ivangs 3 Posted March 20, 2020 Posted March 20, 2020 Hello, I have played mkv file with the following characteristics: ViDEO.iNFO .....: AVC @ 26413 kbps AUDiO.iNFO .....: DTS-HD MA 5.1 @ 1509 kbps @ 768 kbps on NNVIDIA Shield TV 2017 server version 4.3.1 but there is no sound. Thank you in advance for your help.
Luke 42239 Posted March 20, 2020 Posted March 20, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
ivangs 3 Posted March 20, 2020 Author Posted March 20, 2020 Hello, Please find attached log files. embyserver.txt ffmpeg-transcode-01eb7f57-ba0d-450c-a2e1-a7618621d7af_1.txt ffmpeg-transcode-08e529c3-e247-4cbe-9f8c-8ce63c82f79b_1.txt ffmpeg-transcode-08efa84e-1d96-46e1-8d1e-b05799d02bd5_1.txt hardware_detection-63720334177.txt
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 I have tested and with version 4.4.0.40 but result is the same - no sound.
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 In exactly what situation? You posted three ffmpeg logs and said the issue was with DTS-HD audio. But two of those logs indicate an item with mp3 audio. The one with DTS was being played from FireFox. Is it only the DTS one played through the web app that is the problem? Have you tried a different browser?
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 When i play the file with DTS-HD on NVIDIA TV Emby client there is no sound. There is no problem when i play it on FireFox on PC.
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 Does the audio system support DTS-HD? If you un-check the option in the playback settings to allow pass through of DTS-HD do you get sound then?
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 (edited) I have un-check the option in the playback settings to allow pass through of DTS Pass-thru and there is a sound. When i un-check DTS-HD - there is no sound. I am using Sonos beam + 2 x sonos play1 speakers Edited March 21, 2020 by ivangs
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 Okay. That soundbar can support DTS apparently but not DTS HD. Which is why that option is there. So you are good now?
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 Okay. That soundbar can support DTS apparently but not DTS HD. Which is why that option is there. So you are good now? I mean that there ate two options about DTS: 1. Allow DTS Pass-thru 2. Enable DTS-HD Pass-thru When i un-check first option only (Allow DTS Pass-thru) there is sound.
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 What happens if you leave the first one checked and uncheck just the second one?
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 What happens if you leave the first one checked and uncheck just the second one? There is no sound with just the second one unchecked - i think that this means that Sonos doesn't support DTS
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 Yes, but that also means something in the system is reporting that it does when it actually doesn't. In any case, unchecking the option(s) should get you going. Thanks.
ivangs 3 Posted March 21, 2020 Author Posted March 21, 2020 Yes, but that also means something in the system is reporting that it does when it actually doesn't. In any case, unchecking the option(s) should get you going. Thanks. Ok - i have unchecked Allow DTS Pass-thru and now will search for DTS 5.1. to AC3 5.1 converter.
ivangs 3 Posted March 23, 2020 Author Posted March 23, 2020 (edited) Yes, but that also means something in the system is reporting that it does when it actually doesn't. In any case, unchecking the option(s) should get you going. Thanks. Just one question - is Emby LG client capable to trans-code DTS-HD 5.1 to DD 5.1? I have found similar thread here: https://emby.media/community/index.php?/topic/65649-can-emby-transcode-dts-to-ddac3/page-2 Edited March 23, 2020 by ivangs
Luke 42239 Posted March 25, 2020 Posted March 25, 2020 Just one question - is Emby LG client capable to trans-code DTS-HD 5.1 to DD 5.1? I have found similar thread here: https://emby.media/community/index.php?/topic/65649-can-emby-transcode-dts-to-ddac3/page-2 Not at this time but an option for that is certainly possible for the future. thanks.
ivangs 3 Posted March 26, 2020 Author Posted March 26, 2020 (edited) Not at this time but an option for that is certainly possible for the future. thanks. The Sonos owners will appreciate if you can include this option in some beta for test. Edited March 26, 2020 by ivangs
CBers 7554 Posted March 26, 2020 Posted March 26, 2020 Okay. That soundbar can support DTS apparently but not DTS HD. Which is why that option is there. So you are good now? No Sonos devices support DTS, only DD. I have a Sonos Beam and any time I playback a video with DTS or EAC3, then the audio gets remuxed to DD. It works very well, with limited load on the server and excellent audio.
ivangs 3 Posted April 12, 2020 Author Posted April 12, 2020 Not at this time but an option for that is certainly possible for the future. thanks. When we can expect this option to be available?
Luke 42239 Posted April 12, 2020 Posted April 12, 2020 I don't have an ETA but we're working as hard as we can. Thanks.
