lardners 8 Posted March 26, 2020 Posted March 26, 2020 Hi, I've setup an M3U tuner in Live TV and the channels are working but I cannot get the guide to work. It's an XMLTV guide source (a link) I see error below in logs, but not sure what it means? 2020-03-26 16:38:58.977 Error LiveTvManager: Error refreshing channels for service *** Error Report *** Version: 4.4.0.40 Command line: C:\Users\SML\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/SML/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll System.Environment.Version: 3.1.2 Processor count: 4 Program data path: C:\Users\SML\AppData\Roaming\Emby-Server Application directory: C:\Users\SML\AppData\Roaming\Emby-Server\system MediaBrowser.Model.Net.HttpException: MediaBrowser.Model.Net.HttpException: Unauthorized at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.GetTempFileResponse(HttpRequestOptions options) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.GetTempFile(HttpRequestOptions options) at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetXml(ListingsProviderInfo info, String path, MediaProtocol protocol, CancellationToken cancellationToken) at Emby.LiveTV.Listings.XmlTv.XmlTvProvider.GetChannels(ListingsProviderInfo info, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetEpgChannels(IListingsProvider provider, ListingsProviderInfo info, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.EmbyTV.GetChannelsAsync(Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshChannelsInternal(ILiveTvService service, IProgress`1 progress, CancellationToken cancellationToken) at Emby.LiveTV.LiveTvManager.RefreshChannelsInternal(IProgress`1 progress, CancellationToken cancellationToken) Source: Emby.Server.Implementations TargetSite: Void MoveNext()
Luke 42244 Posted March 26, 2020 Posted March 26, 2020 HI there, your xml tv provider is returning a 401 unauthorized response. Can you find out why they're doing that? @@cayars @@maegibbons @@Senna may have some tips.
Carlo 4561 Posted March 26, 2020 Posted March 26, 2020 Something to check. From just a quick glance it appears you haven't given the correct URL for the guide. Many providers require you username/password to be embedded in the URL.
lardners 8 Posted March 26, 2020 Author Posted March 26, 2020 The URL I am using does have a username and password (I removed this from log as I didn't want to post it) but maybe the provider has changed something. I will contact them and check.
Definite 1 Posted March 27, 2020 Posted March 27, 2020 I'm having the exact same problem and cant figure it out for the life of me.
Luke 42244 Posted March 27, 2020 Posted March 27, 2020 I'm having the exact same problem and cant figure it out for the life of me. Hi there @@Definite, we're happy to help. Please see how to report a problem. thanks !
Definite 1 Posted March 27, 2020 Posted March 27, 2020 (edited) Hi there @@Definite, we're happy to help. Please see how to report a problem. thanks ! Okay. I'll make my own post about this. ty Edited March 27, 2020 by Definite
lardners 8 Posted March 27, 2020 Author Posted March 27, 2020 Provider has come back saying there is an issue on their side (which they are working on apparently) Thanks all
