qnetso 22 Posted March 20, 2020 Posted March 20, 2020 Hi - @@ebr I am missing guide data for: 9 CBET CDC 21 cspan1 (is there guide data for that?) 25 Disney Jr. East 26 TV Land East 37 CNN Headline News 51 Travel Channel My provider is Wow! Emby Guide Data in use is USA-MI21595-X Can we get those added? Thanks
ebr 16332 Posted March 21, 2020 Posted March 21, 2020 Hi. What do you mean by your provider is Wow? Are you sure those channels exist in the lineup you chose? Perhaps a different lineup in the same area would have them...?
qnetso 22 Posted March 28, 2020 Author Posted March 28, 2020 I mean my provider is wow! https://www.wowway.com/ And yes I’m sure this is the correct lineup. These channels exist in all the Wow! lineups for my area.
Solution ebr 16332 Posted March 28, 2020 Solution Posted March 28, 2020 Did you check the channel mapping to be sure those channels are mapped properly? 1
qnetso 22 Posted March 29, 2020 Author Posted March 29, 2020 (edited) How would that effect getting guide data? I can tune the channels, just no guide data. Forgive me, not understanding. Edited March 29, 2020 by ThePaladinTech
Luke 42237 Posted March 29, 2020 Posted March 29, 2020 The tuner channels need to be mapped to epg channels in order to see guide data. 1
qnetso 22 Posted March 31, 2020 Author Posted March 31, 2020 Thanks! That fixed it. Is there a way for me to add / replace channel logos?
Luke 42237 Posted March 31, 2020 Posted March 31, 2020 Yes have you explored the image editor for channels?
