rechigo 367 Posted March 14, 2020 Posted March 14, 2020 @@ebr CoverArt plugin does not respect the quality option set in the query. Without the CoverArt plugin, the quality option is respected, so this is not an Emby problem. Without coverart: With coverart (quality is set to 1, you shouldn't even be able to make this out):
Luke 42255 Posted March 14, 2020 Posted March 14, 2020 It seems to be working just fine from here. If you check the server log it's always possible there was some kind of image processing failure and then it would just return the original.
rechigo 367 Posted March 14, 2020 Author Posted March 14, 2020 Checked the server log, no errors Are you running the 4.4.0.25 beta and cover art 4.1.9?
rechigo 367 Posted March 14, 2020 Author Posted March 14, 2020 I tried it in Edge (Chromium build stable) and in Firefox I checked the hash of a quality=1 and a quality=100 image file and the hashes match up the same, so It's safe to say the image wasn't being processed at all. Changing width and height does work, just the quality option seems to not be respected
