Sentinel 12 Posted March 22, 2020 Posted March 22, 2020 Hi, First off, been using Emby from media browser 1 on wards and upwards. Fantastic bit of kit and just gets better and better I use Covert art plug in and it is a great plug to enhance your experience in Emby. I use a slight tilt on the covers. Config says <ImageSetDef> <ImageSetName>ThickCase</ImageSetName> <Rotation>1</Rotation> </ImageSetDef> It works great, but i use the black theme in all apps and have noticed that there is a part of the emby frame that the cover goes in that is not transparent. The larger the tilt, the more visible it is. Not sure if this is a cover art or emby issue. Is there a setting in the config i can change for this or is it in the conversion to add the tilt to the images or the way Emby draws them? Thanks
ebr 16346 Posted March 22, 2020 Posted March 22, 2020 Hi. That is just a background for the image placeholder in the app.
Sentinel 12 Posted March 22, 2020 Author Posted March 22, 2020 Hi ebr, Thanks you for the fast response. guess shall put up with it, or make the images flat with no tilt. Cheers
rechigo 367 Posted March 22, 2020 Posted March 22, 2020 Hey! I wrote some CSS a while ago that takes care of this /*Makes the card look a bit better when hovering over it, you don't need this one*/ .cardOverlayContainer.itemAction { border-radius: 4px; background: rgba(20,20,20,0.6) !important; } /*Removes card background*/ .itemAction.cardContent-button.cardContent.cardImageContainer.cardContent-shadow.coveredImage { -webkit-box-shadow: none !important; box-shadow: none !important; background-color: transparent !important; } Sent from my SM-G973U using Tapatalk 1
Sentinel 12 Posted March 22, 2020 Author Posted March 22, 2020 Hi rechigo What file do i need to replace the code in with your above code? Shall give it a go. Thanks
Sentinel 12 Posted March 22, 2020 Author Posted March 22, 2020 Hi rechigo, Not to worry, Found it. Added into the custom CSS in emby's settings page. Works a charm on web pages but not in Emby Theater, guess that uses the application to draw it all and not the css code. Thank you
caffeineshock 18 Posted April 15, 2022 Posted April 15, 2022 (edited) On 3/22/2020 at 6:33 PM, rechigo said: Hey! I wrote some CSS a while ago that takes care of this /*Makes the card look a bit better when hovering over it, you don't need this one*/ .cardOverlayContainer.itemAction { border-radius: 4px; background: rgba(20,20,20,0.6) !important; } /*Removes card background*/ .itemAction.cardContent-button.cardContent.cardImageContainer.cardContent-shadow.coveredImage { -webkit-box-shadow: none !important; box-shadow: none !important; background-color: transparent !important; } Sent from my SM-G973U using Tapatalk damn, thanks! now i need the same for the (android (tv)) app Edited April 15, 2022 by caffeineshock
