zimny 3 Posted March 25, 2020 Posted March 25, 2020 Hi guys, Not sure if I can post it here but when embycon and emby for kodi have a support here then probably this is a good place. Like in the topic I'm using Embuary skin & EmbyCon which I'm happy about. My problem is that in the default all content is present with subtitles ON Some of this subtitles are really wrong ones. How I can turn OFF subtitles by default? and where I need to do it? EmbyCon? or Emby server?
zimny 3 Posted March 25, 2020 Author Posted March 25, 2020 Hi Luke Yes I have downloaded them and their are on the server I just don't like them to play by default
Luke 42234 Posted March 25, 2020 Posted March 25, 2020 Have you explored the subtitle preferences for your emby user?
zimny 3 Posted March 25, 2020 Author Posted March 25, 2020 There is any setup about it under user account
Luke 42234 Posted March 25, 2020 Posted March 25, 2020 Have you explored the options in the emby web interface?
zimny 3 Posted March 25, 2020 Author Posted March 25, 2020 There is not such of option like don't play subtitles by default
Luke 42234 Posted March 25, 2020 Posted March 25, 2020 There is not such of option like don't play subtitles by default Hi, yes there is. Where did you look?
zimny 3 Posted March 25, 2020 Author Posted March 25, 2020 ? Where I can setup this on the server??? Under user or under where?
TeamB 2440 Posted March 25, 2020 Posted March 25, 2020 Subtitles are controlled on the client in Kodi. When you are playing back media use the on screen display to select the options. Under subtitles disable them. Then before you close the dialog at the bottom use the "set as default for all media" to disable subtitles for all media. You can then turn on subtitles for just the items you need.
