Cthalpa 11 Posted March 13, 2020 Posted March 13, 2020 At times, when movies/scenes are bright, or when there is hardcoded subtitles and loose/external subtitles displayed over, the text is very hard to read. I would suggest adding the feature to enable a black transparent box around the subtitles, as you see in e.g. Netflix etc.If this is already possible, I have failed to figure out how, and I would like to know how and apologize for the feat. request /BR
rbjtech 5345 Posted March 13, 2020 Posted March 13, 2020 (edited) You mean the subtitle 'drop shadow' ? if yes, then depending on the client and subtitle type, you can change this to be a solid black border (Uniform) or faded 'Drop Shadow' if you like. It's in the 'User' settings under 'Subtitles'.. Edited March 13, 2020 by rbjtech
ebr 16339 Posted March 13, 2020 Posted March 13, 2020 https://emby.media/community/index.php?/topic/45892-subtitle-size-and-color/?p=643177
