quickmic 1709 Posted December 27, 2021 Posted December 27, 2021 There is a kodi plugin called something like log uploader. you can use it. In the kodi.log must be at least in information what's the problem. Not necessarily a crash msg. 1
Quek9 7 Posted December 27, 2021 Posted December 27, 2021 2 minutes ago, quickmic said: There is a kodi plugin called something like log uploader. you can use it. In the kodi.log must be at least in information what's the problem. Not necessarily a crash msg. Ok. I will use it after I kick my sons off of the game. Nothing was showing up in the log area. Nothing basic, information, or warning. 1
quickmic 1709 Posted December 27, 2021 Posted December 27, 2021 You can try this version. The internal ports are changed to 57341 and 57342. But I really doubt, that this solves any issue. plugin.video.emby-next-gen-6.2.4-build 15 (ex2) - test -> ports.zip 1
Quek9 7 Posted February 1, 2022 Posted February 1, 2022 On 12/27/2021 at 9:26 AM, quickmic said: You can try this version. The internal ports are changed to 57341 and 57342. But I really doubt, that this solves any issue. plugin.video.emby-next-gen-6.2.4-build 15 (ex2) - test -> ports.zip 1.3 MB · 1 download After about a month of trying to figure my problem out I finally stumbled on this flawed solution. https://www.matthuisman.nz/2021/10/fix-kodi-xbox-addons.html?m=1 Apparently python on Kodi 19.3 is screwed up. Besides having problems with connecting to my emby server. I couldn't get the weather addon to function. After installing xbmc.python via the instructions depicted above I was able to connect to my emby server and get the weather addon working. The weather addon works as intended but I cannot get my libraries to sync correctly nor can I execute a local database reset.
quickmic 1709 Posted February 2, 2022 Posted February 2, 2022 8 hours ago, Quek9 said: After about a month of trying to figure my problem out I finally stumbled on this flawed solution. https://www.matthuisman.nz/2021/10/fix-kodi-xbox-addons.html?m=1 Apparently python on Kodi 19.3 is screwed up. Besides having problems with connecting to my emby server. I couldn't get the weather addon to function. After installing xbmc.python via the instructions depicted above I was able to connect to my emby server and get the weather addon working. The weather addon works as intended but I cannot get my libraries to sync correctly nor can I execute a local database reset. You can send me a kodi.log after you synced your database. Maybe I find something, actually the sync should be ok.
Quek9 7 Posted February 3, 2022 Posted February 3, 2022 20 hours ago, quickmic said: You can send me a kodi.log after you synced your database. Maybe I find something, actually the sync should be ok. I don't know how to pull the kodi.log from the xbox kodi.
quickmic 1709 Posted February 3, 2022 Posted February 3, 2022 There are Kodi plugins available for log downloads.
Quek9 7 Posted February 3, 2022 Posted February 3, 2022 2 hours ago, quickmic said: There are Kodi plugins available for log downloads. I'm unfamiliar. Could you point me in the right direction?
quickmic 1709 Posted February 3, 2022 Posted February 3, 2022 https://kodi.wiki/view/Add-on:Log_Viewer_for_Kodi 1
Quek9 7 Posted February 3, 2022 Posted February 3, 2022 23 minutes ago, quickmic said: https://kodi.wiki/view/Add-on:Log_Viewer_for_Kodi Thanks, I will give it a shot this evening. 1
