ChristiaanCIVL 0 Posted March 15, 2020 Posted March 15, 2020 I have a seedbox for a good month now, Emby worked very well at first. And now it crashes directly, i don't know how that happens. What to do :-) Ubuntu 16.04 RAPIDSEEDBOX
Luke 42246 Posted March 15, 2020 Posted March 15, 2020 Hi there, let's look at an example. Please attach the information requested in how to report a problem. Thanks.
ChristiaanCIVL 0 Posted March 17, 2020 Author Posted March 17, 2020 Hi Luke Ok, so. I just go onto my Seedbox, start the service and by the time i can log on to y LOCALHOST page it crashes. The only log file i find is attached in this message.I did not change anything and it worked really well for a month or so.I cannot log on to see if i get any other fail messages. Greetings 2020-03-17 17:26:57.298 Info Main: Application path: /opt/emby-server/system/EmbyServer.dll 2020-03-17 17:26:58.080 Info Main: Emby Command line: /opt/emby-server/system/EmbyServer.dll -programdata /var/lib/emby -ffdetect /opt/emby-server/bin/ffdetect -ffmpeg /opt/emby-server/bin/ffmpeg -ffprobe /opt/emby-server/bin/ffprobe -restartexitcode 3 -updatepackage emby-server-deb_{version}_amd64.deb Operating system: Unix 4.4.0.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///opt/emby-server/system/System.Private.CoreLib.dll Processor count: 2 Program data path: /var/lib/emby Application directory: /opt/emby-server/system 2020-03-17 17:26:58.162 Info App: Application version: 4.3.1.0 2020-03-17 17:26:58.164 Info App: Loading assemblies 2020-03-17 17:26:58.479 Info App: File /var/lib/emby/plugins/DvdMounter.dll has version 1.0.0.0 2020-03-17 17:26:58.519 Info App: File /opt/emby-server/system/plugins/DvdMounter.dll has version 1.0.0.0 2020-03-17 17:26:58.557 Info App: File /var/lib/emby/plugins/Emby.Server.CinemaMode.dll has version 1.0.30.0 2020-03-17 17:26:58.668 Info App: File /opt/emby-server/system/plugins/Emby.Server.CinemaMode.dll has version 1.0.30.0 2020-03-17 17:26:58.705 Info App: File /var/lib/emby/plugins/Emby.Webhooks.dll has version 1.0.9.0 2020-03-17 17:26:58.721 Info App: File /opt/emby-server/system/plugins/Emby.Webhooks.dll has version 1.0.8.0 2020-03-17 17:26:58.762 Info App: File /var/lib/emby/plugins/MusicBrainz.dll has version 1.0.12.0 2020-03-17 17:26:58.777 Info App: File /opt/emby-server/system/plugins/MusicBrainz.dll has version 1.0.9.0 2020-03-17 17:26:58.804 Info App: File /var/lib/emby/plugins/StudioImages.dll has version 1.0.3.0 2020-03-17 17:26:58.820 Info App: File /opt/emby-server/system/plugins/StudioImages.dll has version 1.0.1.0 2020-03-17 17:26:58.914 Info App: File /var/lib/emby/plugins/OMDb.dll has version 1.0.9.0 2020-03-17 17:26:58.918 Info App: File /opt/emby-server/system/plugins/OMDb.dll has version 1.0.7.0 2020-03-17 17:26:59.018 Info App: File /var/lib/emby/plugins/Fanart.dll has version 1.0.5.0 2020-03-17 17:26:59.031 Info App: File /opt/emby-server/system/plugins/Fanart.dll has version 1.0.5.0 2020-03-17 17:26:59.060 Info App: File /var/lib/emby/plugins/Emby.PortMapper.dll has version 1.0.3.0 2020-03-17 17:26:59.063 Info App: File /opt/emby-server/system/plugins/Emby.PortMapper.dll has version 1.0.2.0 2020-03-17 17:26:59.084 Info App: File /var/lib/emby/plugins/BlurayMounter.dll has version 1.0.0.0 2020-03-17 17:26:59.145 Info App: File /opt/emby-server/system/plugins/BlurayMounter.dll has version 1.0.0.0 2020-03-17 17:26:59.289 Info App: File /var/lib/emby/plugins/MovieDb.dll has version 1.3.0.0 2020-03-17 17:26:59.294 Info App: File /opt/emby-server/system/plugins/MovieDb.dll has version 1.2.6.0 2020-03-17 17:26:59.431 Info App: File /var/lib/emby/plugins/AudioDb.dll has version 1.0.6.0 2020-03-17 17:26:59.538 Info App: File /opt/emby-server/system/plugins/AudioDb.dll has version 1.0.6.0 2020-03-17 17:26:59.558 Info App: File /var/lib/emby/plugins/NfoMetadata.dll has version 1.0.27.0 2020-03-17 17:26:59.559 Info App: File /opt/emby-server/system/plugins/NfoMetadata.dll