rrado 0 Posted March 27, 2020 Posted March 27, 2020 (edited) Hello, I discovered that it was not possible to connect to emby. After analysis, I finally found that 1. there was no disk space any more ! 2. all available space was filled by "transcoding-temp" folder On this server : - no recording - no live TV - oldest .ts files are from (2020-03-26 16:55) Attached are server logs. Using Emby 4.4.0.40 / Ubuntu 18.04 I will restart the server, and will manually remove the .ts file, if needed. Do you have any idea what happened ? Best regards, logs.zip Edited March 27, 2020 by rrado
rrado 0 Posted March 27, 2020 Author Posted March 27, 2020 (edited) Emby was mainly played from web browser (Chrome), and via chromecast Edit : fyi, the server has been restarted. And then, transcoding-temp has been emptied. Edited March 27, 2020 by rrado
Luke 42246 Posted March 29, 2020 Posted March 29, 2020 When you stop playing, how do you typically do that?
rrado 0 Posted March 29, 2020 Author Posted March 29, 2020 Most of time, I do not "stop" playing : I just click on the "back" button (which appears when I move the mouse)
rrado 0 Posted April 8, 2020 Author Posted April 8, 2020 Hello, It seems that some other people have the same issue ? https://emby.media/community/index.php?/topic/84786-expanding-transcoding-temp-directory/ Every now and then (and it seems to be happening more frequently now) I have to delete the directory and restart my server before it expands to use the entire capacity of my SSD Having this emby directory totally fill the disk makes the whole system unusable. @@Luke Would it please be possible to have a temporary work around ? It would be an option which would limit transcoding-temp directory size, for example.
Luke 42246 Posted April 18, 2020 Posted April 18, 2020 If you just play with chrome without using Chromecast, do you still see this happen?
