BetaTester 0 Posted March 25, 2020 Posted March 25, 2020 Hi, after I applied the CoverArt, the color of the DVD background doesn't match my Emby's How can I change either of them? There are a lot of grey rectangles behind the DVD right now.
Solution ebr 16346 Posted March 25, 2020 Solution Posted March 25, 2020 Hi. Are you talking about this? Cover art transparency issue 1
BetaTester 0 Posted March 25, 2020 Author Posted March 25, 2020 HI there, can you show a screenshot? Thanks. https://i.imgur.com/XHxE2dt.png
BetaTester 0 Posted March 25, 2020 Author Posted March 25, 2020 Hi. Are you talking about this? Cover art transparency issue Thats great bro, thanks
BetaTester 0 Posted March 25, 2020 Author Posted March 25, 2020 (edited) Hi. Are you talking about this? Cover art transparency issue Edit: It is fixed now. Thanks again. Edited March 28, 2020 by BetaTester
