mholin 23 Posted March 26, 2020 Posted March 26, 2020 I found that emby is a very usefull music player beside my former focus on video material. Expecially I love the possibility to stream my media to Sonos and other DLNA hardware. Beside my historical collection of MP3 files I got more and more flac music files and even hires audio files during the last year. When I browse my Fiona Joy Hawkins albums, I cannot distinguish between the 44/16 cd version and 96/24 hires version. When I select one album, I would like to see the file format type (say mp3,aac,flac 44/16, 44/24, 96/24, dsf...) beside the song title. maybe right padded to the time: when browsing movies, I can find the technical details on the bottom how can I get similar info on the music files? thanks Michael 1
Luke 42185 Posted March 26, 2020 Posted March 26, 2020 Hi, there currently isn't a way, but i think we will add one in future updates. thanks.
Guest Breizhspir Posted November 14, 2020 Posted November 14, 2020 (edited) Hello Luke, I would like to know where you are regarding the audio file information, thanks. It is really missing all the more since it would not take much for the Android reader to be perfect. Breizhspirit Edited November 14, 2020 by Breizhspir Mauvaise traduction
Breizhspirit 3 Posted November 14, 2020 Posted November 14, 2020 Bonjour Luke, Je voudrais savoir où vous en êtes concernant les informations du fichier audio, merci. Il en manque vraiment d'autant plus qu'il n'en faudrait pas beaucoup pour que le lecteur Android soit parfait. Breizhspirit
Luke 42185 Posted November 16, 2020 Posted November 16, 2020 We can look at adding it in future updates. Thanks for the feedback.
Breizhspirit 3 Posted November 16, 2020 Posted November 16, 2020 Hi Luke, Thank you very much for this good information. Hope you make it. And you can put the volume under the track with a big round ball as on the progress of the track and at the ends a key - and a key +. And for finish, if it's possible look iso video I buy this application. And after I buying I send my last request but it's for after buying Best regards, Breizhspirit
swandruski 12 Posted January 13, 2021 Posted January 13, 2021 Consider this a +1 on the request for the format, bit depth and sampling rate information on music files. Oh, and also, the number of channels.
Luke 42185 Posted October 2, 2021 Posted October 2, 2021 On 8/29/2021 at 1:51 PM, fce2 said: Any headway on this or a timeframe HI, we'll look for a way to work this in. Thanks.
Luke 42185 Posted May 22, 2023 Posted May 22, 2023 3 minutes ago, Ninko said: Is this possible yet? Thanks HI, not yet but we do plan to look at this. Thanks.
mholin 23 Posted May 26, 2023 Author Posted May 26, 2023 comeon guys, my initial question is now slightly more than 3 years old. do not bother the emby team by asking every 6 months for an update.... cheers Michael