has version 1.0.23.0 2020-03-17 17:26:59.624 Info App: File /var/lib/emby/plugins/Tvdb.dll has version 1.0.29.0 2020-03-17 17:26:59.628 Info App: File /opt/emby-server/system/plugins/Tvdb.dll has version 1.0.22.0 2020-03-17 17:26:59.711 Info App: File /var/lib/emby/plugins/Emby.Dlna.dll has version 1.0.35.0 2020-03-17 17:26:59.800 Info App: File /opt/emby-server/system/plugins/Emby.Dlna.dll has version 1.0.33.0 2020-03-17 17:26:59.875 Info App: File /var/lib/emby/plugins/OpenSubtitles.dll has version 1.0.23.0 2020-03-17 17:27:00.014 Info App: File /opt/emby-server/system/plugins/OpenSubtitles.dll has version 1.0.22.0 2020-03-17 17:27:00.386 Info App: Loading DvdMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/DvdMounter.dll 2020-03-17 17:27:00.386 Info App: Loading Emby.Server.CinemaMode, Version=1.0.30.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Server.CinemaMode.dll 2020-03-17 17:27:00.386 Info App: Loading Emby.Webhooks, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Webhooks.dll 2020-03-17 17:27:00.386 Info App: Loading MusicBrainz, Version=1.0.12.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MusicBrainz.dll 2020-03-17 17:27:00.386 Info App: Loading StudioImages, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/StudioImages.dll 2020-03-17 17:27:00.386 Info App: Loading OMDb, Version=1.0.9.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OMDb.dll 2020-03-17 17:27:00.386 Info App: Loading IMVDb, Version=1.0.8.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/IMVDb.dll 2020-03-17 17:27:00.386 Info App: Loading Fanart, Version=1.0.5.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Fanart.dll 2020-03-17 17:27:00.386 Info App: Loading Emby.PortMapper, Version=1.0.3.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.PortMapper.dll 2020-03-17 17:27:00.386 Info App: Loading BlurayMounter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/BlurayMounter.dll 2020-03-17 17:27:00.386 Info App: Loading MovieDb, Version=1.3.0.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/MovieDb.dll 2020-03-17 17:27:00.386 Info App: Loading AudioDb, Version=1.0.6.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/AudioDb.dll 2020-03-17 17:27:00.386 Info App: Loading NfoMetadata, Version=1.0.27.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/NfoMetadata.dll 2020-03-17 17:27:00.386 Info App: Loading Tvdb, Version=1.0.29.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Tvdb.dll 2020-03-17 17:27:00.386 Info App: Loading Emby.Dlna, Version=1.0.35.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/Emby.Dlna.dll 2020-03-17 17:27:00.387 Info App: Loading OpenSubtitles, Version=1.0.23.0, Culture=neutral, PublicKeyToken=null from /var/lib/emby/plugins/OpenSubtitles.dll 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.Api, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.WebDashboard, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.Model, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.Common, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.Controller, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.Providers, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Photos, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Server.Implementations, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.LiveTV, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.ActivityLog, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Server.MediaEncoding, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading MediaBrowser.LocalMetadata, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Notifications, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Codecs.Dxva, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Codecs, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Server.Connect, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading Emby.Server.Sync, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:00.387 Info App: