Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 This plugin will read the database. The trailer node from nfo should be populating the database info. If it is not in the database the plugin can not do anything. 1
dcol 177 Posted February 12, 2021 Posted February 12, 2021 (edited) Would be nice to have the trailer in the metadata GUI so you can manually add it and quickly see if it exists. Edited February 12, 2021 by dcol
roaku 842 Posted February 12, 2021 Posted February 12, 2021 18 minutes ago, dcol said: I was under the assumption from past posts that it was youtube changing things not Emby. Why have you decided that only one of those things can happen? 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 (edited) I've just added a fake "the endless" movie to my library, let emby do its thing and a couple of mins later the trailer was automatically downloaded. Do you have emby creating your metadata or radarr? Emby also needs to have the tmdb metadata provider enabled for your movies Edited February 12, 2021 by radeon
dcol 177 Posted February 12, 2021 Posted February 12, 2021 Because when I mentioned it in the past the response was that YouTube changed something. No one ever responded to me about the beta issue before today.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 2 minutes ago, Happy2Play said: This plugin will read the database. The trailer node from nfo should be populating the database info. If it is not in the database the plugin can not do anything. I don't know how to get that DB view you have in the top part of the picture but the thing is I have put in several high profile movies in the past days since putting in the new plugin and nothing is downloading, unfortunately.
radeon 760 Posted February 12, 2021 Posted February 12, 2021 2 minutes ago, dcol said: Would be nice to have the trailer in the metadata GUI so you can manually add it and quickly see if it exists. That would be one for emby core, not this plugin
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, radeon said: I've just added a fake "the endless" movie to my library, let emby do its thing and a couple of mins later the trailer was automatically downloaded. Do you have emby creating your metadata or radarr? Emby also needs to have the imdb metadata provider enabled for your movies I believe only Radarr is creating the movie.nfo. I will dig around a bit.
radeon 760 Posted February 12, 2021 Posted February 12, 2021 (edited) 3 minutes ago, dcol said: Because when I mentioned it in the past the response was that YouTube changed something. No one ever responded to me about the beta issue before today. because the error you had before related t a change to the plugin, the new error you posted related to a missing assembly because you were running beta. With the greatest of respect, and i do genuinely mean that, if you can't interpret the errors in your logs then you really shouldn't be using beta. Edited February 12, 2021 by radeon
radeon 760 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, plaidstallion said: I believe only Radarr is creating the movie.nfo. I will dig around a bit. sorry, typo there in my post, should have put tmdb NOT imdb
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 This needs to be checked for the library?
roaku 842 Posted February 12, 2021 Posted February 12, 2021 (edited) 4 minutes ago, dcol said: Because when I mentioned it in the past the response was that YouTube changed something. No one ever responded to me about the beta issue before today. You showed an error message *today* that indicated a beta incompatibility. That doesn't mean that YouTube api changes haven't broken things in the past, present, or won't again on the future. Edited February 12, 2021 by roaku 1
dcol 177 Posted February 12, 2021 Posted February 12, 2021 (edited) 4 minutes ago, radeon said: because the error you had before related t a change to the plugin, the new error you posted related to a missing assembly because you were running beta. With the greatest of respect, and i do genuinely mean that, if you can't interpret the errors in your logs then you really should be using beta. Just sayin', today was the first time that came out. I have been using ytrailers with the beta for a while and it was never a 'beta' issue until today. So I guess I shouldn't be using any third party plugins with the beta. Edited February 12, 2021 by dcol 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, plaidstallion said: This needs to be checked for the library? no, this one ^^
Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 (edited) 5 minutes ago, plaidstallion said: I believe only Radarr is creating the movie.nfo. I will dig around a bit. That could be it also as there is a difference of not used written metadata. Emby could write but never read specific nodes. So a question for a server dev would be is the trailer node read on import from existing metadata? Do you have Emby metadata providers enable or just having Emby attempt to read provided metadata from 3rd party? Edited February 12, 2021 by Happy2Play 1
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 Just now, radeon said: no, this one ^^ That I had checked already. 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, dcol said: Just sayin', today was the first time that came out. I have been using ytrailers with the beta for a while and it was never a 'beta' issue until today. maybe, but thats the point of beta, they change stuff all of the time, some are breaking changes to other plugins. You being unable to read the error had you jumping all over how useless the plugin was yet it had nothing to do with it.
roaku 842 Posted February 12, 2021 Posted February 12, 2021 (edited) 4 minutes ago, dcol said: Just sayin', today was the first time that came out. I have been using ytrailers with the beta for a while and it was never a 'beta' issue until today. Again, there can be more than one thing wrong at a time. One of your problems is/was running a release compatible plugin within an Emby beta. Edited February 12, 2021 by roaku 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 Just now, plaidstallion said: That I had checked already. see @Happy2Play's response, at a guess, it sounds to me like it's your radarr creating half baked metadata that could be causing it
Happy2Play 9814 Posted February 12, 2021 Posted February 12, 2021 (edited) The server should tell you when it breaks a plugin assume correct info is in the plugin itself. See log files. Might be more behind the scenes from Luke though with this example. example 2021-02-10 07:08:33.449 Info App: Not loading PeopleBackup.dll 1.4.1.0 because the minimum supported version is 1.5.0. Please update to the newer version Edited February 12, 2021 by Happy2Play
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 1 minute ago, radeon said: see @Happy2Play's response, at a guess, it sounds to me like it's your radarr creating half baked metadata that could be causing it I am just not sure how to check that DB and it was working fine before the last version of the plugin broke.
plaidstallion 9 Posted February 12, 2021 Posted February 12, 2021 I haven't changed anything with metadata collection or generation
dcol 177 Posted February 12, 2021 Posted February 12, 2021 Does explain why I have had constant issues with this plugin. Never occurred to me before or mentioned. But in fact this plugin should NOT be used with the beta version.
roaku 842 Posted February 12, 2021 Posted February 12, 2021 (edited) 3 minutes ago, dcol said: Does explain why I have had constant issues with this plugin. Never occurred to me before or mentioned. But in fact this plugin should NOT be used with the beta version. You understand that even the core functionality of Emby might not work in a beta? How can you expect *more* stability from a plugin running inside that experiment than its host promises? Edited February 12, 2021 by roaku 1
radeon 760 Posted February 12, 2021 Posted February 12, 2021 3 minutes ago, plaidstallion said: I am just not sure how to check that DB and it was working fine before the last version of the plugin broke. like I say, that example film you listed has just downloaded a trailer absolutely fine for me. It seems to me that your emby isnt pulling down the tmdb data for some reason. I could release a version with some extra debug to log all trailers listed against a given movie perhaps. that would at least show you if the trailer data is in the db or not
