arthurmv 14 Posted March 27, 2020 Posted March 27, 2020 (edited) I can't find artist.nfo in APPDATA folder, only cover images there, and nothing happens if I modify or set some dummy nfo's files in my artist folders. I gave me all rights to the whole drive (D:\) but nothing happens... I need to format computer and/or move my media library often, I'm looking for solution using metadata as files or embedded into them. I think emby could be the answer (I came from Plex). Can someone help me? please. log.txt Edited March 27, 2020 by arthurmv
Solution Happy2Play 9806 Posted March 27, 2020 Solution Posted March 27, 2020 Artist/people only writes metadata to database, since the removal of artist structure via library. There is a option in the People Backup plugin for Artists though. It pulls the information out of the database and writes metadata and image to your set location. 1
Luke 42216 Posted March 27, 2020 Posted March 27, 2020 We plan to support artist.nfo in future updates. Thanks. 1
arthurmv 14 Posted March 27, 2020 Author Posted March 27, 2020 Artist/people only writes metadata to database, since the removal of artist structure via library. There is a option in the People Backup plugin for Artists though. It pulls the information out of the database and writes metadata and image to your set location. Thanks! I have to play some with it, looks good.
arthurmv 14 Posted March 27, 2020 Author Posted March 27, 2020 We plan to support artist.nfo in future updates. Thanks. Would be nice. Thanks.