Loading EmbyServer, Version=4.3.1.0, Culture=neutral, PublicKeyToken=null 2020-03-17 17:27:01.809 Info SqliteUserRepository: Sqlite version: 3.29.0 2020-03-17 17:27:01.811 Info SqliteUserRepository: Sqlite compiler options: COMPILER=gcc-8.3.0,ENABLE_COLUMN_METADATA,ENABLE_DBSTAT_VTAB,ENABLE_FTS3_PARENTHESIS,ENABLE_FTS3_TOKENIZER,ENABLE_FTS4,ENABLE_FTS5,ENABLE_JSON1,ENABLE_PREUPDATE_HOOK,ENABLE_RTREE,ENABLE_SESSION,ENABLE_UNLOCK_NOTIFY,ENABLE_UPDATE_DELETE_LIMIT,LIKE_DOESNT_MATCH_BLOBS,MAX_SCHEMA_RETRY=25,MAX_VARIABLE_NUMBER=250000,OMIT_LOOKASIDE,SECURE_DELETE,THREADSAFE=1 2020-03-17 17:27:02.079 Info SqliteUserRepository: Default journal_mode for /var/lib/emby/data/users.db is wal 2020-03-17 17:27:02.382 Info AuthenticationRepository: Default journal_mode for /var/lib/emby/data/authentication.db is wal 2020-03-17 17:27:02.578 Info ActivityRepository: Default journal_mode for /var/lib/emby/data/activitylog.db is wal 2020-03-17 17:27:02.596 Info SqliteDisplayPreferencesRepository: Default journal_mode for /var/lib/emby/data/displaypreferences.db is wal 2020-03-17 17:27:02.620 Info App: Adding HttpListener prefix http://+:8096/ 2020-03-17 17:27:02.680 Info App: Adding HttpListener prefix https://+:8920/ 2020-03-17 17:27:03.845 Info SqliteItemRepository: Default journal_mode for /var/lib/emby/data/library.db is wal 2020-03-17 17:27:08.612 Info Skia: SkiaSharp version: 1.68.0.0 2020-03-17 17:27:08.768 Info TaskManager: Daily trigger for Thumbnail image extraction set to fire at 03/18/2020 02:00:00, which is 512.853858881667 minutes from now. 2020-03-17 17:27:08.928 Info TaskManager: Daily trigger for Rotate log file set to fire at 03/18/2020 00:00:00, which is 392.851187283333 minutes from now. 2020-03-17 17:27:09.136 Info App: ServerId: 44935e89a4cf4acf8041b0635e91f4c3 2020-03-17 17:27:09.305 Info App: Starting entry point Emby.Dlna.Main.DlnaEntryPoint 2020-03-17 17:27:09.821 Info Dlna: Registering publisher for urn:schemas-upnp-org:device:MediaServer:1 2020-03-17 17:27:10.085 Info App: Init BeginReceive on 0.0.0.0 2020-03-17 17:27:10.123 Info App: Entry point completed: Emby.Dlna.Main.DlnaEntryPoint. Duration: 0.8176991 seconds 2020-03-17 17:27:10.123 Info App: Starting entry point Emby.Server.Connect.ConnectEntryPoint 2020-03-17 17:27:10.128 Info App: Loading data from /var/lib/emby/data/connect.txt 2020-03-17 17:27:10.237 Info App: Loading data from /var/lib/emby/data/wan.dat 2020-03-17 17:27:10.237 Info App: Entry point completed: Emby.Server.Connect.ConnectEntryPoint. Duration: 0.1148476 seconds 2020-03-17 17:27:10.237 Info App: Core startup complete 2020-03-17 17:27:10.237 Info App: Post-init migrations complete 2020-03-17 17:27:10.237 Info App: Starting entry point Emby.Security.PluginSecurityManager 2020-03-17 17:27:10.238 Info App: Entry point completed: Emby.Security.PluginSecurityManager. Duration: 0.000147 seconds 2020-03-17 17:27:10.238 Info App: Starting entry point Emby.Server.CinemaMode.IntrosEntryPoint 2020-03-17 17:27:10.238 Info App: Entry point completed: Emby.Server.CinemaMode.IntrosEntryPoint. Duration: 0.0004778 seconds 2020-03-17 17:27:10.238 Info App: Starting entry point Emby.Webhooks.WebhooksEntryPoint 2020-03-17 17:27:10.246 Info App: Entry point completed: Emby.Webhooks.WebhooksEntryPoint. Duration: 0.0074842 seconds 2020-03-17 17:27:10.246 Info App: Starting entry point Emby.PortMapper.ExternalPortForwarding 2020-03-17 17:27:10.251 Info App: Entry point completed: Emby.PortMapper.ExternalPortForwarding. Duration: 0.0052763 seconds 2020-03-17 17:27:10.251 Info App: Starting entry point NfoMetadata.EntryPoint 2020-03-17 17:27:10.251 Info App: Entry point completed: NfoMetadata.EntryPoint. Duration: 0.0003575 seconds 2020-03-17 17:27:10.251 Info App: Starting entry point MediaBrowser.Api.ApiEntryPoint 2020-03-17 17:27:10.251 Info App: Entry point completed: MediaBrowser.Api.ApiEntryPoint. Duration: 0.0001269 seconds 2020-03-17 17:27:10.251 Info App: Starting entry point Emby.Server.Implementations.Udp.UdpServerEntryPoint 2020-03-17 17:27:10.415 Info App: Entry point completed: Emby.Server.Implementations.Udp.UdpServerEntryPoint. Duration: 0.1263046 seconds 2020-03-17 17:27:10.415 Info App: Starting entry point Emby.Server.Implementations.Playlists.PlaylistsEntryPoint 2020-03-17 17:27:10.417 Info HttpServer: HTTP GET http://localhost:8096/. