IncredibleJohn 2 Posted March 14, 2020 Posted March 14, 2020 So I have used Emby for a while on my Shield TV Pro. I have Bose 700 headphones and I can't pause things through them on emby like I can on plex. Hopefully an emby dev sees and fixes this.
Luke 42246 Posted March 14, 2020 Posted March 14, 2020 Hi there, what version of the emby app are you running?
IncredibleJohn 2 Posted March 14, 2020 Author Posted March 14, 2020 I am running 1.7.92g Says VD(4.3.1.0) also if that helps
ebr 16338 Posted March 15, 2020 Posted March 15, 2020 Hi. Exactly what are you doing and what are you expecting to happen?
IncredibleJohn 2 Posted March 15, 2020 Author Posted March 15, 2020 I am playing a movie or any kind of media. To pause with Bose 700 you double tap the side to pause and play things. This works on most apps, like plex, youtube, Spotify, Netflix and so on. However it does not work on Emby.
