.com/file/058D63E0B6477E98 http://www.firedrive.com/file/08362BD66663EFC9 server logs.zip Edited July 1, 2014 by ireme
ebr 16346 Posted July 2, 2014 Posted July 2, 2014 It's under channels One of his images doesn't have that option in the menu.
Solution ireme 11 Posted July 2, 2014 Author Solution Posted July 2, 2014 (edited) Well, has spent a lot of time but uninstalling MBServer and MBClassic and doing a fresh Medoabrowser intallation fix the problem. Edited July 2, 2014 by ireme