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0 2020-03-17 17:27:10.424 Info App: Entry point completed: Emby.Server.Implementations.Playlists.PlaylistsEntryPoint. Duration: 0.0091381 seconds 2020-03-17 17:27:10.424 Info App: Starting entry point Emby.Server.Implementations.News.NewsEntryPoint 2020-03-17 17:27:10.425 Info App: Entry point completed: Emby.Server.Implementations.News.NewsEntryPoint. Duration: 0.0003243 seconds 2020-03-17 17:27:10.425 Info App: Starting entry point Emby.Server.Implementations.Library.DeviceAccessEntryPoint 2020-03-17 17:27:10.464 Info App: Entry point completed: Emby.Server.Implementations.Library.DeviceAccessEntryPoint. Duration: 0.0395765 seconds 2020-03-17 17:27:10.464 Info App: Starting entry point Emby.Server.Implementations.IO.LibraryMonitorStartup 2020-03-17 17:27:10.690 Info HttpServer: HTTP Response 302 to 127.0.0.1. Time: 426ms. http://localhost:8096/ 2020-03-17 17:27:11.026 Info HttpClient: GET https://emby.media/community/index.php?/blog/rss/1-media-browser-developers-blog 2020-03-17 17:27:11.854 Info TaskManager: StartupTrigger fired for task: Check for plugin updates 2020-03-17 17:27:11.886 Info TaskManager: Executing Check for plugin updates 2020-03-17 17:27:11.933 Info HttpClient: GET https://www.mb3admin.com/admin/service/EmbyPackages.json 2020-03-17 17:27:11.933 Info TaskManager: StartupTrigger fired for task: Check for application updates 2020-03-17 17:27:11.939 Info TaskManager: Executing Check for application updates 2020-03-17 17:27:11.991 Info HttpClient: GET https://api.github.com/repos/MediaBrowser/Emby.Releases/releases 2020-03-17 17:27:12.002 Info TaskManager: StartupTrigger fired for task: Hardware Detection 2020-03-17 17:27:12.002 Info TaskManager: Executing Hardware Detection 2020-03-17 17:27:12.023 Info FfmpegManager: FFMpeg: /opt/emby-server/bin/ffmpeg 2020-03-17 17:27:12.023 Info FfmpegManager: FFProbe: /opt/emby-server/bin/ffprobe 2020-03-17 17:27:12.023 Info FfmpegManager: FFDetect: /opt/emby-server/bin/ffdetect 2020-03-17 17:27:12.151 Info FfmpegManager: ProcessRun 'ffmpeg -hide_banner -version' Execute: /opt/emby-server/bin/ffmpeg -hide_banner -version 2020-03-17 17:27:12.390 Info HttpServer: HTTP GET http://localhost:8096/web/bower_components/emby-webcomponents/themes/logowhite.png. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0 2020-03-17 17:27:12.391 Info HttpServer: HTTP Response 304 to 127.0.0.1. Time: 1ms. http://localhost:8096/web/bower_components/emby-webcomponents/themes/logowhite.png 2020-03-17 17:27:12.568 Info HttpServer: HTTP GET http://localhost:8096/web/touchicon114.png. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0 2020-03-17 17:27:12.574 Info HttpServer: HTTP Response 200 to 127.0.0.1. Time: 6ms. http://localhost:8096/web/touchicon114.png 2020-03-17 17:27:12.574 Info HttpServer: HTTP GET http://localhost:8096/web/favicon.ico. UserAgent: Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:73.0) Gecko/20100101 Firefox/73.0 2020-03-17 17:27:12.595 Info App: Entry point completed: Emby.Server.Implementations.IO.LibraryMonitorStartup. Duration: 2.1310552 seconds 2020-03-17 17:27:12.595 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint 2020-03-17 17:27:12.596 Info App: Entry point completed: Emby.Server.Implementations.EntryPoints.AutomaticRestartEntryPoint. Duration: 0.0003638 seconds 2020-03-17 17:27:12.596 Info App: Starting entry point Emby.Server.Implementations.EntryPoints.KeepServerAwake
Luke 42246 Posted September 29, 2020 Posted September 29, 2020 Hi, can you please try Emby Server 4.5? Thanks.
