invader 17 Posted March 27, 2020 Posted March 27, 2020 (edited) This is an odd one. I'm running Windows server 4.4.0.40 and Synology Emby Server 4.3.1.0. Both have the same issue. The .nfo file was generated using Tiny Media Manager. I have deleted it and regenerated and it doesn't help. If I manually edit the rating to 6.2, then refresh metadata, it displays fine; only 1 decimal place. Then I change it back to 6.1 and it goes to the 8 decimal places again. Looks to be specific to a rating of 6.1! https://imgur.com/a/V4HriS4 Edited March 27, 2020 by invader
Happy2Play 9805 Posted March 27, 2020 Posted March 27, 2020 What browser? I don't see that rating format but believe it was added. Can you post the nfo file?
invader 17 Posted March 27, 2020 Author Posted March 27, 2020 (edited) I'm using Chrome. I just tried Firefox too, same issue. I've just attached the nfo. Thanks. movie.zip Edited March 28, 2020 by invader
Happy2Play 9805 Posted March 27, 2020 Posted March 27, 2020 I'm using Chrome. I just tried Firefox too, same issue. I've just attached the nfo. Thanks. Sorry no nfo attached.
invader 17 Posted March 28, 2020 Author Posted March 28, 2020 Sorry no nfo attached. Woops sorry. I didn't realise it said "error" when I tried to attache the .nfo. I've zipped it and now it worked and is attached to that post. Can you compare using a different browser? Hi Luke. I tried Chrome and Firefox. Did you want me to try another?
Luke 42213 Posted March 28, 2020 Posted March 28, 2020 No I was just curious. We're using a browser function to format the numeric value appropriately for your locale.
invader 17 Posted March 28, 2020 Author Posted March 28, 2020 I see. Well I just tried the iOS Emby app and it shows the same number of decimal places too. So seems platform independent.
Happy2Play 9805 Posted March 28, 2020 Posted March 28, 2020 (edited) No I was just curious. We're using a browser function to format the numeric value appropriately for your locale. It appears to this format as i can reproduce. changed <rating>6.1</rating> to <ratings> <rating default="true" max="10" name="imdb"> <value>6.1</value> <votes>40796</votes> </rating> </ratings> Edited March 28, 2020 by Happy2Play
Luke 42213 Posted March 28, 2020 Posted March 28, 2020 Yea actually i was wrong, we're not using the platform function to format it, but maybe now we should.
Happy2Play 9805 Posted March 28, 2020 Posted March 28, 2020 (edited) Is it just the way Emby is reading these 3rd party ratings, since Emby doesn't write this newer format? Edited March 28, 2020 by Happy2Play
Luke 42213 Posted March 28, 2020 Posted March 28, 2020 If you use the metadata editor, what does it show?
Happy2Play 9805 Posted March 28, 2020 Posted March 28, 2020 (edited) If you use the metadata editor, what does it show? You mean this. Easy to reproduce using new format. Edited March 28, 2020 by Happy2Play
invader 17 Posted March 29, 2020 Author Posted March 29, 2020 This issue has been resolved in NFO Metadata plugin 1.0.28. Thank you.
invader 17 Posted March 29, 2020 Author Posted March 29, 2020 This issue has been resolved in NFO Metadata plugin 1.0.28. Thank you. Woops. I got too excited. It isn't fixed, I refreshed metadata and it's got the 8 decimal places again. Still an issue.
