plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, radeon said: So another bloody beta basically! I didn't think about that before! haha. An nfo is an nfo right? lol 1
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 2 minutes ago, radeon said: So another bloody beta basically! Would you mind posting your nfo for The Endless to pastebin or something? I can try populating it into my entry and scan with Emby again to see what happens.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 (edited) duped it Edited February 12, 2021 by plaidstallion duped it
radeon 760 Posted February 12, 2021 Posted February 12, 2021 2 minutes ago, plaidstallion said: Would you mind posting your nfo for The Endless to pastebin or something? I can try populating it into my entry and scan with Emby again to see what happens. That's what I mean tho, I don't have any as I don't have emby or radarr creating them. My emby just generates it's data and stores it in the db. I can kick it into generating one of you want but I'm not sure it'll help. For now, why don't you just turn off all radarr emby and Kodi metadata stuff. Delete all your local metadata for that movie. Run a fill library scan, then go into the web UI and tell emby to refresh the metadata, then try the plugin scheduled task/check out your db and see how the URLs look 1
CBers 7558 Posted February 12, 2021 Posted February 12, 2021 7 minutes ago, plaidstallion said: I mean, if I don't need to I won't as Radarr is doing it I just wasnt' sure if Emby needed to be creating an nfo for the plugin to work properly Don't enable any metadata options with Radarr (or Sonarr), as they're not needed, with Emby doing it for you and then just enable the nfo option within Emby. 7 minutes ago, radeon said: So another bloody beta basically! Yes, but it's not a problem, if you don't enable metadata options. 1
Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 (edited) That is the thing thought, Emby write the same in nfo but database has different. From a Emby metadata only standpoint so from a third party standpoint something else is happening. @Lukefrom a import standpoint should Emby import the plugin:// url from the nfo as shown here? Edited February 12, 2021 by Happy2Play 1
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 (edited) 13 minutes ago, radeon said: That's what I mean tho, I don't have any as I don't have emby or radarr creating them. My emby just generates it's data and stores it in the db. I can kick it into generating one of you want but I'm not sure it'll help. For now, why don't you just turn off all radarr emby and Kodi metadata stuff. Delete all your local metadata for that movie. Run a fill library scan, then go into the web UI and tell emby to refresh the metadata, then try the plugin scheduled task/check out your db and see how the URLs look Ok I will try to run through that tomorrow and report back. Thanks for all the help. It definitely seems to be something about how the DB is being populated as the movies the plugin does try to pull the trailers for start with like TMDB ... and then some other text before the link whereas the ones that the plugin doesn't see look like this:   Edited February 12, 2021 by plaidstallion 1
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 9 minutes ago, CBers said: Don't enable any metadata options with Radarr (or Sonarr), as they're not needed, with Emby doing it for you and then just enable the nfo option within Emby. Yes, but it's not a problem, if you don't enable metadata options. So delete all the metadata and remove the move then put it back and scan it into Emby and look at the DB again?
Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 10 minutes ago, plaidstallion said: So delete all the metadata and remove the move then put it back and scan it into Emby and look at the DB again? That would validate if everything comes from Emby it works.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 Ok WTH. I turned off all metadata collection for Radarr. Removed the movie then did a scan in Emby to get rid of it. I then had Radarr import the movie again without adding any metadata. I then did a Replace Metadata >> Search for Missing Metadata in Emby then did a scan and a new nfo showed up next to the file ...and a trailer. I don't get what the difference is or why it all worked before. I need to figure out how to get the fanart and poster and all that stuff now though. Hold over from my XBMC days and liking to have all the metadata live in the same folder as the movie.
Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 2 minutes ago, plaidstallion said: I need to figure out how to get the fanart and poster and all that stuff now though. Hold over from my XBMC days and liking to have all the metadata live in the same folder as the movie. Go to Dashboard-Library, select specific library click the Show Advanced setting switch and scroll down to your image option and ensure you have enabled save with media and download in advanced.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 (edited)  15 minutes ago, Happy2Play said: Go to Dashboard-Library, select specific library click the Show Advanced setting switch and scroll down to your image option and ensure you have enabled save with media and download in advanced. Abso-freaking-lutely perfect. Thank you @radeon, @Happy2Play and the others who contributed. It would be cool to know why it doesn't work any more in the configuration I had been using since I started with the plugin but whatever, I will take it. This will probably even work out better as Emby allows for per library language specification for metadata. This is a beautiful  sight knowing that it happened automatically:   Edited February 12, 2021 by plaidstallion 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 13 minutes ago, plaidstallion said:  Abso-freaking-lutely perfect. Thank you @radeon, @Happy2Play and the others who contributed. It would be cool to know why it doesn't work any more in the configuration I had been using since I started with the plugin but whatever, I will take it. This will probably even work out better as Emby allows for per library language specification for metadata. This is a beautiful  sight knowing that it happened automatically:   Sweet! That's nice to see! Glad we got you there in the end. Like you say, some questions still to be answered but that's good progress!Â
plaidstallion 9 Posted March 18, 2021 Posted March 18, 2021 (edited) Is the plugin not working again? Â Edit: NM. Possible ffalse alarm. Two imported movies, one grabbed the trailer the other didn't. Will keep watching it. Edited March 18, 2021 by plaidstallion
dcol 177 Posted March 18, 2021 Posted March 18, 2021 Using the stable version of Emby and Ytrailers still throws a ton of errors in the log. But seems to be working somewhat for me. It likes to error over and over again on the same movies saying file exists. Duh.
