yarez0 22 Posted June 30, 2020 Posted June 30, 2020 uptime robot is a simple https check, no authentication
alext41 4 Posted July 2, 2020 Author Posted July 2, 2020 at the moment no crash from my side after ~1week. Only the process takes up more and more memory. I restarted it now because i changed back to the realtime monitor for each my libraries. I see when this is running it takes up more memory as before. But all good right now. I think the problem is that the out of the box Synologys have only 1GB and with that the memory will run low and synology maybe stop the process.
yarez0 22 Posted July 10, 2020 Posted July 10, 2020 1 hour ago, Luke said: Has it happened again? Yep, yesterday, app stopped in packet manager without any reason
yarez0 22 Posted July 10, 2020 Posted July 10, 2020 It always happened (app stop, memory full or « too many files) in the morning (between 7h and 9h am)
alext41 4 Posted July 10, 2020 Author Posted July 10, 2020 1 hour ago, Luke said: Has it happened again? For me Emby is now running more then one week after server memory upgrade without problems. Process is now at around 600MB
bobaldis 24 Posted July 10, 2020 Posted July 10, 2020 On 6/21/2020 at 5:11 PM, Luke said: Hi there, please PM me the log file. Thanks. Hi, I noticed it stopped today, I haven't used for a little while, is there a way to locate the probable last log entry so I can send the appropriate log? Bob
bobaldis 24 Posted July 14, 2020 Posted July 14, 2020 On 7/10/2020 at 8:12 PM, bobaldis said: Hi, I noticed it stopped today, I haven't used for a little while, is there a way to locate the probable last log entry so I can send the appropriate log? Bob Stopped again, any guidance on the right log file to send? Bob
alext41 4 Posted July 21, 2020 Author Posted July 21, 2020 Update from my side: Emby is now running without any problems for ~ 3 weeks.
yarez0 22 Posted July 21, 2020 Posted July 21, 2020 (edited) 2 hours ago, alext41 said: Update from my side: Emby is now running without any problems for ~ 3 weeks. mine still crash.. [EDIT] just crash with TOO MANY OPEN FILES, got all logs before restarting the app. @Luke any help ? thx embyserver.txt embyserver-63730627200.txt embyserver-63730713599.txt embyserver-63730886400.txt ffmpeg-transcode-214a7a9a-db6d-45d7-b7c7-613671a4d4dc_1.txt ffmpeg-transcode-d314346a-c549-4e46-b5c7-82a031541c26_1.txt start-stop-status_20200718.log start-stop-status_20200721.log Edited July 21, 2020 by yarez0
Luke 42243 Posted July 23, 2020 Posted July 23, 2020 For those interested in testing new things: Thanks.
yarez0 22 Posted July 23, 2020 Posted July 23, 2020 1 hour ago, Luke said: For those interested in testing new things: Thanks. just updated to the beta, let's see if the app continue crashing
Luke 42243 Posted July 29, 2020 Posted July 29, 2020 On 7/23/2020 at 1:58 PM, yarez0 said: just updated to the beta, let's see if the app continue crashing How has it gone?
yarez0 22 Posted July 29, 2020 Posted July 29, 2020 50 minutes ago, Luke said: How has it gone? Everything is fine since I updated. I keep an eye on it
yarez0 22 Posted August 1, 2020 Posted August 1, 2020 On 7/29/2020 at 7:22 PM, Luke said: Thanks for the feedback. all good ! just an error for plug in update check after an update of cinema mode but a reboot of the server and everything's fine Connection to https://www.mb3admin.com/admin/service/EmbyPackages.json timed out at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePackagesWithoutRegistrationInfo(Boolean enableCache, CancellationToken cancellationToken) at Emby.Server.Implementations.Updates.InstallationManager.GetAvailablePluginUpdates(Version applicationVersion, CancellationToken cancellationToken) at Emby.Server.Implementations.ScheduledTasks.PluginUpdateTask.Execute(CancellationToken cancellationToken, IProgress`1 progress) at Emby.Server.Implementations.ScheduledTasks.ScheduledTaskWorker.ExecuteInternal(TaskOptions options) question @Luke, if there is an update of the beta, do I have to download and update manually or the server can update itself like the stable release ?
Luke 42243 Posted August 1, 2020 Posted August 1, 2020 With this new package you have to download and install over the top. We're working on getting into the official Synology app store.
yarez0 22 Posted August 2, 2020 Posted August 2, 2020 On 8/1/2020 at 3:31 PM, Luke said: With this new package you have to download and install over the top. We're working on getting into the official Synology app store. Ok. Which topic have I to follow to be aware of updates ?
Luke 42243 Posted August 2, 2020 Posted August 2, 2020 3 minutes ago, yarez0 said: Ok. Which topic have I to follow to be aware of updates ? Updates to what? Your server dashboard will notify you when an update is available.
yarez0 22 Posted August 2, 2020 Posted August 2, 2020 2 minutes ago, Luke said: Updates to what? Your server dashboard will notify you when an update is available. Updates of betas. I did not understood what you meant sorry. I understood that I had to follow the release beta topic to be aware of updates, download manually spk and install. (Translation problem)
tobar 3 Posted August 31, 2020 Posted August 31, 2020 (edited) so what is the solution? update to the last beta version? Edited September 1, 2020 by tobar
Luke 42243 Posted August 31, 2020 Posted August 31, 2020 4 hours ago, tobar said: so what is the final solution? update to the last beta version? That or wait for the beta release to go stable.
