banderson1311 5 Posted March 17, 2020 Posted March 17, 2020 I'm trying out Emby on my Fire Stick 4K. Most videos play flawlessly but I noticed I'm getting noticeable delay in the audio if the video uses Dolby Digital Plus (eac3). Logs are attached. Any suggestions on how to further troubleshoot would be greatly appreciated. embyserver.txt ffmpeg-remux-3da9038b-80ee-4154-962c-e4dbd0c02b20_1.txt
Luke 42246 Posted March 18, 2020 Posted March 18, 2020 Hi there, are you able to play the same file using the Emby web app?
banderson1311 5 Posted March 18, 2020 Author Posted March 18, 2020 It plays properly through the web app on my laptop. I will try the webapp on the Fire Stick later today as well.
banderson1311 5 Posted March 18, 2020 Author Posted March 18, 2020 I had a similar delay through the web app on the TV I've been testing on (LG). I tested on the other two TVs in my house and had interesting results. On an Insignia TV using the same model of Fire TV Stick 4K I saw the same delay both with the Emby app and through the web. On a Vizio TV using a previous generation Fire TV 4K (from 2017?) I did not see delays from either. This leads me to believe it's either related to the newer Fire TV Sticks or something else with my TV or soundbar. It's still weird that it's only this codec though.
Luke 42246 Posted March 18, 2020 Posted March 18, 2020 Is the audio delay built into the file? You can check with a tool like MediaInfo.
banderson1311 5 Posted March 18, 2020 Author Posted March 18, 2020 I can check MediaInfo but the same delay is occurring for any file using eac3.
banderson1311 5 Posted March 18, 2020 Author Posted March 18, 2020 I took a look at a few of my eac3 files and they do seem to indicate a delay. However the delay is pretty minimal (~10ms) and audio is off by 200+ ms. General Unique ID : 39808393596372312695535454588016022340 (0x1DF2D15686774621588442B577885344) Complete name : Z:\TVShows\Curb Your Enthusiasm\Season 10\Curb Your Enthusiasm - 10x08 - Elizabeth, Margaret and Phillip.mkv Format : Matroska Format version : Version 4 File size : 751 MiB Duration : 38 min 38 s Overall bit rate : 2 716 kb/s Encoded date : UTC 2020-03-09 02:30:25 Writing application : mkvmerge v38.0.0 ('The Silent Type') 64-bit Writing library : libebml v1.3.9 + libmatroska v1.5.2 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 5 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 5 frames Codec ID : V_MPEG4/ISO/AVC Duration : 38 min 38 s Bit rate : 2 458 kb/s Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 23.976 (24000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.111 Stream size : 679 MiB (91%) Default : Yes Forced : No Audio ID : 2 Format : E-AC-3 Format/Info : Enhanced AC-3 Commercial name : Dolby Digital Plus Codec ID : A_EAC3 Duration : 38 min 38 s Bit rate mode : Constant Bit rate : 256 kb/s Channel(s) : 6 channels Channel layout : L R C LFE Ls Rs Sampling rate : 48.0 kHz Frame rate : 31.250 FPS (1536 SPF) Compression mode : Lossy Delay relative to video : 11 ms Stream size : 70.8 MiB (9%) Service kind : Complete Main Default : Yes Forced : No Text ID : 3 Format : S_TEXT/WEBVTT Codec ID : S_TEXT/WEBVTT Duration : 38 min 35 s Bit rate : 133 b/s Count of elements : 1037 Stream size : 37.6 KiB (0%) Language : English Default : Yes Forced : No I also tried using the LG app to bypass the Fire TV Stick but the same thing occurred. I'm wondering if this might just be an issue with my TV and sound bar since it doesn't seem to be happening for others.
Luke 42246 Posted March 18, 2020 Posted March 18, 2020 Ok, we're about to release Emby Server 4.4 so i would suggest re-evaluating with that once available. Thanks.
banderson1311 5 Posted March 19, 2020 Author Posted March 19, 2020 Sounds good. I will try again when 4.4 is ready. Thanks for your help.
