Definite 1 Posted March 27, 2020 Posted March 27, 2020 (edited) I've attached the log with my error for reference. My guide does not display, I am using xTeVe for my tuner source. here is the screenshot of my guide for reference.https://i.imgur.com/RaMLKAS.jpg The channels work, but nothing displays.I am using the IPTV Provided through IPTorrents, there guide is public. https://iptv.memorial/EPG.xml embyserver.txt Edited March 27, 2020 by Definite
Luke 42244 Posted March 27, 2020 Posted March 27, 2020 Hi there, did you forget to attach the log file? thanks.
Definite 1 Posted March 27, 2020 Author Posted March 27, 2020 Hi there, did you forget to attach the log file? thanks. missed the attach button afterwords. added now.
Luke 42244 Posted March 27, 2020 Posted March 27, 2020 Did you check the mapping tool to ensure that tuner channels are mapped to epg channels?
Definite 1 Posted March 27, 2020 Author Posted March 27, 2020 (edited) Did you check the mapping tool to ensure that tuner channels are mapped to epg channels? can you guide me to this so I can be sure I'm using the correct thing? Unless you mean like so. https://i.imgur.com/0aFNAme.png & on xteve https://i.imgur.com/whzDpPh.png Edited March 27, 2020 by Definite
Luke 42244 Posted March 27, 2020 Posted March 27, 2020 can you guide me to this so I can be sure I'm using the correct thing? Unless you mean like so. https://i.imgur.com/0aFNAme.png Yes exactly like this. Does each tuner channel indicate the epg channel underneath?
Definite 1 Posted March 27, 2020 Author Posted March 27, 2020 Yes exactly like this. Does each tuner channel indicate the epg channel underneath? yes.
Solution Definite 1 Posted March 27, 2020 Author Solution Posted March 27, 2020 I believe I have solved this, i had to recreate my xteve from the beginning and manually mapped each channel instead of letting it automap and it appears to have worked. thank you! 1
