KRA 39 Posted July 29, 2014 Author Posted July 29, 2014 Primarily I will use it for TVHeadend But I also plan to use it for streams that are open but locked to a spesific network, so I have access to it all over.
psykix 97 Posted July 30, 2014 Posted July 30, 2014 I'm messing about with this at the moment and adding and deleting streams to see what works. How do I get the streams to update though? I added two which didn't work, so went back and deleted those and added 2 more, but I still only see the old 2, not the new ones..
KRA 39 Posted July 30, 2014 Author Posted July 30, 2014 I had same problem either refresh page or restart server dont remember what worked.
psykix 97 Posted July 30, 2014 Posted July 30, 2014 I had same problem either refresh page or restart server dont remember what worked. Neither works here :-(
psykix 97 Posted July 30, 2014 Posted July 30, 2014 Add a third Hmm.. Tried that, and it added another old one back instead!! Also, what's image URL for? I thought maybe a channel logo but that didn't work :-p
im85288 1493 Posted July 30, 2014 Posted July 30, 2014 image url works for channel logos for me, they probably need to be hosted on a web server though for accessibility via HTTP..or maybe not! Mine are defined similar too: http://192.168.1.8/xbmc/1_0_19_1B1D_802_2_11A0000_0_0_0.png
psykix 97 Posted July 30, 2014 Posted July 30, 2014 I'll try again then. However I'm struggling to get it to forget the deleted streams and show the new ones at the moment :-(
im85288 1493 Posted July 30, 2014 Posted July 30, 2014 I think I had to first add it with a different name...then delete them both..then add the new one. Something like that
psykix 97 Posted July 31, 2014 Posted July 31, 2014 (edited) After a server update they appeared. Something odd happening though - they are obviously being cached somewhere even after deletion. Edit : ones I delete this morning disappeared straight away. Will see how it goes :-) Edited July 31, 2014 by psykix
snazy2000 344 Posted July 31, 2014 Posted July 31, 2014 I've requested that I can turn off caching in some places but may have to wait a while for other more important things to be done =) Sent from my HTC One using Tapatalk
psykix 97 Posted July 31, 2014 Posted July 31, 2014 Yeah, it's causing issues again - somehow streams deleted yesterday reappeared today after I thought it was working.
snazy2000 344 Posted July 31, 2014 Posted July 31, 2014 (edited) Can you try restarting your MBS see if that removes the onces you deleted Edited July 31, 2014 by snazy2000
psykix 97 Posted July 31, 2014 Posted July 31, 2014 Can you try restarting your MBS see if that removes the onces you deleted I had already tried that. Restarting makes no difference. It seems to be a little bit random when it updates or not. I've uninstalled the plugin at the moment and will reinstall later and try again :-) I'm not using it in anger, was just playing around to see what it could do!
The Baron 64 Posted August 1, 2014 Posted August 1, 2014 I have the same issue here, in the WebViewer, I am getting an entry for what seems to be the first stream created in a sequence. I can delete that stream in the IPTV plugin, but it remains in the WebViewer. Strangly, when you go into the edit section of the stream, you cannot modify the path, for example. It seems to be set to read-only, unlike other streams which you can edit. I've tried restarting MBS and the host, neither of these steps resolve the issue.
kingy444 117 Posted August 4, 2014 Posted August 4, 2014 @@snazy2000 Been testing out the IPTV plugin. Curious if you could customise it to not show username/password in the path field when viewing the channel page. Two options: Dont display it at all or use a string replace method ? The other thing I have noticed is that once a stream is added you cant edit it. You mist recreate it
snazy2000 344 Posted August 4, 2014 Posted August 4, 2014 I will make edit work when i get a chance. Ill see what i can do with it not showing up Im currently working on some other projects atm 1
Luke 42246 Posted August 29, 2014 Posted August 29, 2014 sorry guys. i figured the app wouldnt' auto-update which would allow you to stay where you are. if that didn't happen, apologies.
KRA 39 Posted August 29, 2014 Author Posted August 29, 2014 Today the plugin changed name to Video Bookmarks and all my settings (links) are gone 1
KRA 39 Posted August 29, 2014 Author Posted August 29, 2014 so is it safe to setup again now, or could this happen again in comming days ?
im85288 1493 Posted August 29, 2014 Posted August 29, 2014 Same for me...even worse I'm away from home so this was not a nice surprise
snazy2000 344 Posted August 30, 2014 Posted August 30, 2014 (edited) This is a change @@Luke made last night. Sent from my HTC One using Tapatalk Edited August 29, 2014 by snazy2000
snazy2000 344 Posted August 30, 2014 Posted August 30, 2014 It has only happened because of the name change. Should be all ok now
AgileHumor 123 Posted August 30, 2014 Posted August 30, 2014 Are you planning to add h264 RTSP support? This is for my Foscam security camera.
Solution Luke 42246 Posted March 3, 2018 Solution Posted March 3, 2018 You can do this with our IPTV plugin. Enjoy 1
