aja07 20 Posted March 18, 2020 Posted March 18, 2020 So far I have not been able to figure out how to stop a current recording while in ATV (W10 server). We always pad our recordings by 30min at the end (AU tv does not always run to schedule). When we watch an active recording and get to the end of the program before the padding has finished recording how do I then stop the recording in ATV. For that matter even if I want to stop a recording before the end of the program, how to do this in ATV. I have not found a "Stop Recording' action anywhere ATV. I do know that I can do this in the Server web interface. Thanks
Luke 42246 Posted March 18, 2020 Posted March 18, 2020 Hi there, have you clicked into the detail screen of the active recording?
ebr 16338 Posted March 18, 2020 Posted March 18, 2020 Hi. On the detail screen for the recording, there should be a button with a red circle. Click it and it will ask you if you want to cancel the recording. You can also stop recording while watching the channel live with the same red circle on the OSD.
aja07 20 Posted March 18, 2020 Author Posted March 18, 2020 (edited) Will give this a go and report back, thanks. Presume it is the same for series recordings. I was pressing the 3 dot button and expecting a 'stop recording' button in the drop down. Edited March 18, 2020 by aja07