plaidstallion 9 Posted April 2, 2021 Posted April 2, 2021 I think it stopped working for me again the past couple days.
dcol 177 Posted April 2, 2021 Posted April 2, 2021 (edited) This is common, I don't even use it anymore because it throws constant errors. Usually on the same movies over and over again. And this is on the stable Emby. This plugin needs a redo. I use Media Center Master to fetch my trailers and it never needs updates or checks the same movies twice, so it can be done. It uses the same technique of looking for the trailer URL's in nfo's and XML's with lots of extra features like manually pulling in trailers from IMDB ID's or YouTube and the ability to control the resolution. Also you can set the libraries you want included. Also, you can use Emby beta because it is not dependent on Emby to run. Downside is you need MCM pro to get trailers, but YTrailers isn't free either. Edited April 2, 2021 by dcol
radeon 760 Posted April 2, 2021 Posted April 2, 2021 I'm lost, I don't get many issues at all. I catch most of the issues and throw them to debug which if you have turned off then you wouldn't be getting them. The only ones that throw real errors are reported as errors.  You can't really have it both ways. I feel like you're just going to hate it whatever it does and I can't really help that. Im off grid until next week but it's currently running fine for me. 5 minutes ago, dcol said: This is common, I don't even use it anymore because it throws constant errors. Usually on the same movies over and over again. And this is on the stable Emby. This plugin needs a redo. I use Media Center Master to fetch my trailers and it never needs updates or checks the same movies twice, so it can be done. It uses the same technique of looking for the trailer URL's in nfo's and XML's with lots of extra features like manually pulling in trailers from IMDB ID's or YouTube and the ability to control the resolution. Also you can set the libraries you want included. Also, you can use Emby beta because it is not dependent on Emby to run. Downside is you need MCM pro to get trailers, but YTrailers isn't free either. Â
plaidstallion 9 Posted April 8, 2021 Posted April 8, 2021 (edited) On 4/2/2021 at 7:17 PM, dcol said: This is common, I don't even use it anymore because it throws constant errors. Usually on the same movies over and over again. And this is on the stable Emby. This plugin needs a redo. I use Media Center Master to fetch my trailers and it never needs updates or checks the same movies twice, so it can be done. It uses the same technique of looking for the trailer URL's in nfo's and XML's with lots of extra features like manually pulling in trailers from IMDB ID's or YouTube and the ability to control the resolution. Also you can set the libraries you want included. Also, you can use Emby beta because it is not dependent on Emby to run. Downside is you need MCM pro to get trailers, but YTrailers isn't free either. Looks like Media Center Master needs to run on Windows. Yucky. I need something that will run on my headless server and if it doesn't have a WebUI, that I would be able to run it in a container and VNC to that. Edited April 8, 2021 by plaidstallion
blackstar88 2 Posted June 12, 2021 Posted June 12, 2021 ust payd for the ytrailers put it in to the pluggin folder on my nas 918+ running emby from there and no trailers downloading ive put the license in ofc and rebooted ofc ... its working theme videos tv& movies but ytrailer... nothing... running latest beta on emby...
dcol 177 Posted June 12, 2021 Posted June 12, 2021 ytrailers does not work in the beta version of Emby
blackstar88 2 Posted June 12, 2021 Posted June 12, 2021 Â 1 minute ago, dcol said: ytrailers does not work in the beta version of Emby how do i get it to work then?
blackstar88 2 Posted June 12, 2021 Posted June 12, 2021 Just now, dcol said: use the stable version, or get MediaCenterMaster ty will look in to the mediacentermaytrster... since emby sometimes dosent trow me the trailer on some giving me error. wanted to try out ytrailer... but will ytrailer work on next stable emby? Â
